The CC module is looking for a valid ground on pin 18.
The module biases the line high
The clutch pedal switch is normally, NC, and breaks the circuit as soon as the pedal moves.
The brakelight bulbs act as a half ohm ballast to the ground sink. Low enough resistance that it appears to be nearly a ground to low current levels. But applying the brakes floods the circuit with 12V
So, clutch depressed, line floats high.
Clutch engaged, bulbs pull line low
Brake lights flood the circuit to high again.
LED bulbs are very high resistance. They will not sink the signal current. Many a person has fried the transmission in their '90's Ford because of the same circuit design being used to ransmission control.
You could rewire the clutch switch so that it goes to ground via the NC contacts of a small relay. Drive the relay from the brake light signal such that the contacts open when the brake lights are on.
/.randy
Excellent info. That's an interesting method for shutting off the cruise control.
I may well rig up a relay. That would still work if the incandescent bulbs were swapped back in. Win win.
If you are going to change the Cruise control clutch switch please note that the early Z3's had a 2 wire switch and the later Z3's had a 3 wire Hall Effect switch. Order the right one for your car. You either have a look to see which one you need or go to www.RealOEM.com and put your VIN number in to search for parts for your particular car.
The most common cause of the Cruise Control not working is a faulty brake switch. There will be a "BLS/BTS plausibility" code logged in the DME.
1999 2.8L Z3 Roadster,
2000 3.0L Z3 Roadster,
PRICE CUT on ALL FABRICS
