Bavarian Soundwerks
Results 1 to 4 of 4
Thread: 2008 BMW 630i NBT iDrive Professional retrofit
    Jul 2012
    Dublin/Ireland
    With wheels
    The car, 2008 630i convertible
    Upgrade from CCC to 2014 NBT iDrive from BMW F30 (3 series)
    Much faster radio, has a dual core 1.3 GHZ cpu, a NVIDIA graphics card, 1 GB memory and a 200 GB hard drive.
    Steering wheel buttons are still working, you also get the check control messages from the car.
    Also allows you to stream audio from your phone, play movies from a USB stick or even from your phone. Also comes with voice command which is pretty sweet.
    Nice interior color combo
    Car has the CCC iDrive Professional, but no bluetooth.
    And the work begins
    Installing a brand new mic in there along with new wiring
    New DAB radio antenna
    Work in progress, routing cables and , included network plug for coding if required later, so no need to take the radio out.
    Updating the navigation part with the latest maps, on the table, so I don't need to start and run the engine for 45mn
    A bit more wiring and few more plugs getting tied up
    New HD screen in place
    NBT all connected up in the car now. Starting it for the first time. Sweet upgrade.
    Now the most difficult part. Find a solution to fit the iDrive controller. The old one is way too wide. So I tried to find a solution that would look good and not out of place.
    Removal of the central console
    Old idrive controller frame out. Trying to figure out if I could reuse it or not. Turned out to be a flop...
    Ok forget about reusing the old idrive frame, let start cutting the excess of trim in there, so at least I can fit the new controller and see what I can do with it.
    USB socket in place
    Ok I decided to make my own custom trim to actually cover the new controller.
    Before hot gluing. So far so good.
    Now how to make that new controller to hold in there...Ok I took a part the old one and kept the frame. I reattached the frame to the console, and actually the new controller fits just fine with double side tape.
    There you go, all done
    BMW OSS Master - BMW Coding, flashing, and NBT/CIC retrofits for breakfast.
    Founder of BMW Planet, serving wiring diagrams to BMW enthusiasts and independent garages all over the world since 2008
    Jan 2014
    Amazing!
    @BMWPlanetDude
    You are amazing for sharing this tutorial with us. Thank you so much! How long did it take you for the whole installation?
    BimmerRetrofit is telling me I need the following additional parts to do the NBT EVO retrofit:
    1. CIC Front Panel,
    2. LCI Climate Control Panel (I have the same as yours)
    3. CIC FacePlate.
    But I am not showing that you used that because your dashboard looks like mine. Can you confirm?
    Also and in hindsight, what do you think is the best way to fit the Controller? Do you just have to the top, or is there plastic underneath too that needs trimming? Is removal of the Center Trim required?
    Thank you for your help.
    Ced.
    Sep 2008
    West London/Heathrow - UK
    03 530dT - Ex Police Car
    Hi Ced,
    This member/person is banned from this forum again so most likely you'll not get any help or response from him. I'd suggest looking for a more reputable and professional specialist to help with this project.
    Where are you based? depending on where you are and various versions of the NBT unit etc you might have different things to try.
    On this thread, he was active and due to some 'issues' again, a few months ago he was banned but other members are very knowledgeable and could help potentially - https://www.bimmerforums.com/forum/s...in-E39-E38-E53
    Cheers, Dennis!
    Jan 2014
    [QUOTE=DennisCooper;29748863]Hi Dennis,
    Much appreciated, thank you for the heads-up!
    Ced.
