Page 2 of 11 FirstFirst 1234567891011 LastLast
Results 26 to 50 of 272
Thread: M70 Rebuild Thread.
  1. #26
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    Quote Originally Posted by NevadaMike View Post
    Have you considered CO2 (Dry Ice) blasting? You should be able to find a place in the Bay Area. I've also found that regular old paint thinner (not lacquer thinner) does a pretty good job dissolving that carbon. Be sure to get the deodorized kind, you'll thank me.
    Ordered gasket remover, alot of guys use it to melt off carbon...
    Quote Originally Posted by fursideup View Post
    That will be fun! I better clean off the pool table so you have a place to lay all those pistons, caps and bearings out.
    Thinking about it.. Don't want to go overboard with this rebuild, probably would make sense to open one up and take a look at the main bearings...
    Wolf has a point on taking the pistons out to soak them outside the block.
  2. #27
    Aug 2013
    vacavillle,ca
    8 - 850i (2 -6 speeds)
    Quote Originally Posted by bmw528e11 View Post
    When you planning to do that? I might swing by on Saturday morning?
    It wont be this Saturday - I will let you know Dimitri
    84 E31 cylinders - 72 Running
  3. #28
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    I think myself and Jon are busy this weekend, I will text you when we get ready to do it.
    Time is always the big issue...
  4. #29
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Quote Originally Posted by wokke View Post
    And yes Tim, the bolts are stretch bolts and I highly recommend to use quality bolts and not some super cheap "on sale" crap.
    Thanks Wolf, the reason I asked was due to the discussion on using studs - where stretch bolts are used you can't just swap over to studs as the correct compression of the head gasket relies on the stretch of the head bolts.......
    My BMW Repair YouTube Channel
  5. #30
    Regina SK. Canada
    1991 850i / 6
    Quote Originally Posted by B10 BITURBO View Post
    I really recommend using studs,, thats my opinion,, it is an aluminum block,, i think can get studs that are almost the same dimension,, 10x110 is oem bolts
    here is a comparison,,,
    http://www.summitracing.com/int/part...0-1b/overview/
    The use of studs is a very wise suggestion. In racing where engines are taken down more frequently, studs are used almost exclusively. A much safer and more secure way to attach cylinder heads, and will prevent metal fatigue in the aluminum block. If you are a strong believer in overkill, then ARPs chrome moly connecting rod bolts are worth considering as well. Don't you think Timm, if you torque the head bolts (or studs) by slow degrees in correct sequence,
    the gaskets will be compressed correctly? What do you think Wolf?
  6. #31
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    Quote Originally Posted by garylafortuna View Post
    Why fix something that's not broken, this is the first time I heard someone saying the threads gave up on an M70 block, actually it was M73. Wolf did say he did 10 engines and NONE had a problem with threads giving up, several had broken head bolts, but those were original bolts I believe. Plus ARP studs are $10 bucks EA. That's $280 just for the bolts. My Victor Reinz head bolts were only $48.
  7. #32
    Sep 2008
    Santa Barbara
    91 Dinan860 & 91 850 6sp
    Do what Wolf says above and pull the pistons. At this point, you ought to pull everything and have the block hot tanked - that's the best way to clean everything off.
    Also make damned sure you keep track of exactly where everything came from and in which direction
    Forget about head studs, make sure your threads are clean and there is nothing in the holes - then use quality bolts.
  8. #33
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    Head gaskets and head bolts just arrived.
  9. #34
    May 2013
    Salinas CA.
    1993 BMW 850CI
    Quote Originally Posted by dragon850 View Post
    Great, Now just don't get in a hurry, and as Cartoonz said keep meticulous track of everything, especially cam followers.
  10. #35
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    Quote Originally Posted by Mikekugel View Post
    Will do... I thought rocker arms are interchangeable, same design?
  11. #36
    Duesseldorf, NRW, Germany
    '90 850iM70B54, '91 850i
    I will remove Cylinders for soaking and look at the bearings.
    Better remove the pistons. If you remove the cylinders the block is destroyed.
    BTW, have you ever considered taking the chance for a M73 upgrade? Used M73 should be dirt cheap in the US and it's really worth it.
    All you actually need is the M73 block incl. it's internals. You can even keep your M70 heads and probably end up at about 340HP due to the slightly hooter cam shafts of the M70.
    And if you go for Schrick cams and a customized engine mapping CSi power is possible.
  12. #37
    Jun 2014
    Blue Springs MO
    M70 6sp. 540iT, 535is
    Unfortunately Dragon850 already bought an M70 (i think)..
    $700 in LA and $660 in Texas..
    Wokke, just M73 block with internals, but keeping the exterior parts from M70? what about pcv system, valve covers, and intakes? and what you meant about 'slightly hooter cams'?
  13. #38
    everything from the headgasket upwards can be used from the M70. And some bits and pieces HAVE to be used from the M70 like timing chain cover and flywheel.
    M70B54 picture thread (lots of pictures)
    Cam data comparison
  14. #39
    Iceland
    BMW 850
    everything from the headgasket upwards can be used from the M70. And some bits and pieces HAVE to be used from the M70 like timing chain cover and flywheel. M70B54 picture thread (lots of pictures)
    Cam data comparison
    Wolf. Dragon has a supercharger so I guess a m70 is better
  15. #40
    Quote Originally Posted by Fatandre View Post
    Oops, I didn't realitze that. I fully agree, M70 is the way to go for FI.
  16. #41
    Sep 2008
    Santa Barbara
    I'm all for anything "slightly hooter"....
  17. #42
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    Got almost everything parts wise, now where do I find time to install all of this?!
  18. #43
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    Heads are off to the local machine shop for cleaning, resurfacing, valve job, new valve guides and seals.
  19. #44
    Rigel 7
    M3, 850i, E30T, E55T
    Subscribed.
  20. #45
    May 2010
    Brentwood, NY
    BMW 850
    I am planning to tackle the same project. Should be good experience. I will also be ready if my supercharger stresses my motor. I will follow your thread.
  21. #46
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    Rockers, basis and hydraulic lifters after ultrasonic cleaning. The lifters will not be reused, I purchased a whole new set. One of the rockers has a wavy pattern on it and will be replaced.
    Heads are still in the shop.
  22. #47
    Jun 2014
    Blue Springs MO
    Dragon, Any updates? whats the forecast of your 8 running?
  23. #48
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    Heading out to the machine shop to pick up my reworked heads!
    Will update with pics!
  24. #49
    Jun 2008
    SF Bay Area
    Supercharged 850ci
  25. #50
    The OC, CA
    95 840Ci
    For us looking to do something like this for our hybrids rebuild, what does something like this cost? Ball park is fine.
    Current
    95 e31 840 Ci (Auto) Orient Blue 61k
    11 e90 328i Space Gray
    18 F15 X5 35i XDrive White
    Past
    00 e38 740 i (Auto) Titanium Silver
    94 e31 840 Ci (6 speed conv.) Avus Blau (This car was Awesome!)
    03 e46 325 Ci (Auto) Jet Black
    91 e31 850i (Auto) Diamond Black, Yes, two!
    00 e39 528i (Auto) Jet Black
    92 e36 325i (Auto) Laguna Green
