Results 1 to 9 of 9
Thread: 2002 330ci staggered wheels tire pressure
    Oct 2014
    United States
    2002 330ci
    I have a 2002 330ci w/ sports package.
    Front- 225/45R-17
    Rear- 245/40R-17
    I have been reading some who say to to run 40psi at all 4. I've also read to have higher PSI at front tires, 40/38 and 42/37.
    I am going on a 1000 mile road trip tomorrow and wouldn't mind some accurate information regarding the tire pressure.
    Thanks.
    It should tell you what size to run on the door jamb sticker
    PRICE CUT on ALL FABRICS
    I always set them at 36 front, 40 rear.
    But yes, check the door jamb sticker. I wouldn't go less than 35 in front.
    Michigan
    2005 325Xi
    The sticker recommends higher pressures in the rear, assuming that there will be people or luggage back there.
    If you run empty 99% of the time, like I do, run all four tires at the front tire pressure, since the vehicle is balanced 50/50. Then just raise the pressures in the back a few psi if you're going to load up.
    Quote Originally Posted by B4SH View Post
    If anyone knows, it's this guy who knows literally nothing about everything.
    Quote Originally Posted by fcvapor05 View Post
    Do you even OT? The mean 401k around here is probably about $6, what with all the shiny cars and $1,000 watches and donations to get other members' Volvos running.
    Jul 2015
    Miss, OK
    Always 40/40 for me
    40 in the front just seems a little high to me. But who knows. Would you even be able to feel 4 psi difference?
    Sep 2017
    Wellington, FL
    2001 BMW 330ci
    tire pressure
    Quote Originally Posted by White94RX View Post
    So from what I hearing 39 in the front and 40psi in the rear is safe?
    Yes 39/40 is totally fine. I prefer 36/40 myself.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    What tires are on the car? It does matter! I ran Yokohamas for a while and set the pressures at 36F/40R. With Michelin PS2/PSS I ran 34F/36R. Both were the appropriate pressures for the respective tire.
