Results 1 to 8 of 8
Thread: problem when try coding
    Nov 2014
    Thailand
    1994 bmw e36 325i
    Question problem when try coding
    I have install m3 us cluster in my 93 325i m50b25 non EWS
    I want to change odometer from mile to km.
    I try 3 program but it fail
    gt1/dis vmware v44
    -dis woek perfect can coding but when I try programing I got "VIN and ZCS/FA cannot read out from EWS/KMB/LSZ control unit!"
    sss progman v32 Got it. progman not work with ads interface
    -I'm stuck at "The vehicle order/central encoding key (FA/ZCS) is being determined"
    ncs expert
    -run expert mode
    -reading kmb (instument cluster) module
    -try to edit FSW_PSW.MAN file in ncs dummy
    -edit and export to FSW_PSW.MAN and change job to SG_CODIEREN and execute job with no error.
    -but my odometer still in mile
    -I reading kmb module again and try to edit FSW_PSW.MAN with notepad
    -I got problem it should have WEGSTRECKE_EINHEIT but not have
    I'm use tiny ads interface with real serial port laptop in windows xp
    Can someone help me
    Thank for advance.
    sorry for my english.
    update
    my current vin is incorrect
    Do I need to change my vin?
    Attached Files Attached Files
    Feb 2014
    O.C. Oregon
    E36-E367-E39-E53
    Weird.
    Can you post the kombi file?
    ​~Mike
    Nov 2014
    Thailand
    1994 bmw e36 325i
    This is FSW_PSW.TRC when I read from kmb module
    I think my vin number is not correct
    Nov 2014
    Thailand
    1994 bmw e36 325i
    First I'm open ncsexpert and select REVTOR profile
    2 click VIN/ZCS/FA
    3 click ZCS/FA f.ECU
    4 choose e36
    5 choose KMB (CKMB,EWS not respond)
    6 click back
    7 select KMB(instument cluster)
    8 popup cbd name KMB_E36.C27
    9 change job to CODIERDATEN_LESEN
    10 click execute job
    11 open ncs dummy select chassis e36 load FSW_PSW.TRC and select module KMB_E36.C27 (another module EX KMB_E36.C25 .0 .1 can't edit and got error )
    12 distance unit has uncheck?
    13 I have try to edit in FSW_PSW.TRC and not found distance unit
    14 I'm looking in profile edit
    15 I'm check distance unit to km in ncs dummy and export and verify in FSW_PSW.TRC with notepad
    16 re open ncs expert and change job to SG_CODIEREN
    17 execute job and look at my cluster is writing
    18 but when complete is still in mile
    If I do somthing wrong please tell me.
    Nov 2014
    Thailand
    1994 bmw e36 325i
    my real vin is ZBTCB45080AA46103
    but in m3 combi is WBAAA00000AA46103T
    what is T mean?
    under my hood my vin is +AA46103+
    Should I need to change my vin first before coding?
    thank for advance.
    Nov 2014
    Thailand
    1994 bmw e36 325i
    CODIERUNG_ERFOLGT
    codierung_erfolgt
    CODE_NR_2
    wert_01
    CODE_NR_3
    wert_01
    SIA_AUS_VERZOEG
    wert_01
    SIA_TEMP_FAKTOR
    wert_01
    DZM_FAKTOR
    wert_01
    LICHT_EINSCHALT_DAUER
    wert_01
    WARNUNG_GESCHW_AUS_ZEIT
    wert_01
    LICHTWARNUNG_AUS_ZEIT
    wert_01
    LICHTWARNUNG_EIN_ZEIT
    wert_01
    DATA_VALID
    datensatz_gueltig
    TANKGEBER
    hebelgeber
    GETRIEBE
    automatik
    K_ZAHL_WEG
    4663_imp/km
    K_ZAHL_WEG_KOMPL
    4663_imp/km
    STEIGUNG_EINSPRITZ_KENNL
    m52b28
    MOTOR_FAKTOR
    3_imp/umdrehung
    CODE_NR_1
    nicht_aktiv
    CODE_NR_4
    wert_01
    CODE_NR_5
    wert_01
    GURTWARNUNG
    aktiv
    GURTWARNUNG_GONG
    aktiv
    LAENDERVARIANTE
    ece
    TANK_KENNLINIE
    kennlinie_01
    TANK_DAEMPFUNG
    kennlinie_01
    OELTEMP_GAS
    oel_temp
    TANK_GAS_KENNLINIE
    nicht_aktiv
    TANK_GAS_KENNLINIE_WINKEL
    nicht_aktiv
    SIA_GRENZE_INSPEKTION
    30.000_km
    SIA_GRENZDREHZAHL
    4512_u/min
    LICHT_EINSCHALT_VERZOEGER
    wert_02
    SIA_GRENZE_ZEIT
    0_tage
    SIA_ANZEIGEPARAMETER
    ohne_zeitinspektion
    OELSERVICE_ANZAHL
    2_service
    GURTWARNUNG_AUS_ZEIT
    wert_02
    GURTWARNUNG_EIN_ZEIT
    wert_02
    WARNUNG_GESCHW_LIMIT
    nicht_aktiv
    WARNUNG_GESCHW_EIN_ZEIT
    wert_02
    ZUENDSCHL_WARN_AUS_ZEIT
    wert_02
    ZUENDSCHL_WARN_EIN_ZEIT
    wert_02
    BC_CODE_AKTIV
    aktiv
    TANK_SCHALTPUNKT_1
    wert_01
    TANK_SCHALTPUNKT_2
    wert_01
    TEMPERATUR_KENNLINIE
    kennlinie_02
    SCHWELLE_UEBERDREHZAHL
    8000_u/min
    May 2009
    Netherlands
    E21 325i,E30 323i
    Have you ever solved the issue?
    I'm having the same problem but with engine mode. Car is 318i and has now M62B44 in it. Need to set impulses per stroke from 2 to 4. Coding goes fine (KOMBI says EEP1 / EEP2) seems that it is written but once read again it fails.... (still same).
    May 2009
    Lithuania
    E38 750i FL & E36 M3 4DR
    Bump up the thread. I am in the same boat as mintth
    Is there a solution how to chaneg mileage from miles to kilometers in E36 M3 Instrument Cluster?
