Thread: "What did you do to your E39 today V2.0."
  1. #8701
    Jul 2013
    Worcester, MA
    03 540i Msport Touring
    if you want all oem you'll need this
    https://www.schmiedmann.com/en/produ...1-60-0-028-229
    thankfully that kit comes with the bumper reinforcement piece and the removable flap so all you need is the hole cut in your bumper, the modified bumper carrier, and the tow bar...
    but all that together, new, with shipping is like $893, before cutting the support, phew
    Looking for an e39 Touring black carpet set, including the rear cargo cubbies and side sections!
    ALSO looking for 540i 6speed manual transmission sets (2001+ pedals with switches, driveshaft, gearbox), for the 6speed swap! Probably not for a while....
    GN92489
    540i msport touring; jet black on grey
    Progress Thread (general)
    Progress thread (touring specific)
  2. #8702
    Sep 2008
    San Jose, CA
    00 528/5 & 02 530i Sport
    Got some new rubber and an alignment. Put some hankook ventus v12 evo2s -- loving them so far!
  3. #8703
    Mar 2013
    So~Cal
    2003 E46 M3 / E30 Vert
    My Valeo alternator Stopped Alternatin', so it got Alter-nated with a Bosch Alternate.
  4. #8704
    Santa Cruz Mountains
    '03 M-Sport 540iA
    Troubleshooting rough idle and cut off when cold on my 2000 M62tu with original Vanos and TCG's at 246k.
    Bummer, P0340 so I replaced both sensors as preventative. She runs fine one day and then two days later, the code returns accompanied with fuel cutoff due to misfire. The bummer is that the rough cold idle became worse and now the tach "hunts" for idle and actually shut down a couple times. I found an old thread on the subject (search engine is your friend) and have swapped out the passenger side with the old, known working unit from the driver's side. Now I have to wait for the engine to cool off enough to give it another run...
    This actually reminds me of the symptoms when the MAF/HFM5 was failing (no codes). When cold, the engine would be trippin' but wouldn't throw any codes. Once warmed up, PERFECT operation. On the day that I received the new MAF/HFM5, "DING"...code popped up. I replaced it then (+/-120k) and haven't had any issues until now. The difference this time is that the very specific code, P0340 showed up. I'll try to remember to report my results...IF you guys are interested.
    BTW, I bought what I thought were OE CPS replacements from FCP but after removing the passenger side, I don't see ANY indication that it's an OE BMW part...
    '00 540iA Sport w/235k+ Original TCG's, Vanos and transmission.​*Trans failure at 244k+...FS Now
  5. #8705
    Sep 2015
    Sincinnati
    2000 540i6, 2008 535xiT
    Violin, an acquaintance of mine is dealing with this right now. He replaced literally everything. Down to the entire engine, lol with a known good one. The compression on his original was a bit low with...ironically 246k mls. New engine harness and all, replaced both cam sensors. Still runs like crap.
    Began tracing the bank 1 cam sensor wire back to the DME, found a loose pin. Literally moving the DME around while it was running would cure the misfire, when he'd put it back in the box, the misfire would return.
    Garage Queen: Biarritz Blue 540i6
    Daily Driver: Burger Tuned Titan Silver 535xiT
    Sold: RHD Steel Blue E46 328i
    Sold: 2006 Black Sapphire M5
  6. #8706
    Sep 2015
    Sincinnati
    After being side-swiped back in October, I've been on the hunt for a replacement driver rear door in Biarritz Blue for months. Turns out it's a fairly hard to find color. Finally found one at a yard 12 miles from me. Had PDR done on the front door but the rear wasn't salvageable.
    SO, my first time taking the door off of an E39 went well. Window on the replacement door doesn't work though -_-
  7. #8707
    Jan 2015
    Tempe, AZ
    1995 525i/5
    I'm amazed you were able to find a good door in that color with paint still on it... in Arizona the junkyard cars usually have no paint left on them due to the sun roasting it all off.
    1995 525i 5-speed - Thread
  8. #8708
    Sep 2015
    Sincinnati
    I genuinely was too. I found a single one previously, but it wasn't even close to being a reasonable driving distance away, and not seeing it in person I wasn't comfortable purchasing it and having it shipped. I've been on car-part dot com every couple of days for the past few months looking for new postings. Found this one on Tuesday and immediately went to look at it. I liked what I saw so I purchased it right there and stuffed it into the back seat of my G30 loaner lol. I believe it's been repainted at some point in it's life, but if you're not looking for it you wouldn't notice it.
    The only E39's with bad paint around here I typically see are early black ones or that weird purple color they did for a year or two. I can't imagine having to try and source painted parts out west on cars this old. I've never seen another biarritz blue in person, it appears that most of them, at least locally have been banished to e39 heaven.
  9. #8709
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    Vacuumed and tidied up the interior.
    Nate J.
    (oOO\ (|||)º(|||) /OOo)
    (eŌō\ (||||)º(||||) / ōŌe)
  10. #8710
    Jan 2015
    Tempe, AZ
    1995 525i/5
    Today's my last day at my job... I'm annoyed that I don't have my GoPro, I guess I'll just have to use my phone to film the fat burnout I'm gonna do on the way out of here at the end of the day.
  11. #8711
    Sep 2008
    San Jose, CA
    Quote Originally Posted by dannyzabolotny View Post
    You should draw a member w/ your skid marks lol
  12. #8712
    Jan 2015
    Tempe, AZ
    1995 525i/5
    I did a tidy little burnout and recorded it:
    I wish the lighting was better but it was really satisfying A fitting end to this chapter of my life.
  13. #8713
    Sep 2015
    Sincinnati
    Yessss!
  14. #8714
    Aug 2016
    Virginia,USA
    528i, 525iT, M5
    I smell roasting tires!
    Current Garage Highlights
    2003 525iT TiSilver
    2002 M5 TiSilver
    Former Garage Highlights
    2005 X5 4.8is
    2004 325iTs (2x)
    1973 Pantera L
    1969 Road Runner 383
  15. #8715
    Dec 2016
    Canton, Ohio
    97 528i
    you go boyyeeee!!! wish I'da done that at my last job...lol !!!
    congrats D! and best wishes moving forward !!!
    "two wrongs don't make a right...only three lefts do...."
    '79 Euro 635csi - gone and regretting it...
    '89 gsxr-750 - former traffic knife
    '97 528i sedan - holding on strong...(just sold after 16 years of ownership - sad day)
    '03 Euro 525it - something about a famous dolphin.....
    '06 Mercury Grand Marquis (don't ask....it gets the job done....)
    '84 Specialized Allez - full Campagnolo Super Record
    '99-ish Cannondale CAAD4
    "Stinky" - Kona Stinky Five
    '86 528e
    2008 E70 X5 3.0
  16. #8716
    Jan 2015
    Tempe, AZ
    1995 525i/5
    Quote Originally Posted by StephenVA View Post
    Oh yeah, it smelled real good. It was the smell of freedom right there.
    Quote Originally Posted by adm750 View Post
    I've had that on my mind ever since I decided to quit, haha. I wish I had gotten a better video but ultimately it was just satisfying for me. I left on good terms with a proper two week notice, and I'm still friends with all my former coworkers, so it was nothing but good vibes yesterday. I'm excited for the next chapter in life, so we'll see what happens.
    In the meantime, I'm going to be starting another chain guide job on Monday on a lovely Glacier Green over Stone Green 540i/6. And I'll be finishing the part-out of my 540it as well as starting to part-out the 540i/6 (after I give it a good final thrashing). Now I'll finally have the time to complete my 540it's interior swap along with the manual swap. Pretty stoked on all of it.
  17. #8717
    Feb 2016
    Destin, FL
    W220 S55 AMG, E39 540i6
    And Danny wonders why his tires cause weird vibrations ;-)
    Jk Danny. Congrats and best of luck with the new adventures.
    Chris
    04 Mercedes S55 AMG
    97 BMW 540i6
  18. #8718
    Lawrenceville, GA
    4 BMWs.
    Best of luck, Danny!
  19. #8719
    Sep 2013
    Tx.
    02 bmw 540
    Lol. Nothing like the smell of burned rubber ( Tim Allen grunting).
    My kind of guy !
  20. #8720
    Sep 2008
    San Jose, CA
    On the 528 -- Rebuilt my parking brakes, changed brake discs front/rear, installed akebono ceramics and flushed fluid. VCG has been leaking so will tackle that next.
  21. #8721
    Jul 2012
    mitten
    525it,02 525it,73 2002
    Put a little Parker Super O-Lube on the rear SLS airbag connection,have had a slow leak on driver side. Hopefully that will cure it since plastic o-ring clip is NLA.
  22. #8722
    Oct 2016
    Shoreview MN
    Had a 1991 BMW 850
    Did some gratuitous doughnuts in the parking lot of the ski hill in the 528i Wagon.
    Still monitoring and getting more mileage between adding oil after changing the CCV system.
  23. #8723
    Dec 2016
    Canton, Ohio
    97 528i
    Quote Originally Posted by jp5Touring View Post
    That stuff is slicker than owl $#it isn't it !!?? Doesn't take much....
    We appreciate your patronage btw...!!
  24. #8724
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    TWSS.
    FWIW Arnott supplies new clips with their bags, maybe they'd sell you one. I think you could prob fabricated a metal version from a broken plastic one if you were determined.
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
  25. #8725
    Dec 2016
    Canton, Ohio
    97 528i
    Ok...so (much to the dismay of my wife and kids...)I have spent every single weekend for the last month and a half...or longer...working on Frau Christine !!!
    Finally got 'front wheel bearing number two' installed yesterday. That was a tough job. One bolt was very agreeable...but it took me over an hour to persuade the other 3 hub bolts that they needed to come out too since their other old bolt friend was lying on the ground all by itself and missing it's other three old bolt friends. Mucho time with the impact gun, and a light heating of the other 3 corners of the hub base (where the bolt threads show through) and we had 4 old bolts on the ground all hanging out with each other again.
    New hub goes on, four new bolts go in, everything gets re-assembled. I take it out...and ol' growly is now nice and quite going down the road. But as I drove down said road, I was like "why the heck is this thing not shifting..??" She got to 3rd and just hung there !! I looked down and found I'd hit the jackpot ! Got the ABS/DSC/BRAKE warning light trifectra !!
    Guess I know what I'm doing this week. Working on this car...again.....
Page 349 of 672 FirstFirst ... 249299324339340341342343344345346347348349350351352353354355356357358359374399449 ... LastLast
