Page 4 of 7 FirstFirst 1234567 LastLast
Results 76 to 100 of 164
Thread: Rear Deck Speakers Choices
  1. #76
    Fairfax, VA
    E38 740i, 2009 E92 M3
    Quote Originally Posted by HDIDDY View Post
    My local yard only charges about $6 each for the speakers.
    Which one? I am in NOVA too
    Also, I don't have that rear speaker deck (97') so I wonder what my options are? Funny i've been on this board for a long time and never researched any types of sound upgrades for the e38
    Mods: 19in Staggered Style 89s, HR sport lowering springs/Bilistein HD shocks, Tri-stitched M steering wheel, Leather Dash, Custom two tone leather interior (euro 750i) Euro-clear tails, AE's, OEM Xenons, Smoked side markers, PWR- folding mirror retrofit, Wood seat backs, Leather grab handles, "porn" lights, Shadowline, Tint, Electric rear sunshade retrofit, LED interior lights, Alcantara Headliner etc.
    Maintenance: Complete power steering hose rebuild, complete front suspension rebuild, rear ball joints replaced, inspection II, synthetic oil every ~6k, magnetic drain plug, expansion tank replaced (twice) aluminum throttle cables, etc.
  2. #77
    Jun 2005
    Woodbridge, Va
    2000 740i Sport, 69 GTO
    VA pick a part in Stafford down my quantico. I figure adding the sub box and wiring would be a huge pain. Though I don't know for sure. Someone may chime in.
    1969 GTO Warwick Blue/Parchment
    2000 740i Sport 6 speed
  3. #78
    West Palm Beach, FL
    06 Audi A8L Quattro
    Grind around speaker terminals like so
    Use screwdriver to help pry off outer spacer.
    Chisel to separate spacer from speaker.
    Removed spacer should look like this
    I use a rotary tool to make the edges flat.
    I use a zip tie to hold the terminals to the magnet.
  4. #79
    Dec 2011
    Lancaster CA
    e34,e38,e39,e46,e70,e90
    Thanks deville, that was my biggest question. Did you use the VW connector for wiring? It appears you can remove that too and just solder on the wire from the rear deck to the speaker leads.
    Also, some of the connectors have two wires while others have four. In the 4 wire type, which wires should I use?
  5. #80
    Jun 2005
    Woodbridge, Va
    I solder the BMW wires to the VW connections and retain the plug. Not really sure the 4 wire speakers are the G speakers. Any G that I have pulled so far only have 2.
  6. #81
    Dec 2010
    Atlanta, GA
    E38 7er, E46 M3
    This idea took my interest but I didn't get something clearly; so do the front door VW Monsoon speakers replaces our rear deck speakers or front door speakers?
  7. #82
    Jun 2005
    Woodbridge, Va
    Rear deck for sure, not sure about the doors.
  8. #83
    West Palm Beach, FL
    06 Audi A8L Quattro
    Anyone that has done this retrofit and has Bluetooth.
    Play this track OMG.
    Some seriously low bass notes that are played with amazing depth and power from the Monsoons!!!
    http://youtu.be/w1E-D-CfxrY
    I happened to have also done all four door speakers with Monsoons too.
    I don't have to worry about them fading or drying out.
  9. #84
    IL
    2000 740i sport
    How was the door speaker install? The speakers look big. Any trouble with putting the door panel back on?
  10. #85
    West Palm Beach, FL
    06 Audi A8L Quattro
    Quote Originally Posted by purplecty View Post
    No problem installing door panels.
    Speaker magnet fits right into enclosure.
    The first pair I did, I totally hacked up the speaker box to use the Monsoon without removing if from the spacer frame.
    I removed it from the spacer for the second pair and it was much easier
  11. #86
    IL
    2000 740i sport
    Any write up on the door speaker install? I need to do all of this as all my speakers suck and there are no good direct replacements...
  12. #87
    West Palm Beach, FL
    06 Audi A8L Quattro
    Once you separate the Monsoon speaker from that spacer in the pics above, it's a direct swap from BMW 5.25" to the Monsoon if you keep the VW plug and splice the BMW wires to it.
  13. #88
    IL
    2000 740i sport
    Quote Originally Posted by dville View Post
    Thats amazing. The sound has to be outstanding...
  14. #89
    Dec 2011
    Lancaster CA
    With the original speakers all 8 ohm and the Monsoons at 4 ohm they will naturally play with greater power and volume, but they will also hear up the amp. Swapping four in the back may be ok, but worried that doing all 8 may shorten the amp lifespan significantly.
  15. #90
    IL
    2000 740i sport
    Just keep a spare amp on hand
  16. #91
    Apr 2006
    IL - 60499
    99 M Rdstr, 92 325ic,
    Would rewiring the speakers in series be an option to bring the resistance back up to 8ohms?
  17. #92
    West Palm Beach, FL
    06 Audi A8L Quattro
    The door speakers are not 8 ohm.
    I tried the rear in series and it just sounded weak.
    I have been abusing my DSP amp in HOT Florida weather during the summer with a total of 8 Monsoon speakers in total.
    Sounds awesome, and no ill effects to report.
  18. #93
    Dec 2011
    Lancaster CA
    With a Dremel and a wide metal cutter tool you can go around the edge of the speaker and remove the plastic mount in less than 5 minutes
  19. #94
    Dec 2010
    Atlanta, GA
    E38 7er, E46 M3
    I went to take out the factory speakers off my old E38 and found these inside the rear deck. I don't remember getting them replaced but my father says they were indeed replaced. Any good? Worth swapping the factory rear deck speakers with these on my current E38? Says 4ohms.
  20. #95
    West Palm Beach, FL
    06 Audi A8L Quattro
  21. #96
    Dec 2010
    Atlanta, GA
    E38 7er, E46 M3
    I don't remember how they sounded honestly. That's why I wanted to get someone's opinion. They were in our first E38 which my father drove most of the time and now is a part car. Also the last one or two years before the transmission gave up, the radio unit was not working regardless of how many things we swapped out to make it work. I went with the intention of removing the factory speakers out of it as my current E38's speakers are blown and found them.
  22. #97
    West Palm Beach, FL
    06 Audi A8L Quattro
  23. #98
    Jul 2015
    Millersville, Md
    2001 750iL
    Quote Originally Posted by kouks View Post
    Only the rear deck speakers are 8 ohm. The doors are 4.
  24. #99
    Dec 2011
    Lancaster CA
    Monsoon speaker in E38 video --> https://youtu.be/ZmvbJ9t2wGE
    Have not worked in the front door units yet. Did you have to trim the lip around the speaker face for them to fit or was it an easy fit?
  25. #100
    West Palm Beach, FL
    06 Audi A8L Quattro
    Door speakers:
    Before I thought about separating the spacer from the Monsoon speakers I just hacked up the BMW door box for the Monsoon speakers. (see photos)
    Rear speakers:
    Lips are still on the speakers (see photos)
    ImageUploadedByTapatalk1456766261.632686.jpgImageUploadedByTapatalk1456766272.380574.jpgImageUploadedByTapatalk1456766287.999412.jpgImageUploadedByTapatalk1456766297.566527.jpg
