Serious dough then! (Some rep tid bits are the aspherical line and a very mild black boarder around the glass) OEMs in the US usually had dimming which had a slightly protruding / thick lens boarder.
2003 BMW 540i [Sterling Gray / Gray]
[Msport] [Mods from A-Z] [Two-Tone Interior]
Stuff For Sale :
All types of E39 OEM Used HVAC Buttons
Other E39 Parts, see my ebay! [Click]
I’m 99% sure they’re knock offs but will definitely post pics of my mirror rebuild.
Got the other side done. Waiting for it to dry on the tailgate and rear bumper now.
Found my rear carpets were wet after a wash, I swear about every month this car likes to chip away at my bank account. Starting to get tired of the constant failure left and right.
Quick & easy, do it right and the issues on both rear doors will NOT come back in your ownership.
Current Garage Highlights
2003 525iT TiSilver
2002 M5 TiSilver
Former Garage Highlights
2005 X5 4.8is
2004 325iTs (2x)
1973 Pantera L
1969 Road Runner 383
I have a new pair on order for both rears. It's not that it's difficult to maintain these cars, it's just the annoying little things that get to ya sometimes. Especially if their back to back constantly.
Nate J.
(oOO\ (|||)º(|||) /OOo)
(eŌō\ (||||)º(||||) / ōŌe)
I pulled Mine apart to look at the shades. Everything was a little beat up. I had to use some JB Weld to reform part of the card. The PO had done a crappy job trying to fix the shades. I just pulled the shades out but restructure part of the hardware as they are part of rigidity to the door card. Wasn't too bad once I figured it out.
After timing chain guide job is done and crank no start issue is fixed, I brought the car for state inspection, I just replaced front passenger side sway bar link due to the ball joint booth was torn and thought all suspension components are tight, well, the car passed emission but failed safety inspection, ball joints failed on front passenger side lower control arm (curved one) and both rear upper forward control arm links, all those failed components were replaced 2.5 years ago, anyhow, need to replace them again. PA has very strict vehicle emission and safety inspection so any suspension components, wheels, brakes, lights, wipers, windshield spray nozzles could cause the inspection to fail.
Oil change!
I do not believe in a risk free society where the thrill of living is traded for the safety of existence. Nick Ienatsch
The law does NOT determine "right" from "wrong". They are unrelated.
If you put cheap parts on your car, you will soon have a cheap parts car.
Last night after I changed my oil, I hooked the shop scanner up to the car, my key’s range was getting weak, thought like it was the battery getting week or something. So I went to coding, re-codex the EWS, and re-aligned the DME with it, now my range is good again, just like new. So that’s cool and all, but why did that happen at all? Not too keen on the coding bit. I wasn’t using INPA, or the other usual software that everyone uses, I was using an Autel scanner that our shop has. My SnapOn SOLUS is on the fritz so I have not been able to use that for a little while. I was surprised to see that the shop scanner had coding ability.
2003 525iT TiSilver
2002 M5 TiSilver
2005 X5 4.8is
2004 325iTs (2x)
1973 Pantera L
Yeah and I definitely relate. Have on my list: folding mirror repair, drivers side regulator has a screw loose so it rattles and scratches the glass, so I’m going to R/R the door and swap out the window.... and passenger front vapor barrier likely needs some attention.
Nate J.
Valve cover gasket and spark plugs done! Headliner is next up over the holidays.
2002 M5 Sterling Gray (88k)
Dinan mufflers and intake, ZHP shift knob, E60 shifter, Ground Control coilovers
Restoration in progress!
2021 M340i (25k)
Sold!
2003 540i MSport 6sp Tit Silver (193k)
Dinan Exhaust, Autosolutions SSK, 88C Thermostat, Koni's, BlueBus, BavSound, DUDMD Stage 2, AFE CAI
Sold!
Aavi's 98 M3/4/5 Cosmos (137k)
TMS Stage 3 with Shrick cams, Shorty headers and tune, M50, Stromung, 8.5 LTW's squared, PFC-Z, 3.38, Bosch H1's with city lights, CD43, BSW Stage 1, BMS SSK, TMS Underdrive Pulleys, Sunroof Eclipse, LeatherZ gauge pack
BMW CCA# 308494
I don't think they are knockoffs, I did the rest of the suspension with their parts and that's holding up fine. It just seems that Lemforder has issues specifically with these bushings as there are many people who reported the same failure after few thousand miles. There's a thread on M5board.
You'll like get the same parts but I'm curious. Post some pics when you get them. Someone mentioned to use X5 bushings pressed into Lemforder arms.
I ordered TRW control arms now, I have them on my E38 and E31 so we'll see how long they last. Not looking forward to doing this again and alignment after.
Sent from my SM-G965F using Tapatalk
Here's mine.
Idiots.... you would think that they would be stringent on quality control, dubbing the work out to China. Monoball time on my next suspension bits.
