Hi Guys,
i recently managed to read out an Alpina TCU and made a flash file out of it. Now we can use WinKFP to update our V8's to Alpina Gearbox Software, which is a huge increase in drivability!
Read here how to do it: https://www.tuningdb.info/alpina_b8s_flashes
Pre TU Alpina Tune for M62: https://www.tuningdb.info/alpina_b10_v8_pretu_flashes
Alpina Tune for M54 Engines Gearbox: https://www.tuningdb.info/alpina_b3s_flashes
Maybe someone is interested in this.
Good luck,
Jan
Thanks for sharing, will try the BMW Scanner route and let you know how it goes. Never flashed anything with WinKFP.
Quick question, when you say "no S mode anymore" does it means that the ECU shift points are the same if you select D than if you select S? or that one doesn't needs to be selecting S anymore to get those extra features? Have you tested D vs. S programs and they shift the same?
Diehard E39 driver.
I'd rather die or take a walk before driving an E60 or any BMW made after Y2K.
"Your momma's so ugly she makes Bangle cars look nice"
It feels like always S mode, when you switch do S mode it instantly moves to "M" in Alpina software, shifts are the same i would suggest.
Thanks for the reply, will experiment the BMW Scanner route and let you know.
Diehard E39 driver.
Do a Complete readout before for safety, takes up to 10-15minutes. 0000-3FFF i think. This works, i didn't try to write using BMW Scanner, but you can try, take the inverted complete file.
How do we get the file?
BMW Scanner don't reads the whole EEPROM dump. They barely seem to read adaptations and such. If I could do a complete EEPROM dump I could share a Stage 3 Dinan EGS file that I have in my car. It has the hoñding gears in manual mode, more aggressive use of the lockout, and still keeps a Sport and a Normal mode (the normal mode is way better than the regular EGS's normal mode, it feels much like a S mode that releases 4th below 60km/h if throttle pressure drops)
I have the Galletto 1260 cable and could open up the Dinan EGS if you want to instruct me how should I get a good EEPROM dump. PM me. I also have an Alpina B10V8 DME. I'm using it in my car now.
Diehard E39 driver.
you guys are insane
i did a BMW Scanner readout on the bench, select 0000-3FFF, i compared it with my eeprom programmer readout, it was complete! 256k file
Inneressin. Maybe i'll swap back to auto and try this.
2003 M3CicM6 TiAg
Former:
1985 MB Euro graymarket 300SL
Thank you!
So my bad on those crappy 1k files I've been dumping! "On the bench" means on the car, I take, since you'd need a full wiring system out of the car to use BMW Scanner on the bench, right? I'll see if I can get a reverted bit readout selecting 0000-3FFF and report back.
(that F..orbiden word) you! You'll never get tired of taking a stab at the regular joe (or john, in my case) driving a slushbox, right?
How's that VF supercharger going?
Diehard E39 driver.
-Paul
2003 "M5" - Full M5 conversion, AMG C63S 6 piston front calipers, Porsche Panamera 4 piston rear calipers, GC Coilovers, Eibach ARBs, UUC Evo3/DSSR, Borla Exhaust w/Muffler Delete, BMW NBT with Carplay/Android Auto, Bi-Xenons, e38 Style 37 M-Pars, e60 Hubs 530i 6-speed swap build thread2005 Range Rover 4.6is (M62TU Powered) - 4.6is Engine Swap from X5, BMW NBT with Carplay/Android Auto
Thanks! I'm in the car taking the big dump right now.
Memory dump, that is! Lol
UPDATE:
Took the Dinan stage 3 memory read, I obtained a 256kb file but BMWScanner said "memory read with errors"
Tried to flash the Alpina B10V8 EGS file using BMW Scanner and it says "incorrect file size". Tried to flash the file I obtained and it also says "incorrect file size". Tried to use WinKFP and admittely I haven't used it before, and I got it "almost there", but it says there's an error in communication with the module. I guess I'm just SOL.
Diehard E39 driver.
Lol. True i was bein wiseass about de-swapping but this is a cool thread and has many GGapprove points for initiative and potential.
Da car is all good esp since my spring intake servicing (sorted some leaky connects and BPV stuff) and esp esp since throwin clutch #3 in the beast. With luck Brian and i will get together in next month or so and have our matchy matchy tourings side by side... Will be fun...
2003 M3CicM6 TiAg
Former:
You burn through as many clutches as your mother does condoms....
Your two tourings side by side ... Actually, that'd be pretty awesome, especially if you blow a clutch up, then a tire, then bounce off Brian and as you guys pass your house you tumble end over end and the last bounce off your M3 puts you into the house. lmfao.
If you have never used WinKFP update before, please read a HowTo first. WinKFP need to be setted up correctly. And you need that GD8602 folder (which contains all gearbox flashes)
I did read it, downloaded the newest date files for my car and moved them.
The issue seems that I forced an installation of BMW standard tools on a x64 OS and while it mostly works, I get some COAPi and APi fail messages from time to time on my INPA and NCS, like some modules or APi jobs works with x64 and some won't. I need to sort all that out again.
Diehard E39 driver.
No you better have to use x32 system for inpa and WinKFP, or just use a virtual machine.
Nice. If you could get the non TU version for us non vanos owners, that would be fantastic.
BMW OSS Master - BMW Coding, flashing, and NBT/CIC retrofits for breakfast.
Founder of BMW Planet, serving wiring diagrams to BMW enthusiasts and independent garages all over the world since 2008
Not a bad idea to get this while it's available if anybody thinks they might want it in the future...
2003 M3CicM6 TiAg
Former:
Did I understand correctly that if one does this Alpina flash, there is no more sport mode - that regular "Drive" is like a sport mode and the other side of the transmission is just manual?
Very cool. Is there any info on how to extract the whole tune from the EGS? I'm pulling the transmission out of my 540, but the EGS box does have the Dinan tune.
