Results 1 to 12 of 12
Thread: Weird running after modifications, need help troubleshooting
    Aug 2023
    United States
    2001 E39 530i
    Question Weird running after modifications, need help troubleshooting
    2001 BMW 530i LCI, m54b30
    Over the winter while my car was garaged I decided to do some small projects I had wanted to do, and I did a new VCG & installed catless headers. VCG had no clear issues, doesn't seem to leak etc. Catless headers were installed fine, fairly confident is no exhuast leaks, and I fabbed a blockoff plate for the secondary air check valve. I removed & unplugged downstream 02 sensors and blocked the ports in the new headers, as they should be unnecessary since they are for monitoring cat health. Upstream sensors intact and are reading on INPA.
    Had to take the car to an exhaust shop to get the exhaust flanges welded to meet up with the header flanges (because cheap ebay crap headers ) But when I was running & driving the car dumping from the headers I noticed no irregularities in how it was running. Or maybe I just couldn't hear it since it was too loud. Either way, I didnt have my computer to check INPA after driving with the header dump, but when i started it for the first time with the header dump there was no new codes from before (though that is likely because computer hadn't seen anything wrong yet). After running & driving it with the header dump, it still didnt even get a CEL.
    After the exhaust was re-welded, I got a CEL and the motor was running choppy when I picked it up from the shop. I checked INPA and have the codes in the attached PDF. While looking at INPA more, I checked "rough" and it indicated cyl 1 burn quality as very far in the red. I replaced spark plugs & ignition coil, and no change. I looked around in INPA more, and found I could clear "adaption irregular running", and after that the motor ran weird, but better - and "rough" indicated that all cylinders were a little bit in the red (maybe just running rich?)
    test drove, and after a couple minutes at low speeds, all values in "rough" were in the green, and after a couple more minutes at higher speeds, cylinder 2 had a very high rough value (similar to cylinder 1 before i cleared irregular running). I have looked at all of the codes, but they are difficult to find clear answers as to what (in my situation) is causing them, and I am unsure which ones are actually causing the irregular running. (also note, code 227 and 228 the car has had since i bought it, and the car has ran completely fine with those codes, so it is unlikely those are the issue)
    Thank you to anyone who can help or has insight.
    code history \/
    e39m54errmem.pdf
    Jan 2014
    Buenos Aires, Argentina
    '97 523i5 - 99' 540iA
    Did you reset adaptations? Do you know If the exhaust shop disconnected the battery before welding? They could have f'd up your o2 sensors or maybe something is tangled (wiring harness wise)
    Diehard E39 driver.
    I'd rather die or take a walk before driving an E60 or any BMW made after Y2K.
    ​"Your momma's so ugly she makes Bangle cars look nice"
    Aug 2023
    United States
    2001 E39 530i
    I reset only irregular running adaptations, as well as lambda adaptations since I figured those were the most relevant. I could try resetting all though. And yes, the car actually had no battery even in it while it was at the shop. There is a chance something may be tangled, I did do a lot of twisting of the 02 sensor wires in order to get them screwed into the headers, and moved wiring around. Doubtful I did tangle wiring, but I will check today.
    Jan 2014
    Damn server ate a long answer
    Check the actual wiring between the sensors and the e-box, then monitor sensors using inpa or something that can see live data, if both things check up fine, you knight need a tune
    Diehard E39 driver.
    Aug 2023
    United States
    2001 E39 530i
    Update, car still doing same thing - followed some wiring and does not seem to be messed up.
    I reset all adaptations, after a couple minutes it straightened itself out and seemed ok. Drove it, all seemed well besides power dip at high revs (noticed in second gear). INPA was showing green for "rough". Was a short drive, only 5 or so minutes to get gas but nothing changed really. Got home, and the car had difficulty idling, with the same issues I had described before.
    Tried removing MAF as I read in the e46 forums that some people with similar issues could correct the issue by unplugging the MAF, no success just weirder running.
    INPA showed this for 02 sensor values, I am not sure exactly what all of this means but I am assuming that the values reading 99+ are the removed downstream 02 sensors?
    I am really very puzzled - not sure whats wrong but I feel it's something small that I am missing. Everything I am reading confirms that there should not be these issues with catless headers ( and secondary air check valve & downstream 02 sensor delete ).
    The old vacuum line that was on the secondary air check valve is vented to atmosphere (just not attached to anything) could that be an issue?
    Is there any other sensors or readings on INPA I should check?
    Thank you for the help btw lol
    Jan 2014
    Quote Originally Posted by CombatWombat View Post
    Yes! there's a port to be plugged in the back of the manifold, where the vac line that goes to a weird NR valve that looks like a miniature old style fuel filter and then to the secondary air valve (electronic solenoid, not the SAP valve that's bolted on the side of the head). That's quite a vac leak if you haven't plugged it.
    Also weird that the pre-cat probes are maxed out and not the post ones... and also, make sure you didn't mix up bank 1 and bank 2 sensors.
    Did you remove the post cat sensors alltogether?
    Diehard E39 driver.
    Aug 2023
    United States
    2001 E39 530i
    Haha, I am very inexperienced with these car things, so I apologize if any of this seems obvious - it is my first real "project" car.
    Just to make sure we are referring to the same things - We are both talking about the vacuum line that attaches to this right?:
    Attachment 724498
    I have been calling it the secondary air check valve this whole time in case I got it that wrong -_-
    And yes the post cat sensors are removed completely, they are not in the manifold & are unplugged at where they plugged into near the fuel rail. the video I was following and other peoples on the internet said they are unnecessary, as they only function to monitor cat health essentially, which is not necessary when switching to a no cats setup. or at least so i was told haha. the holes where they would be are plugged and sealed with copper crush washers
    Would you know how to confirm that the 02 sensors are in the correct manifold? I am fairly certain that they're in the correct ones, but I guess just to be thorough it couldn't hurt to check.
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    That’s not a check valve, it’s a on/off valve. The vac line that attaches to the barb goes to an electric valve that the DME turns on during cold start.
    You need to plug that vac line.
    Aug 2023
    United States
    2001 E39 530i
    will plug line tomorrow and update if issues persist
    thank you for assistance and bearing with me haha.
    Jan 2014
    All of the SAP systems I've seen have a vac line from the manifold, plugged to a check valve, that line goes to a solenoid that has wiring to be turned on/off and that's what actuates the control valve. I was merely describing that arrangement that if you delete, you need to plug the source of manifold vac....
    But if you're not understainding me maybe OP will not either. Just to disambiguate, marked with the red X it's all you deleted. You need to plug the fitting in the back of the manifold, where you removed that hose taht goes to the click valve, the on-off valve and the conttol valve of the secondary air system.
    Diehard E39 driver.
    Aug 2023
    United States
    2001 E39 530i
    AH - i see. you were saying manifold and I was thinking exhaust manifold, not intake. This is wicked helpful, I can not thank you more for taking the time to illustrate this out for my dumbass. Will do tomorrow and post an update.
    Aug 2023
    United States
    2001 E39 530i
    Update: Removed all vac hoses in illustration & plugged hole in intake manifold thoroughly. I did not remove the solenoid thing that the vac lines attach to because it was in a very difficult to get to position, and figured it would be fine to keep there temporarily while I tested (yes i unplugged the electrical plug as well).
    Started car, same things. Runs perfect, then loses a cylinder after a couple minutes. I was monitoring the "rough" values and it seemed fine at first, but then the values for all of the cylinders would rise and go into the red a little bit, and then one cylinder would go very far into the red, losing the cylinder, but causing all the other cylinders to stabilize in the green.
    I am going to remove the airbox and intake tubes and generally things in the area to check for vacuum leaks, though I feel that may not be causing the issue because I did not really tamper with anything in that area, and the car ran very well before.
    Im feeling pretty defeated haha, any ideas?
  1. Weird Running Issue, 318i need help please
    By jedan71 in forum 1991 - 1999 (E36)
    Last Post: 06-16-2011, 06:52 AM
  2. need help troubleshooting IPOD integration into e46
    By tommyboy in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 03-07-2006, 05:04 PM
  3. daytime running light problem...need help!!!
    By toyotahachiroku in forum 1991 - 1999 (E36)
    Last Post: 07-19-2005, 10:44 AM
  4. Need Help Troubleshooting...
    By DasAutokerl in forum 1991 - 1999 (E36)
    Last Post: 08-20-2004, 04:01 PM
  5. Need help troubleshooting tranny noise.
    By crazydeer43 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 09-09-2003, 02:44 PM
