Page 25 of 33 FirstFirst ... 15161718192021222324252627282930313233 LastLast
Results 601 to 625 of 821
Thread: the grip missile. chronicling the sadventures of a neglected M3
  1. #601
    Jan 2005
    Wilkesboro, NC
    95 M3, 86 325
    Quote Originally Posted by Zed Sump View Post
    This car is the business. My buddy JZ got a quick vid at the resort.
    https://www.instagram.com/p/BSrlaiMAS0Q/?taken-by=jz173
    I just came back in here for this...
    Glad you managed to have your rim repaired OP
  2. #602
    May 2014
    Noblesville, IN
    98 328i, 79 911SC
    that cold on saturday turned into full blown ebola before Monday.
    i was back at work on wednesday because we midwesterners don't miss work unless it's absolutely necessary.
    feeling mostly better today. just coughing up the last of the junk in my lungs from the retreating plague.
    job2 tonight and tomorrow and my yard hasn't been mowed in two weeks. so i may get some work done on the m3 sunday. if not sunday, it'll be next week. i have to swap the coilovers on my 328 for a new set as mine are junk and being warrantied. then, both cars need oil changes and the m3 needs more revisions to optimize its setup.
    that's all for now.
    always trying to make it lighter and faster
    ^^former build: http://www.bimmerforums.com/forum/sh...-neglected-M3/
    current build: http://forums.pelicanparts.com/porsc...car-build.html
    instant grams: doktor_b
  3. #603
    May 2014
    Noblesville, IN
    98 328i, 79 911SC
    Opinion poll.
    Leave the felony form overs and add aero and more tire?
    or
    Switch to the pandem wide body, change wheels, and add more tire?
  4. #604
    DeWitt, Michigan
    '97 540i/6, '97 328i
  5. #605
    May 2014
    Noblesville, IN
    98 328i, 79 911SC
    I think the Pandem kit just looks a lot more finished.
    granted, it'll cost an arm and a leg. And it'll require actual body work to make it all look correct. But the m3 needs some actual paint and body work to bring it up to snuff. I've neglected the body a bunch because it was in bad shape when I got it. A new kit would inspire me to actually give a hoot about how it looks.
    plus I'd go back to 17s. Cheaper tires aren't a bad thing.
  6. #606
    Jul 2013
    Tacoma, WA
    E36 M3 turbo, E90 M3 ZCP
    Quote Originally Posted by doktor b View Post
    Opinion poll.
    or
    I love the look of your current setup, I think the wheels are perfect. Normally I would say go back to 17's but I think your car looks amazing as is. How wide of tires are you trying to go?
    That being said, if you do go with the pandem, I will gladly buy the FF overs
    1995 M3 coupe GTX3582R powered
    2011 M3 sedan ZCP
  7. #607
    Florida and ATL
    1999 M3 and 1990 Jetta G
    I'd keep felony form and add more tire. If you want a 'show-ey' car then Pandem will get you that attention, since it's a rocketbunny spin-off and that's all the rage on the scene points.
  8. #608
    Aug 2013
    1999 BMW M3 Coupe
    Don't care, as long as you're not running -5+ degree stancebro camber in back like in that pic.
  9. #609
    DeWitt, Michigan
    Quote Originally Posted by TostitoBandito View Post
    . . . as long as you're not running -5+ degree stancebro camber in back like in that pic.
    THAT is a very good point!
  10. #610
    Sep 2002
    Vancouver
    98 M3
    I think the Pandem kit is the ugliest, tackiest, universal looking designed kit ever offered. It looks like its made to fit 500 different type of cars, albeit poorly on every single one.
    Felony form kit looks great, and leaves you enough tire to stick, without making your car turn in like a boat.
    Like you said, the car needs some clean up. I think you will love the looks of the FF kit with some fresh paint and wheels. The kit looks a little wavy in this photo, but anything not OEM is going to need some work to make it OCD perfect.
    - 98 m3, techno/anthrazit cloth, 124k and officially worthless - 89 m3, alpine/black 143k and officially old - 2000 323it, tiag/grey, 169k and officially boring
  11. #611
    Aug 2013
    1999 BMW M3 Coupe
    Now that car looks clean and nice. Do that. Yours is even the same color. Don't necessarily need to slam it quite as low, but it doesn't look bad regardless.
  12. #612
    May 2014
    Noblesville, IN
    98 328i, 79 911SC
    Quote Originally Posted by 95AWM3 View Post
    Thank you, sir.
    i'm running 215/35/18s up front and 245/35/18 out back now. in a perfect world, i'd like to run 245/35/18 up front and 265/35/18 out back. that's not gonna happen without raising the car and doing some offset magic.
    Quote Originally Posted by propcar View Post
    i don't much care about scene points. i'm on bf.c and IG and that's it. i typically only go to one show a year, and very infrequently wash my car. now, if i paint it and fix the bodywork....i'll keep it clean and care for the exterior. but i'm still not gonna be on the show circuit. i've built all of my cars for me, and this one is no exception. i'm going to try to add more rubber on my current kit because the Pandem kit will cost me a fortune and i still have a few more bits to buy to finalize this current iteration. (differential, sunroof plug, new harnesses)
    but thanks for the input.
    i run -3.75*F and -2.5-2.75*R camber. ~1/16" total toe out up front and zero toe in the rear.
    i don't believe in changing my alignment to make my wheels fit. i'll take an angle grinder to the body (again) before i add useless camber to make my wheels/tires fit.
    i get heat all the way across the tires with my current setup. if adding tire allows me to reduce camber, i'll do that. if i still use the whole tire, then my alignment won't change.
    Quote Originally Posted by notMpowered View Post
    thanks for the input. but i don't agree with you on the "universal fitment" looks of the Pandem kit. it's a blister kit for sure. but i really like it. the RB/Saarto version 1 kit for e36 looks much more universal and much less appealing.
    the FF kit is wavy. it (like all FRP/FG kits) requires significant work to give an OE fit & finish. the FF kit adds ~40-45mm of width and re-radius-es the whole arch shape. so it does enable more tire. but it's not as much as you'd expect.
    with my rubber bands up front, my car turns quite crisply and (on the sliding scale of looks/performance) i'm stoked with how it drives. admittedly, i want more tire so i get more performance. but i'm not prepared to sacrifice looks as i drive the car daily and track/beat/race/whatever it very infrequently. i'm not super sold on a kit like the PTG or Flossman or MaShaw kits for something i take to the grocery store and work. if it were track-only, that's exactly what i'd do. but it's primarily a street car. so compromise is the order of the day.
    the car needs paint. but the wheels were just refinished this winter. only reason i'd change them is if i change to 17s.
    thank you to everyone that chimed in.
    as of right now, i'm going to buy a new diff and the sunroof plug first, then try out some 225/35/18 fronts to see how i like them. i also need to vent the hood and build a front splitter. so we'll see what i can do for some dynamic front grip in lieu of a massive upgrade in mechanical grip.
    worst that happens is i ball it up and have to redirect, right? lol
  13. #613
    DeWitt, Michigan
  14. #614
    May 2014
    Noblesville, IN
    98 328i, 79 911SC
    Quote Originally Posted by tptrsn View Post
    Venting my hood tomorrow. With an angle grinder.
    This is y I lurv ewe.
  15. #615
    DeWitt, Michigan
  16. #616
    May 2014
    Noblesville, IN
    98 328i, 79 911SC
    so today i washed the m3 and then my friend Pawel took a bunch of pics of my boss Kevin's Porsche.
    evidence it's clean.
    Kevin's Porsche
    Pawel making magic
    Then, Kevin drove Pawel around and Pawel took snaps of the #gripmissile and this little vid.
  17. #617
    Aug 2013
    1999 BMW M3 Coupe
    Is there anything that can be done to the lower rear fender/bumper aft of the rear wheel? Your rear wheels are so fat and kicked out (awesome btw) that you can see almost the entire tire sticking out from in front of the stock rear end lines. Are there wide body kits that take care of the stock bumper which now looks tiny, or at least fatten up the corners of it to fit with the wider contour which is in front of the rear wheel?
  18. #618
    May 2014
    Noblesville, IN
    98 328i, 79 911SC
    the only 'fix' is to go with a different widebody kit.
    Pandem (Rocket Bunny V2)
    PTG/Flossman/MaShaw
    Rocket Bunny V1
    Musk Customs
    or make some junk myself.
    that's about it.
  19. #619
    NY
    skateboard
    This
    ― George Orwell
  20. #620
    DeWitt, Michigan
  21. #621
    May 2014
    Noblesville, IN
    98 328i, 79 911SC
    Your car is SIIIIIICK!!
    thank you, sir!
    she's a 50 footer. but show cars aren't as fun as drivers.
  22. #622
    Feb 2012
    Birmingham, Alabama, USA
    1995 BMW M3
    Sounds wicked! jellyaf
    Cant wait to stuff a v8 with twins in mine some day.
  23. #623
    May 2014
    Noblesville, IN
    98 328i, 79 911SC
    Quote Originally Posted by rajicase View Post
    thank you.
    and twins on a v8 is a lot. there's no way i'd push this chassis to that much power. need something with more room for tires. like a c5 z06 or a viper.
    yeah. i'd like a viper. (first body style)
  24. #624
    DeWitt, Michigan
    You got that right! I broke the crap out of mine yesterday, never had so much fun! haha
    But then mine isn't even a hundred footer probably, it looks bad for as far as the eye can see. That's why I love it, no cares at all.
  25. #625
    Sammamish, WA
    95 Hellrot M3/02 MY Z06
    Nice build! One of my Son's has an LS1 w/T56 trans in the garage he plans on putting in his 318is some day. My M3 was everything to me years ago, but its been my DD for so long it now has 246K miles, so my Z06 is my sunny fun car. It even weighs less then the M3 with the same 50/50 balance and a lot more HP!....both are fun though!
    John
    '95 Hellrot M3 w/Dove
    AA Euro HFM Stage II (w/21# Injectors & Software) W/Gen III Exhaust - URI Crank Pully - FDM w/3 Row M Coupe Rad - 3.23 LSD - Vogtland Club Spec/Koni SA - UUC Red w/Enforcers - TMS Shims/Rear Camber Bars w/QA1 inners/Sways - VMC F/TMS R End Links - X-Brace - Perf Ultimate/SS Brake Lines - GC Tower Mounts/RTAB Shims - ZKW's w/5000K Hid - Fog Delete - Alpine 9847/Pioneer TS-C130R Kevlar Components/Pioneer PRS-X340/Stealth Box's/Wired Zune 120GB - OE LTW CF Sills/Glove Box Plate - Staggered Black M-Spoke II's w/235/40 (front), 255/40 (Rear) Nitto NT05's - Rolled Fenders!
    ***Got a '95 M3? (actually pretty common on all years! Even happened to Racer Seth Thomas! ) Check Your LSD! http://forums.bimmerforums.com/forum...d.php?t=390209
  1. Chronicling the demise of an automatic transmission
    By joekitch in forum 1996 - 2003 (E39)
    Last Post: 02-15-2016, 01:21 AM
  2. The $160 missile e28. A journey of pure misery
    By Jrcanes55 in forum Drifting
    Last Post: 06-10-2015, 05:09 PM
  3. Replies: 31
    Last Post: 08-08-2001, 12:42 PM
  4. Will 245/45/17 tires fit the rear of a 95 M3?
    By M3Jokster in forum 1992 - 1999 M3 (E36)
    Last Post: 07-17-2001, 11:36 AM
  5. can an aftermarket alpine cd changer be mated to the oem head unit of a 95 m3
    By mguy in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 04-10-2001, 11:04 AM
