A couple years ago I suddenly heard a whining/grinding sound . Shortly thereafter, the traction control light lit up and simultaneously the noise stopped. Later, upon restarting the car the noise returned until the Traction Control light lit up again. The noise was coming from my ASC+T hydraulic unit.
Initially I changed out the Electronic Control box and did not solve the problem. Next, I changed out the hydraulic control unit (what a pain) and this worked momentarily.
A big break came when I had to replace a blown hydraulic seal in the driver side rear shock (self leveling) about a year ago. After I replaced the seal the noise was gone but returned about three months later.
I've since tried to reproduce the effect of fluid loss by bleeeding the rear shock, bleeding the system, replacing the power steering pump all to no avail. One thing I noticed after I replaced the power steering pump (a month ago) was fluid pressure is routed to the self leveling system aftrer the noise stops and the light goes out. This is real annoying!!!! anyone have or heard of this problem and found a solution?
Wow, nobody else has had this problem?
I do not have ASC+T, so no real experience with that.
Are you sure the noise comes from ASC+T? Because what irritates me is the mentioning of the LAD system. Sometimes the LAD regulating valve can make noise I have read, although I never have experienced that.
Have you asked a shop for a fault code read out?
Or try this:
ABS/ASC blink codes
Only possible on newer E32/clusters
German version:
ABS/ASC-Blink-Code
- Bremspedal und Schalter "ASC" gleichzeitig drücken
- Zündung "an"
- Bremspedal und Schalter loslassen
- ASC-LEUCHTE fängt an zu blinken
BC = BlinkCode
BC 1 = kein Fehler
BC 2 = EMS Fehler
BC 3 = Motronic Fehler (DME/ EMU)
BC 4 = Drehzahlgeber Fehler hinten links
BC 5 = Drehzahlgeber Fehler hinten rechts
BC 6 = Drehzahlgeber Fehler vorne rechts
BC 7 = Drehzahlgeber Fehler vorne links
BC 8 = ABS-Magnetventil hinten links
BC 9 = ABS-Magnetventil hinten rechts
BC10 = ABS-Magnetventil vorne rechts
BC11 = ABS-Magnetventil vorne links
BC12 = ASR-Plungenventil Fehler hinten links
BC13 = ASR-Plungenventil Fehler hinten rechts
BC14 = Ventilrelais Fehler
BC15 = Rückförderpumpen Fehler
BC16 = Speicherladeventil Fehler
BC17 = Langzeitfehler Druchüberwachung
BC18 = Leckage Fehler (Wird auch angezeigt wenn Druckspeicher(Gaspatrone) im ASC+T Hydraulikblock schadhaft ist (zB. leer))
BC19 = Druck Fehler
BC20 = Getriebebeinflussung Leitungsfehler
BC21 = ABS/ASR-Regelgeräte Fehler
BC22 = TD-Signal Fehler (dürfte Tachoimpuls sein)
BC23 = Option pin Leitungs Fehler
Zu BC 22:
TD Signal Fehler
Regelgerät Kl. 55
Zündung aus
Stecker vom ABS/ASR-Regelgerät und Motronic-Steuergerät Bank links abziehen
Leitung vom ABS/ASR-Regelgerät Kl.55 zum Motronic- Steuerg. Kl.6 auf Unterbrechung/Plus-/und Masseschluß prüfen.
wenn i.O.
Fehlerspeicher Motronic auslesen
wenn i.O.
ABS/ASR-Regelgerät tauschen
Translation, hopefully correct:
- push brake pedal and ASC switch simultaneously
- Zündung "an" / ignition on
- Bremspedal und Schalter loslassen /release brake pedal + ASC switch
- ASC-LEUCHTE fängt an zu blinken/ASC light starts to blink
BC = BlinkCode
BC 1 = kein Fehler / no fault
BC 2 = EMS Fehler / EMS fault
BC 3 = Motronic Fehler (DME/ EMU)/ DME/EMU fault
BC 4 = Drehzahlgeber Fehler hinten links/fault speed indicator rear left
BC 5 = Drehzahlgeber Fehler hinten rechts/fault speed indicator rear right
BC 6 = Drehzahlgeber Fehler vorne rechts/fault speed sender front right
BC 7 = Drehzahlgeber Fehler vorne links/fault speed sender front left
BC 8 = ABS-Magnetventil hinten links/ABS solenoid valve rear left
BC 9 = ABS-Magnetventil hinten rechts/ABS solenoid valve rear right
BC10 = ABS-Magnetventil vorne rechts/ABS solenoid valve front right
BC11 = ABS-Magnetventil vorne links/ABS solenoid valve front left
BC12 = ASR-Plungenventil Fehler hinten links/fault ASR plunger valve rear left
BC13 = ASR-Plungenventil Fehler hinten rechts/fault ASR plunger valve rear right
BC14 = Ventilrelais Fehler/ fault valve relay
BC15 = Rückförderpumpen Fehler/ fault recycling pump
BC16 = Speicherladeventil Fehler/fault storage load valve
BC17 = Langzeitfehler Drucküberwachung/fault long time pressure control
leakage fault (is also shown when pressure vessel (gas bomb) in ASC_T hydraulic block is damaged (for example empty))
BC19 = Druck Fehler/ fault pressure
BC20 = Getriebebeinflussung Leitungsfehler/fault pipe transmission control
BC21 = ABS/ASR-Regelgeräte Fehler/fault ABS/ASR regulators
BC22 = TD-Signal Fehler (dürfte Tachoimpuls sein) TD-signal fault (should be the speed impulse)
BC23 = Option pin Leitungs Fehler/option pin line fault
Zu/to BC 22:
TD Signal Fehler/TD signal fault
Regelgerät Kl. 55/ regulator terminal 55
Zündung aus /ignition off
Stecker vom ABS/ASR-Regelgerät und Motronic-Steuergerät Bank links abziehen/disconnect from the ABS/ASR regulator unit and MOTRONIC module bank left the connectors
check the line from ABS/ASR regulating unit terminal 55 to MOTRONIC- control module terminal 6 for interruption/plus-/and ground connection
wenn i.O./ in case that is o.k.,....
Fehlerspeicher Motronic auslesen/read fault codes
wenn i.O./in case that is o.k.,....
ABS/ASR-Regelgeraet tauschen/change ABS/ASR control unit
Hey thanks for the response Shogun. No, it's the ABS hydraulic Control Unit making the noise for sure. This morning I narrowed things down a bit: I discovered that when the electronic ABS/ASC control unit is plugged in this process start and end. In other words, if I unplug the unit before I start the car there is no noise. And I've swapped this unit out a few different times to determine the problem.
I tried the Blink Codes you suggested but got no response from the light. I guess that means my car will not respond to the blink code startup process. I guess a shop with the code reader is the next best option.
Sounds like an electrical issues, not a mechanical. As in some relay has a broken solder point and when loaded causes erratic behavior of the pump. It would also explain the sometimes unpredictable nature of the issues. Have you refreshed the ABS computers, etc?
______________________________
1992 750iL
No, I can't say I know anything about refreshing the ABS computer, but I can say that I've changed out the ABS computers with two otherABS computers and the problem stayed the same.
Additionally, If I shut off the ASC unit using the interior ASC button the light will come on BUT the noise will not stop unit the ASC hydraulic unit has faulted on its own. Remember earlier I said the noise will stop and the hydraulic pressure will cycle to the LAD when the ASC light comes on and simultaneously the noisestops. It appears control of the ASC hydraulic unit problem is not affected by the interior control being turned onor off.
Ok, Roseville BMW got a "plunger Accumulator Fault". Does this sound familiar to anyone?
Try document link. I can not say for sure, seems like a faulty ABS unit.
ABS/ASC/ASC+T Trouble Codes - Mark Gardner Gibson
1992 750iL
I copied that here for easier access: ABS/ASC/ASC+T Trouble Codes - Mark Gardner Gibson
4 Rotational speed sensor fault rear left
5 Rotational speed sensor fault rear right
6 Rotational speed sensor fault front right
7 Rotational speed sensor fault front left
8 ABS-valve fault rear left
9 ABS-valve fault rear right
10 ABS-valve fault front right
11 ABS-valve fault front left
14 Valve relay fault
15 ABS Back-delivery pump fault
21 ABS-control-unit defect
24 Incorrect gear wheel on one of the four wheels
25 Line interruption-brake light switch
2 EML-Interface fault Please check the connecting lines from PIN 6,8 and 14 to the EML. If you can not find a fault, reset the fault accumulator. Please effect a diagnostic at the EGS.
3 DME-Interface fault Please control the line PIN 39 to the DME.
4 Sensor fault rear left Please check the size of the tyres on all rims. Check the wheel- bearing clearance, the pulse-wheels, rotational speed sensor (optical damages, dirt).
5 Sensor fault rear right Please check the size of the tyres on all rims. Check the wheel- bearing clearance, the pulse-wheels, rotational speed sensor (optical damages, dirt).
6 Sensor fault front right Please check the size of the tyrea on all rims. Check the wheel- bearing clearance, the pulse-wheels, rotational speed sensor (optical damages, dirt).
7 Sensor fault front left Please check the size of the tyres on all rims. Check the wheel- bearing clearance, the pulse-wheels, rotational speed sensor (optical damages, dirt).
8 ABS-Valve fault rear left Please check the plug and socket connection on the ABS-hydraulic aggregates for correct seating and for corrosion. Please check the wire from the ABS/ASC unit PIN 2 to the ABS-hydraulic aggregate PIN 5. If no fault is found, erase the stored faults and re-diagnose. Should this fault occur again please replace the control unit.
9 ABS-Valve fault rear right Please check the plug and socket connection on the ABS-hydraulic aggregates towards correct seating and for corrosion. Please check the wire from the ABS/ASC unit PIN 36 to the ABS-hydraulic aggregate PIN 7. If no fault is found, erase the stored faults and re-diagnose. Should this fault occur again please replace the control unit.
10 ABS-Valve fault front right Please check the plug and socket connection on the ABS-hydraulic aggregates towards correct seating and for corrosion. Please check the wire from the ABS/ASC unit PIN 22 to the ABS-hydraulic aggregate PIN 3. If no fault is found, erase the stored faults and re-diagnose. Should this fault occur again please replace the control-unit.
11 ABS-Valve fault front left Please check the plug and socket connection on the ABS-hydraulic aggregates towards correct seating and for corrosion. Please check the wire from the ABS/ASC unit PIN 19 to the ABS-hydraulic aggregate PIN 1. If no fault is found, erase the stored faults and re-diagnose. Should this fault occur again please replace the control-unit.
12 Plunger-valve fault rear left Please check whether, on the magnetic valve, a voltage of 12 V exists. Please also check, whether visible damage (corrosion etc.) on the magnetic valve exists. If so replace the magnetic valve.
13 Plunger-valve fault Please check whether, on the magnetic valve, a voltage of 12 V exists. Please also check, whether visible damage (corrosion etc.) on the magnetic valve exists. If so replace the magnetic valve.
14 ABS-valve relay fault Please reset the fault storage and test-drive the car. Perform a diagnosis again. If the fault is displayed again please check the valve relay for correct seating and the contacts for corrosion.
Please check, by switching on and off of the ignition, whether the valve relay pulls on. Please check the voltage supply at the valve relay.
15 Rear feed-pump fault Please check the engine-relay for correct seating and the contacts for corrosion. Kindly check the earth connection to the ABS hydraulic aggregates. Also check the earth connection and the function of the pump-motor.
16 ASC+T storage-load valve fault Please check the function of the magnetic valve on the plunger-hydraulic aggregate.
17 Inlet valve front left Please check the connection between valve and master relay. Please also check the action of the master relay and of the valve itself.
18 Outlet valve front left Please check the connection between valve and master relay. Please also check the action of the master relay and of the valve itself.
20 Inlet valve front right Please check the connection between valve and master relay. Please also check the action of the master relay and of the valve itself.
24 Outlet valve front right Please check the connection between valve and master relay. Please also check the action of the master relay and of the valve itself.
33 Inlet valve rear axle Please check the connection between valve and master relay. Please also check the action of the master relay and of the valve itself.
34 Outlet valve rear axle Please check the connection between valve and master relay. Please also check the action of the master relay and of the valve itself.
68 Control-unit defect Please replace the ABS-control-unit.
72 Internal fault Please replace the ABS-control-unit.
81 Rotational speed sensor front left Please check the connection between rotational speed sensor and control- unit. Look for a disconnection or short-circuit.
82 Rotational speed sensor front right Please check the connection between rotational speed sensor and control- unit. Look for a disconnection or short-circuit.
84 Rotational speed sensor rear left Please check the connection between rotational speed sensor and control- unit. Look for a disconnection or short-circuit.
88 Rotational speed sensor rear right Please check the connection between rotational speed sensor and control- unit. Look for a disconnection or short-circuit.
97 Rotational speed signal front left Please check the plug and socket connections of the rotational speed sensor. Check the air-slot between rotational speed sensor and pulse wheel. If necessary reduce the air-slot. Possibly the pulse wheel has a wrong number of teeth or the rotational speed sensor is defective.
98 Rotational speed signal front right Please check the plug and socket connections of the rotational speed sensor. Check the air-slot between rotational speed sensor and pulse wheel. If necessary reduce the air-slot. Possibly the pulse wheel has a wrong number of teeth or the rotational speed sensor is defective.
100 Rotational speed signal rear left Please check the plug and socket connections of the rotational speed sensor. Check the air-slot between rotational speed sensor and pulse wheel. If necessary reduce the air-slot. Possibly the pulse wheel has a wrong number of teeth or the rotational speed sensor is defective.
104 Rotational speed signal rear right Please check the plug and socket connections of the rotational speed sensor. Check the air-slot between rotational speed sensor and pulse wheel. If necessary reduce the air-slot. Possibly the pulse wheel has a wrong number of teeth or the rotational speed sensor is defective.
113 Rotational speed signal front left Please check the plug and socket connections of the rotational speed sensor. Check the air-slot between rotational speed sensor and pulse wheel. If necessary reduce the air-slot. Possibly the pulse wheel has a wrong number of teeth or the rotational speed sensor is defective.
114 Rotational speed information front right Please check the plug and socket connections of the rotational speed sensor. Check the air-slot between rotational speed sensor and pulse wheel. If necessary reduce the air-slot. Possibly the pulse wheel has a wrong number of teeth or the rotational speed sensor is defective.
116 Rotational speed information rear left Please check the plug and socket connections of the rotational speed sensor. Check the air-slot between rotational speed sensor and pulse wheel. If necessary reduce the air-slot. Possibly the pulse wheel has a wrong number of teeth or the rotational speed sensor is defective.
120 Rotational speed information rear right Please check the plug and socket connections of the rotational speed sensor. Check the air-slot between rotational speed sensor and pulse wheel. If necessary reduce the air-slot. Possibly the pulse wheel has a wrong number of teeth or the rotational speed sensor is defective.
132 Pedal travel sensor Either the pedal travel sensor is defective or the feeder is interrupted or a short-circuit exists.
136 Brake hydraulics! The brake-system is leaking or there is air in the brake circuit. Advice: This fault must be eliminated before the car is driven.
145 Falling out of the pump Please check the lines to the ABS-control-unit and to the pump motor relay. Check the ABS-master relay for a short-circuit or interruption. All above mentioned systems could be defect.
152 Hydraulic pedal travel sensor Please check, whether the brake system is leak-tight or whether air is in the system. The pedal travel sensor could have an intermittent contact.
161 Outlet valve front left Please check the inlet valve which is related to the outlet valve concerning tightness. Please ensure that the rotation speed sensors are not mixed up. If necessary replace the outlet valve.
162 Outlet valve front right Please check the inlet valve which is related to the outlet valve concerning tightness. Please ensure that the rotation speed sensors are not mixed up. If necessary replace the outlet valve.
164 Outlet valve rear axle Please check the inlet which is related to the outlet valve concerning tightness. Please ensure that the rotational speed sensors are not mixed up. If necessary replace the outlet valve.
177 Fault, valve load circuit Fuse
ueberpruefen Sie alle ABS - Sicherungen/test all ABS fuses (10,13,26). Ersetzen Sie die ABS - Relais/replace the ABS relays
255 Accumulator fault The control-unit must be replaced.
1 No faults accumulated
14 ABS-valve relay fault Please reset the fault storage and test-drive the car. Perform a diagnosis again. If the fault is displayed again please check the valve relay for correct seating and the contacts for corrosion. Please check, by switching on and off of the ignition, whether the valve relay pulls on. Please check the voltage supply at the valve relay.
17 charging time fault plunger accumulator Please check all hydraulic-lines and connections for tightness. Also check the function of the tandem hydraulic pump.
18 Leaky fault plunger accumulator The plunger accumulator is leaky. Please check the system inside and outside for leakages. Advice: The plunger hydraulic aggregate must be disassembled.
19 Accumulator warning-pressure-treshold. Please check the connections and plugs of the plunger hydro aggregates to the ABS/ASC-control-unit for correct seating resp. the clear flow.
20 EGS Interface mistake Please measure the voltage on the control unit PIN 54. The value should be a 12 V! If 12 V does exist you have to simulate the normal-operation of the ASC-system. The voltage has to drop down nearly to 0 V! If the voltage does not drop down again the ABS/ASC-control-unit must be replaced. If the 12 V does not exists, please check the feeder and replace the ABS/ASC-control-unit.
21 Internal control-unit fault The ABS/ASC-control-unit must be replaced.
22 Number of revolutions signal fault Please check the signal-lines from the ABS/ASC-control-unit PIN 55 to both DME-control-units. If no fault can be seen please reset the fault accumulator.
23 Fault transmission-encoding (options-PIN) Please check the connecting lines on the ABS/ASC control-unit from PIN 15 to PIN 34.
Also interesting to read on his website:
BMW Data Link Interface Project
Fault Codes
If your ECU has codes set, what you get back is a hex number. When you convert to decimal, you still only have a number. Thus, here are a few tables with the codes I've found thus far, compiled from various sources:
ABS Trouble Codes
ABS1.txt
ABS2.txt
AC.txt
Air Conditioner
Airbag
Alarm
Central Body
DME41.txt
http://markgardnergibson.com/BMW/codes.html
Is there a update to this thread?
I seem to be having the same problem with my 1993 750il. It didn't occur until right after I opted for self leveling delete. Not sure if it's related. Also I believe I have only Asc not Asc-T.
My symptoms are the same, when I turn on the car there is a whining sound coming from the power steering and once I hit 45ish mph my Acs light comes on and it goes away instantly. I have tried to fix by changing the Power Steering Filter (very expensive filter btw) to no avail.
When I had my SLS deleted I purchased Febi equivalent pentosin 11s fliud. My current fliud is pinkish not sure if it is suppose to be green(maybe my fliud is the culprit?)
If it helps the last 7 of my Vin# DC81388
Any help would be appreciated.
whining sound coming from the power steering could be too low fluid mixed with air bubbles.
Pentosin is green-ish as well as the Febi equivalent.
A 1993 750 should have ASC+T I assume. With your VIN you can check here in the VIN decoder all the options which were ordered, but if ASC+T was standard then, it is not listed https://www.bmwvin.com/
Bleeding brake system with ABS/ASC+T
https://www.bimmerforums.com/forum/s...with-ABS-ASC-T
Thank You Shogun
I will see if this can solve my problem
So I still have this noise that wont go away and it is truly annoying. I originally thought it was my power steering pump but it looks like it is the exact same deal as Jerrybare. I disconnected my ABS pump and the noise was gone.
Was there any solution to this issue? Was it finally resolved? A brand-new ABS pump is going for 2k at the stealership. I have a salvage yard near me that wants 100 bucks for a used one. Thinking to try it out. Thoughts?
-Abdullah
There's a guy on Ebay in Ill with your part up used for $250.00. But he's taking offers. Maybe offer him a hundred bucks and see where he goes. Might get lucky.
Jeff
https://www.ebay.com/itm/BMW-5-7-8-S...EAAOSw09JZyohE
1990 735I (Auto) E32 Feb 1990 to Present
1996 Z3 Roadster (5 Speed) E36/7 Jan 1999 to Dec 1999
1983 733I (5 Speed) E23 April 1983 to Feb 1990
https://www.youtube.com/watch?v=2d4tHoHGaJo
https://1drv.ms/v/s!Av20xCMMocSsyEpl...h_oOk?e=ekIcAT
Thank You Jeff will take a look at this one. Really want to fix this really annoying noise.
