Hey guys - has anyone had a leaky rear end and fixed the problem themselves? I'm lookin at a '93 325, with some fluid around the diff. and possibly around the water pump. Any feedback would be helpful
Nick
Current: '07 VW Fahrenheit GTI; 2010 BMW s1000rr
Past: 2003 M3, 6M, Steel Grey, Koni Yellows
2012 Triumph Thruxton
1995 M3, Cosmos on Black Vaders
1993 325i Sport and Cold weather (limited slip!) packs, 5M
That's easy... just stop eating those wierd low fat potato chips fried in Olestra!Originally posted by E36 Fanatic
Actually there are several spots that coud be leaking on the diff. It might be as simple as replacing the crush washers on the drain and fill plugs or the o-ring around the speed sensor. More difficult to replace are the seals around the pinion and the axles. You're best bet is to throughly degrease the outside of the diff casing so the leaky spot will be easier to locate.
www.understeer.com Your source for:
Stromung|UUC|Eurosport|Hawk|H&R|Koni|Apexcone HID|Short Shift Kits|and moreUUC Evo3 SSKs are IN STOCK - free 2-Day shipping!
LMAO! "anal leakage" that's good stuff
Anycrap, thanks for the suggestions
N
