Results 1 to 18 of 18
Thread: FS: CES Stage II Turbo Tune OBD2
    busterhax's Avatar
    busterhax is offline Y̝͎̘̍́ͣ̉͑̿̆Ō͎̼̺̬̒ͯ̃̇͗̂ U͈̖
    Jun 2006
    NYC
    e36
    See link below for description of the Stage II kit.
    Tune is for:
    Bosch 42 lb injectors
    803 MAF
    9:1 compression (unsure if this matters?)
    stock s52 internals
    running at 14-15 PSI
    EWS deleted.
    Sold
    "Active Auto GT-R Stage 2 CES Turbo Tune Package (Stock ECU), Draw Thru Air Mass Meter, extended HFM harness. PRICE OBD2 $1600.00"
    http://www.cesmotorsport.com/documents/126.html
    Dec 2012
    Gig Harbor wa
    1996 328i
    Is this just for the tune? Or does this include a maf and or injectors?
    soon to be.....
    1996 328i
    built motor:
    Molnar rods
    wiseco 8.5:1 pistons
    main bearings
    rod bearings
    all new gaskets etc
    .070 cometic head gasket
    s52 cams
    supertech dual valve springs
    60# injector technica tune
    pt6266 84 ar t4 flange
    26x12x3 intercooler
    2.5" hot side and 3" cold side piping
    tial 44mm wastegate
    obx top mount
    3" straight pipe
    busterhax's Avatar
    Jun 2006
    NYC
    e36
    Quote Originally Posted by ziptied View Post
    Just the ecu.
    Dec 2012
    Gig Harbor wa
    1996 328i
    Quote Originally Posted by busterhax View Post
    Just the ecu. I do have the maf that goes with it that I can include for $100 with purchase of the ecu.
    Okay thanks, I have a buddy that might be interested
    soon to be.....
    1996 328i
    built motor:
    Molnar rods
    main bearings
    rod bearings
    all new gaskets etc
    s52 cams
    26x12x3 intercooler
    tial 44mm wastegate
    obx top mount
    3" straight pipe
    busterhax's Avatar
    Jun 2006
    NYC
    e36
    Bump. Make offer. Want this gone.
    Manchester, N.H.
    96 332IS 6466 turbo
    This a active tune ? Draw through obd2 ?
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
    busterhax's Avatar
    Jun 2006
    NYC
    e36
    Yes. Active sticker plastered on the housing and the chip.
    It came with a used CES stage 2 kit I purchased previously owned by turnerncm3.
    Dec 2015
    Island Lake, Il
    1994 BMW 318is M52 swap
    Do you know if this would be compatible with m52?
    busterhax's Avatar
    Jun 2006
    NYC
    e36
    Quote Originally Posted by arktisgraue36 View Post
    No. S52 only.
    busterhax's Avatar
    Jun 2006
    NYC
    e36
    bump obo
    Mar 2013
    Upstate NY
    M3
    Would a s257sxe work with this? Same Lb/min and compressor wheel size.
    busterhax's Avatar
    Jun 2006
    NYC
    e36
    Quote Originally Posted by Mklock View Post
    I don't see why not.
    Louisville, KY
    turbo m3
    it's a MAF based tune so it should work fine.
    Eventually it will run out of fuel and/or spool up could be rich or lean slightly.
    This is my signature....
    busterhax's Avatar
    Jun 2006
    NYC
    e36
    bump obo
    Jul 2020
    arizona
    1987 325e s52 swap
    Old post but is this tune for 42lbs 803 maf injectors still available?
    Tune is for:
    803 MAF
    stock s52 internals
    EWS deleted.
    Asking $300 shipped OBO
    Is still available?
    Jul 2020
    arizona
    1987 325e s52 swap
    E30 s52 swap obd2
    bump obo
    I need this lol
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    It’s only been 4 years since the seller last bumped the thread.
    Jul 2020
    South California
    '98 E39
    Quote Originally Posted by Bmwbe$t View Post
    I need this lol
    This post has two meanings! + necropost markup.
    Chuckles/10
