Thread: "What did you do to your E39 today V2.0."
  1. #6201
    Middle of a corn field
    E39 hamster/ruberbandPWR
    Awesome work JP !
  2. #6202
    Rural KY
    2002 BMW 530i Sport
    It has been forever since I've listed but I've got a laundry list of things in doing after my board exam. But today, I replaced the assisters in one headlight. Coming up
    Changing
    All coils
    All of sensors
    Tan to black interior conversion
    And more.
  3. #6203
    Jul 2013
    Ontario, Canada
    1998 528i; 2000 540i;
    Got the sleeve off of the thrust arm ball joint. I used the Scwaben 20 - 80 ball joint tool with an appropriately sized socket over the top of the spindle to give a better purchase. It popped off easily. I don't know why it didn't do this when the sleeve was in the steering knuckle.
    The sleeve is now in the freezer overnight to "shrink". I bought a torch to heat the steering knuckle - and I'll do that it the morning and then hopefully the frozen sleeve will drop right in and I can get it all put back together.
    I got the RHS thrust arm in place in the meantime - without torquing the bolt through the bushing. That's for later.
    gmak: The Good, the Bad, and the Ugly. A journey with my new-to-me 2000 540i
    "Working on a BMW E39 is the best way to run out of time."
  4. #6204
    Feb 2014
    Caboolture, Q, Australia
    E39 535i
    You'll find it will press right in to the knuckle with minimal. Effort using a normal G clamp, especially if the steel is in the freezer.
    I'd advise against heating the alloy with a torch myself...
    Absinthe makes the tart grow fonder
  5. #6205
    Jul 2013
    Ontario, Canada
    I'll try it without heat first and then.... Interesting perspective because all I've heard lately is to bring the heat, it seems.
  6. #6206
    Mar 2016
    Brothell, WA
    03 540i
    I had the passenger side corroded tail light connector. The pins were solid rust and none of the pass side lights worked. Instead of replacing a perfectly good tail light assembly, I spliced in some molex connectors by drilling into and soldering wires into the metal plates that correspond to each pin. Now everything works!
  7. #6207
    May 2015
    Virginia
    E39, E39
    Prepped my M front bumper for paint tomorrow. Came out very good considering I'm using spray cans. Anyone have tips on installing the fog lights and fog light covers. Is everything supposed to slide in place? I don't want to scratch paint trying to install.
    Sent from my SM-G955U using Tapatalk
    2013 Ford F-150 FX4 Ecoboost
    2002 530i/5 M-Sport
    1994 318i/5 (Up for sale Soon)
  8. #6208
    Oregon/Ukraine
    E39 M-Sport F30 M-Sport
    Quote Originally Posted by mebjr12 View Post
    I had the same fear from my past experience installing front m5 bumpers on the 530. What I did was hooked the outer trim piece in first and then popped the inners in without damaging the paint. Don't expect the fog lights to fit in any way lmao.
    E39 WhatsApp Chat Gruppe
  9. #6209
    May 2015
    Virginia
    E39, E39
    Quote Originally Posted by RuskiE39 View Post
    Would you mind explaining a little more? I got the bumper from someone selling their e39 and it was never installed? Wasn't sure if I was missing any hardware. But for $100 I figured why not. Does the fog install from the top or bottom, and the the cover be but in first?
    2002 530i/5 M-Sport
  10. #6210
    Oregon/Ukraine
    is the bumper OEM or aftermarket? The hooks on the fog lights don't line up with the bumper so you won't get a snug fit. What I did was put the fog lights into the fog light trim piece and then popped it into the bumper. Basically I didn't secure the fog lights tontje bumper at all because the trim piece holds the fog light to the bumper rather tightly.
  11. #6211
    May 2015
    Virginia
    E39, E39
    I'm pretty sure its aftermarket.
    2002 530i/5 M-Sport
  12. #6212
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    Quote Originally Posted by seabass07 View Post
    I had good results using a rust removing solution - "Metal Rescue Rust Remover" - and soaking the pins and the taillight socket for a few days. Perfectly clean when I removed them. Make sure to replace the taillight gaskets so that the water can't get in to rust them again.
    Nate J.
    (oOO\ (|||)º(|||) /OOo)
    (eŌō\ (||||)º(||||) / ōŌe)
  13. #6213
    Jul 2013
    Ontario, Canada
    Pressed in the steering knuckle sleeve on the LHS for the thrust arm on the 528i (M52). Here are a few pics.
    1. C-Clamp set up. It's massive and usually used for the rear ball joints. You can see the aluminum bearing press plates that I'm using to distribute the force a bit better.
    2. The goop I put on the sleeve for retention. Usually used in hotter environments in the engine - but should work here.
    3. The frozen sleeve in place. I decided to try pressing it without heating the steering knuckle.
    4. Clamp on pressing sleeve into place. I was able to turn the 'screw' by hand for most of the pressing except the last 1/4 inch or so.
    5. Bottom view of fully pressed sleeve to show clearance.
  14. #6214
    Jul 2013
    Ontario, Canada
    Here are a few more pictures showing that the cap on top does not sit flat on the knuckle - along with a view of the same sleeve top on the RHS.
    1. View of LHS cap after pressing. I put the clamp back on and pressed it a bit more after this.
    2. Other side for comparison
  15. #6215
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    Completed my steering wheel re-wrap. Final results are... okay. The fitment of the "cover" was decent-ish, but is a little loose near the 9-3 grips. I hope that tightens up with age, but who knows. I wonder if I could squeeze some sort of foam in there to firm things up a bit.
    There's less slack on the left side than the right (which is good, seeing as how I drive with one hand at 9 o'clock always)
    But a little more on the right.
    Backside has more wrinkles/looseness.
    Overall, I'm satisfied. I'll probably have at least one of these wheels professionally refinished at some point, but I don't have the budget for that now. This will hold me over until that time.
    Nate J.
  16. #6216
    Mar 2004
    Tyler, Tx
    '01 740i Sp, '07 335i
    Do you have a steamer or even your wife's steam iron if it has the steam blast that some have.
    http://i293.photobucket.com/albums/mm71/krallopian/darthSigTest2_zpsn6zkw5id.jpg[/URL][URL="http://www.facebook.com/pages/DFW7-Dallas-Fort-Worth-BMW-7-Series-Club/300942239566"]DFW7 on Facebook/URL]
    "The Last Great e38" 2001 i Sport - Born'd on date 1/01 Cosmos/Grey - 32.8K miles - 2 1/2 " Custom Exhaust, Center “X”over , Modified OEM rear bumper, M5 style trunk spoiler, M6 OEM wheels, M3 Steering wheel with working paddle shift & CF trim, Bi-Xenon upgrade, 13mm Rear sway bar added, SS brake lines and bronze bushings, Cross drilled rotors and painted calipers, Akebono pads, Zionsville aluminum radiator & exp. tank with electric fan, Sprint Booster, BluTooth conversion, MKIV Nav., Custom wood cupholder, DUDMD Tune, Orien V2.5 LED Angel Eyes, Evans waterless. Recently added grey faced //M5 Cluster - all gauges functioning. Changed the grey carpet to black and topped off with GG Bailey front/rear mats[/SIZE]
  17. #6217
    Feb 2009
    Hollywood, CA
    e39, e53, 957
    Still have to have it coded to the correct mileage and get the oil temp working. Everything else works as it should.
  18. #6218
    Feb 2014
    E39 535i
    Ordered a DME from DUDMD to replace the one killed because I was in a hurry and didn't check I had my ignition off...
  19. #6219
    Lawrenceville, GA
    4 BMWs.
    Today I cleaned out the brake booster housing drain hole on both the 528i and M5. Not much debris in there, but now it's nice and clear.
  20. #6220
    Oregon/Ukraine
    Quote Originally Posted by amancuso View Post
    Been meaning to do this... sigh, I need to stop procrastinating.
  21. #6221
    Raleigh, NC
    SR-71 Blackbird
    Better do it now ... I mean now in the middle of night. I should've done this long time ago when I still had my 530i and I would have still be driving it today.
  22. #6222
    Feb 2008
    Chicago
    2000 540i
    Link to a good DIY with photos for this? Just got my brake fluid flushed at a shop, I wonder if they did this.
  23. #6223
    Lawrenceville, GA
    4 BMWs.
    Quote Originally Posted by theshadow92 View Post
    There are no DIYs AFAIK. Basically just remove the driver's side cabin air filter housing and have at it with a vacuum and a long flexible wire (think pipe cleaner) to clean out the area under the brake booster.
  24. #6224
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    Quote Originally Posted by TxDarth View Post
    Good idea, thanks. I'll give that a try.
    I actually used the craft-style pipe cleaners to do precisely this. I have to do it about once a month; my yard has this tree with tiny, needle-like leaves that get stuck in everything.
    Nate J.
  25. #6225
    Oregon/Ukraine
    Ordered this today from ECS:
    Unsurprisingly, the estimated ship date is JULY 25..
    Here's a good DIY:
    https://www.bimmerforums.com/forum/s...your-e39-again
    http://www.bimmerfest.com/forums/sho...=587452&page=2
Page 249 of 672 FirstFirst ... 149199224239240241242243244245246247248249250251252253254255256257258259274299349 ... LastLast
