Results 1 to 9 of 9
Thread: 2006 750li blowing blue smoke
    Aug 2015
    Hi i have a 2006 750li with 97000 kms it blows blue smoke when idling and initial accelleration but once over 20 kms an hour no more blue smoke does anyone no what could be the main cause of this
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Valve stem seals. Guaranteed
    Jan 2005
    Japan
    In case of my M70 V12 the problem was solved by replacing the crankcase breather valves. Here explained http://bmwe32.masscom.net/sean750/vc.../VCVvalves.htm
    The v12 is a completely different animal. It doesn't suffer the same fate of leaking valve stem seals.
    Feb 2015
    Bay Area
    1995 BMW M3 Coupe
    Valve Stem Seals 100% ... VERY common problem on these engines.
    1995 BMW M3 5 Speed Coupe, 3.0 S50B30, Cosmos Black/Hellgrau Vader, Shrick Camshafts, New Vanos
    Dinan Cold Air Intake, Ireland Engineering Front and Rear Strut Bar, Turner Motorsport Chip, EWS Delete
    BBS RC 303 Genuine, 24 lb Injectors, Tuned for 93 Octane, StopTech Rotors, Bilstein Shocks, H&R Race Springs
    Continental DWS 06, Eibach Front and Rear Sway Bars, Turner Motorsport Rear Camber Arms, TM RTABs.
    Jul 2018
    Davenport, Iowa
    2006 750Li
    2006 750LI smokes after 5 minute idle. Couple questions. Please help
    2006 750Li 80k miles. first post. Been reading all posts I could find on topic.Smokes heavily after extended idle. Does not smoke while driving. Very little oil consumption since I never let it idle.ccv's , OSV, cyclone, Valve guides seals ? How do you tell?CCVs look intact, I removed the hose from the CCV's, plugged the intake and ran it. Smoke from passenger side only at CCV. After 5 minute idle = heavy smoke from tailpipe.Drive it 1/4 mile and smoke is gone. Doesn't misfireNo CELRuns perfect. Runs strong.Is there a way to positively diagnose this or is it best guess?I don't want to but will have no issue replacing VGS"s. Went to UTI and ASE cert tech most of my life. Not very familiar with troubleshooting this one. Please help. MikeThanks for you're time and advice.Mike LintzDavenport Fire Dept
    Apr 2008
    Toronto
    850i, Alpina B7, E61
    What parts are needed to change out the valve stem seals ???
    Jan 2016
    Ca
    2001 525it
    Check pcv valves on valve covers then change your oil to 10w60.
