Thread: "What did you do to your E39 today V2.0."
  1. #5901
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    Quote Originally Posted by gmak View Post
    Finished up basic undercarriage maintenance, neutralizing any small rust spots at weld seams and then covering with Por-15. Then I used rubberized asphalt to add another layer to what BMW already has there. Next I'm thinking of trying the ceramic coating again on the exhaust. I'll have to do a better job of cleaning it this time around since the ceramic paint became splotchy and didn't't take the last time around. This is on the 528i that I'm going to give to my daughter next year.
    I'd like to hear how you ceramic coated the headers.
    Quote Originally Posted by HoZy View Post
    What makes all of this worse, I'm in the middle of a custom facelift headlight build with Morimoto D2S4.0, lcm iv, RGBW angels etc & a Big brake kit.
    What big brake kit do you have in the works?
    Nate J.
    (oOO\ (|||)º(|||) /OOo)
    (eŌō\ (||||)º(||||) / ōŌe)
  2. #5902
    Jul 2016
    Chicago, Illinois
    are slow
    Guys with southern cars, check your spare tire compartment. Even if the battery tray is spotless, you might find something there.
    My car probably hasn't had a lead acid battery since 2010 but those 8 years were enough for surface rust buildup. I just put in a Group 65 and risk a buildup of semi-corrosive explosive gas, oh well.
  3. #5903
    Jul 2013
    Ontario, Canada
    1998 528i; 2000 540i;
    Computinateor:
    I didn't ceramic coat the headers. I used ceramic pain (VHT, IIRC) from the flange down to the muffler / scuba tank. Ceramic coating of the headers should include the inside or it just leads to the same problems of metal deterioration beneath the surface - or so I've been told
    gmak: The Good, the Bad, and the Ugly. A journey with my new-to-me 2000 540i
    "Working on a BMW E39 is the best way to run out of time."
  4. #5904
    Oregon/Ukraine
    E39 M-Sport F30 M-Sport
    Quote Originally Posted by dannyzabolotny View Post
    Did it go to a forum member?
    Unfortunately not.
    E39 WhatsApp Chat Gruppe
  5. #5905
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    Computinateor:
    Ah, gotcha. Was there a noticeable drop in exterior temperature with the paint? I'd like to reduce under hood temps (to preserve ABS lines and help radiator efficiency); is ceramic paint effective at this, or should I pursue header coatings?
    Nate J.
  6. #5906
    Sep 2016
    Edmonton AB
    E39 00 528
    Vanos seals from Beisan on M52TU finished just as the mosquitos were getting thirsty!
  7. #5907
    Middle of a corn field
    E39 hamster/ruberbandPWR
    Quote Originally Posted by RuskiE39 View Post
    Sold the 530 today sad day, but now I have extra funds for guides and other things for the 540
  8. #5908
    Lawrenceville, GA
    4 BMWs.
    Yesterday, I swapped out the busted-in-six-places center console in the M5.
    2001 Z3 3.0i -Oxford Green/Sandbeige
    2016 428xi -Estoril Blue II/Black
    2018 430iC- Estoril Blue II/Black
    2018 330it - Melbourne Red/Venetian Beige/Black
  9. #5909
    NW suburban Chicago
    hiss by my window
    Struggled mightily with the front strut pinch bolt, well corroded in it's aluminum home. Slathered it well with anti-seize paste on re-assembly for next time.
    Why couldn't the Germans have done this?
  10. #5910
    Mar 2005
    Bel Air, Maryland
    E39 M5, 525..e34 525 x3
    New shiny parts for the 530's cooling system, Stewart water pump, Behr radiator, Mahle thermostat, BMW power steering reservoir, assorted hoses, belts and clamps and an oil change, air filter and cabin filters.
    ( e34)
    '91 525i calypso/parchment (Big Red)
    '92 525i calypso/parchment ( parts)
    '95 525i alpenweiss/parchment, 5spd( parts)
    ( e39)
    '01 530i Msport susp. anthracite/gray
    '02 525i Msport susp. jet black/sand
    '02 M5 jet black/blk-silverstone
    (e53)
    '06 X5 alpenweiss/truffle brown
  11. #5911
    Jan 2015
    Tempe, AZ
    1995 525i/5
    I'm sure living in Chicago has something to do with it... swapping the struts on my California/Arizona 540it was a breeze, everything came apart with just a ratchet, no breaker bars or pry bars needed.
    1995 525i 5-speed - Thread
  12. #5912
    Feb 2010
    Slovenia
    are rusting away
    Turbo charge pipe burst open. Nicht gut.
    Duct tape didn't last long.
    A couple of days and two trips(because the internet lied about the hose size, shockingly) to a local hydraulics shop that had three ply silicone hoses in stock, got it fixed.
    Bam, instant 25 HP.
    Live slow, die whenever
  13. #5913
    Oregon/Ukraine
    Getting ready to pull the trigger on an early birthday present m5 front bumper for myself. Anyone have any seller recommendations? I'm pretty sure they all fit the same anyways, huh...
  14. #5914
    Jan 2015
    Tempe, AZ
    1995 525i/5
    Try to find a used OEM one from a partout or something, the replicas never fit right (as I'm sure you know from your experiences with the 530i).
  15. #5915
    Feb 2016
    Destin, FL
    W220 S55 AMG, E39 540i6
    Yea. I don't think there's any difference between the umnitza or ddm ones compared to the eBay ones. May be worth it to get a CCA discount and go OEM
    Chris
    04 Mercedes S55 AMG
    97 BMW 540i6
  16. #5916
    Jan 2014
    Pennsylvania
    97 528i+03 540i m-sport
    Quote Originally Posted by DustenA View Post
    I don't want to admit I was wrong to my wife and sell it lol.
    Quote Originally Posted by StRaNgEdAyS View Post
    Good man!
    My partner tells me mine is a money pit all the time lol...
    I tell her it'll either this, or a motorcycle, or an aircraft.
    At least she's a bit of a petrol head too, so she can appreciate it.
    Absinthe makes the tart grow fonder
    Hear it everyday.
    -Xteve
  17. #5917
    Jan 2015
    Tempe, AZ
    1995 525i/5
    My girlfriend doesn't complain about my cars because ultimately my expenses for several BMWs is still lower than 6 years of a constant monthly payment on a $20k+ car. Plus with an old car I can run the cheapest liability insurance which decreases costs even further. We ran the numbers back when I had my Range Rover and deduced that I could daily drive the Range Rover for many years and it would still be cheaper (and nicer to drive) than our brand new Hyundai that we're still paying off.
  18. #5918
    Lawrenceville, GA
    4 BMWs.
    You've got a point there! Luckily for us, we're fortunate to have all of our vehicles paid for at the moment. So Now it's just maintenance (The 3 newest still have factory warranty!)
  19. #5919
    Jul 2013
    Worcester, MA
    03 540i Msport Touring
    our brand new Hyundai.
    i am so very, very sorry
    hyundai has been improving but they have a very long way to go
    Looking for an e39 Touring black carpet set, including the rear cargo cubbies and side sections!
    ALSO looking for 540i 6speed manual transmission sets (2001+ pedals with switches, driveshaft, gearbox), for the 6speed swap! Probably not for a while....
    GN92489
    540i msport touring; jet black on grey
    Progress Thread (general)
    Progress thread (touring specific)
  20. #5920
    Feb 2014
    Caboolture, Q, Australia
    E39 535i
    Quote Originally Posted by amancuso View Post
    I'm fortunate that I don't have any personal debt.... Not even a credit card
  21. #5921
    Mar 2017
    Lake Goodwin, Wa
    1997 540I 6 speed
    Mine isn't complaining about cost. I own 9 cars, 5 ate nothing more than toys that see less than 2000 miles a year. She complains that I bought this car for my commute sweating it'd be reliable(previous owner screwed me good) and it's not. That's why she's pissed.
    Quote Originally Posted by joekitch View Post
    Weird. I have 70k on a 2015 hyundai sonata sport with zero issues. Routine maintenance and rear brakes. Nothing more. It's daily driven 120 miles a day.
    2001 Ford Lightning - Built Motor - Built Trans - 2.3 KB - Custom Interior - 537/632 - 11.40 @ 119.6 - Garage Queen
    2008 F-250 - Tune/Delete/Studs - Lifted - BroDozer
    1994 Cobra #2277 of 5009
    1993 Gen 1 Lightning #5194
    1968 Ford Mustang "Gold Nugget Special"
    2015 Chevrolet Tahoe LTZ
    2015 Hyundai Sonota Sport
    1997 BMW 540i
    My Youtube
  22. #5922
    Mar 2017
    Lake Goodwin, Wa
    1997 540I 6 speed
    I washed it today. I also pulled the passenger door panel investigating why my auto up doesn't work. Turns out the strip at the top is faulty. I also replaced some broken clips.
    1997 BMW 540i
    My Youtube
  23. #5923
    Lawrenceville, GA
    4 BMWs.
    Same here! Best way to live!
  24. #5924
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    I read somewhere that if you have no debt and $10 in your pocket, you're richer than 25% of America. Kinda scary.
    Nate J.
  25. #5925
    Jan 2015
    Tempe, AZ
    1995 525i/5
    It's a 2013 Elantra GT, so it's not the worst. I mean, it's totally gutless and the transmission is determined to suck all the fun out of driving it, but it's reasonably comfortable, has a decent sound system, and is dead reliable. It's basically my girlfriend's car at this point.
    Nice! I wish I would have been smarter about credit cards when I first got them... I went a little nuts and now I have two credit cards with rather high balances that I'm paying off bit by bit. I also used a personal loan to buy my first decent E39 for $6k, so that's still being paid off as well.
    If I had to do it all over again I'd just be more patient and save up the cash for an E39 instead of getting a loan for it, but I was 22 and quickly needed a second car when my girlfriend got a job that made sharing one car impossible. Oh well. On the bright side, I should be free of all debts within a year or two, as long as I avoid using credit cards and whatnot.
    Ah, I see. It's rather unfortunate that the previous owner of your E39 was so dishonest about it, I hate people like that. I've been daily driving an E39 for a while now with almost no issues, even though I usually buy them with pretty high mileage (I'm at 190k now on the 540it and my previous 540i/6 had nearly 200k). I've had to replace a radiator and overhaul the suspension but neither of those prevented me from getting to work. In fact, I haven't missed a single day of work in over 2 years because of driving supposedly "unreliable" German cars.
Page 237 of 672 FirstFirst ... 137187212227228229230231232233234235236237238239240241242243244245246247262287337 ... LastLast
