Page 8 of 10 FirstFirst 12345678910 LastLast
Results 176 to 200 of 228
Thread: Ponchiz BMW M302
  1. #176
    Aug 2008
    Houston, Tx.
    '10 X5, '98 M3 - 302
    So I did a thing today.
    For a while now, I've been looking into details for the car to give it a bit more personality. I found a shop in the UK that makes custom badges so I contacted them to get me some molding badges made. Took about two weeks to get them but well worth it.
    Big thanks to Richard at www.vehicledecals.co.uk for getting these done.
  2. #177
    Dec 2014
    Des Moines, IA
    '97 M3/4/5.0
  3. #178
    Aug 2008
    Houston, Tx.
    New wheels, who dis?
    Apex FL5. 18X9.5 ET22 front with 10mm spacer. 18X10.5 ET22 rear, no spacer. Looks like I might get away with rolling for now. I want 245/35 and 285/30 but it looks like that's ambitious at this point.
  4. #179
    Dec 2014
    Des Moines, IA
    '97 M3/4/5.0
    Looks like you're gonna need some flares!
  5. #180
    Aug 2008
    Houston, Tx.
    Yes, for the tire size I want
  6. #181
    Apr 2012
    Stuttgart, Germany
    1997 M3 / 5.3
    Impressive on the badges...looks factory!
    Wheels...don't look factory! Seems excessive for the wheel well without flairs. Certainly a lot of stick if you can make them fit.
  7. #182
    Aug 2008
    Houston, Tx.
    Thanks! I really like how the badges came out. As for the wheels, I'm thinking flares.
  8. #183
    Aug 2008
    Houston, Tx.
    Celebrated 'Merica Day.
    https://youtu.be/Q6qoxEthh8w
  9. #184
    Aug 2008
    Houston, Tx.
    So after months of driving the car with open headers, I finally got it too quiet down.
    Exhaust is a dual 2.5 to a Borla Pro XS resonated y, to a single 3" with massive dual tips.
    https://youtu.be/HuFArQayDk8
  10. #185
    Dec 2014
    Des Moines, IA
    '97 M3/4/5.0
  11. #186
    Aug 2008
    Houston, Tx.
    Thanks! I wanted a more aggressive sound but when I heard this test run I liked it and ran with it.
  12. #187
    Aug 2009
    Metro DC
    79 323i, 94 325is, 13 M3
    Hey, you put the Borla in the middle! I have been thinking of doing that, but I haven't been able to work up the courage. I keep thinking I'll be messing something up. But it would make the job easier in some ways, even though I'm going with 2.5" dual all the way back.
    If God meant for man to motor-swap LS engines into track cars, He wouldn't have created Corvettes.
  13. #188
    Aug 2008
    Houston, Tx.
    My options were dual 2.5 with resonated borla or magnaflow X pipe but they didn't have the X pipe available, so the guy said he'll run true dual straight pipes and just install it once it arrives.
    Dual 2.5" to regular X pipe with dual magnaflow bullets.
    Option three was this one and was recommended by several Ford people I talked to to increase torque. I really liked the sound and more torque is a good thing.
    Muffler is Borla 40349
  14. #189
    Aug 2009
    Metro DC
    Yum, more torque. With mine, that's where the car really shines on track versus a regular E36 M3, so I might as well make it shine even more. I have a Borla 400286 in my garage, which is the same thing as yours except with dual 2.5" outs instead of the single 3". I'm about 90% decided to follow your approach here with the placement.
    But instead of that nice custom-bent pipe out to the rear bumper like you have, I'm gonna have to cut and weld something of my own out of straight pipe and whatever bends I have left over from the front end job. Oh joy. I have a real band saw now, so that should make it easier to cut butt joints that actually fit up well. I did it with an angle grinder and a disc sander for the front end.
  15. #190
    Aug 2008
    Houston, Tx.
    I installed a offbrand temp gauge just to keep an eye on things. Apparently, my car runs at 205-210℉. I only have the high speed fan wired in off the sn95 relay which triggered the fan at 210℉. If I wire in the low speed fan which kicks on at 190℉, would the low speed relay shut off once the high speed kicks in, or will the fan get power from both relays? It's something I'm tackle this weekend.
  16. #191
    Dec 2014
    Des Moines, IA
    '97 M3/4/5.0
    What thermostat are you running? I think I have a spare 180deg lying around if you want it.
  17. #192
    Aug 2008
    Houston, Tx.
    Mine is either 180 or 192 which most likely it's 192. The fan seems to be working fine though keeping the temperature in check.
    Maybe I should put in a toggle switch instead of wiring in the low speed fan relay.
  18. #193
    Aug 2009
    Metro DC
    What's your running temp during a steady half-hour cruise on the freeway, where the fan is no help?
    I'm afraid I don't know about the Fox relay/thermo switch setup. I used the junkyard 2-speed Volvo relay.
    The Oracles of the Internet say 210 is "high normal." 200 being normal-normal. They say start trouble-shooting somewhere between 210 and 220.
    I'm using an aftermarket probe-type thermostat controller to trigger my relay, but I have to remember to keep an eye on it. In another car I have, I have seen them fail and/or drift, even the expensive ones. The permanent screw-in switches, like the one in the stock E36, are supposed to be more reliable and I guess the 80/88 one might be okay for you in Texas. I tried one but I mounted it into the drain port on my radiator with a metric adapter, and it never turned on. The snout apparently needs to be right in the flow, like in the radiator hose.
    I have seen old thermostats that open up ten degrees late, or only open up a crack. I put in a new one when I replaced the intake. It's too much trouble to pull one out and test it. Maybe start it up cold and use a laser thermometer on the hose to ball park what the water temp is when it starts flowing?
  19. #194
    Dec 2010
    Lutherville, MD
    1995 318is with a 95 5.0
    I use a stock BMW 80/88 switch with the Volvo fan (mounted as a pusher where the A/C fan was) and Volvo relay setup. To mount the switch to my aluminum radiator I JB welded a 14mm 1.50 nut to the side of the radiator a couple of inches below the radiator cap. Except when it's in traffic with the A/C or it's 90 to 100 degrees out my car runs at 170 with the 195 degree thermostat.
  20. #195
    Aug 2009
    Metro DC
    So the tip of the BMW switch is just pressed up against the aluminum radiator body? Interesting, makes sense.
  21. #196
    Aug 2008
    Houston, Tx.
    Quote Originally Posted by JBasham View Post
    Lowest ive seen was just under 200 on the highway, at night. Street driving kept it at 210.
  22. #197
    Aug 2008
    Houston, Tx.
    Took this video after removing the SCT chip and starting up the car without it. It didn't work. Really rough idle and borderline stalling. Reinstalled the chip and this is the result. Idle is a little low but stable. Temporary temperature gauge is wired in and it shows the temperature it's always at.
    https://youtu.be/x54n1juSuyE
  23. #198
    Aug 2009
    Metro DC
    Quote Originally Posted by ponchiz318 View Post
    200 makes sense for a functioning 192 T-stat. IIRC, 210 is where your fan turns on high now, so at high fan speed it's getting the job done stalling the upward progression.
    The 200 reading on the highway tells me the fan's best case utility range is 200 to 210. I doubt turning it on low at 190 would keep it down at 200 in stop n go traffic.
    Do you have a front undertray at least as large as the stock one? I ran without one for a while and it created a bit of a high-pressure zone behind the radiator. That interfered with airflow at speed and hindered cooling, until I fabbed up a new one out of aluminum.
    I really doubt you would ever get below 200 on a regular basis with a 192 T-stat. I have no idea what a 180 T-stat would do for you in a street car. There's no point using one in my car because I run it at WOT whenever there is enough traction to be there, and the car is going fast enough on the track that the fan is irrelevant. With a 16# radiator cap (puke tank system) it stabilizes at 210 and stays there. Without an oil cooler the oil temps will get to the high 200s in 15-20 minutes. But I have an oil cooler now.
    I don't know what your SCT chip is doing. But with an unmolested EEC-IV box, there is an adaptive table that the ECU populates with data based on actual experience running whatever your motor is, in closed-loop mode. It's kept alive even when the ignition is off. Clearing it requires a battery disconnect.
    Try it again only this time, pull the SCT chip, disconnect the battery long enough for the capacitors to drain, reconnect, and drive it for 15-30 minutes to repopulate the adaptive table. Then check the idle.
  24. #199
    Dec 2014
    Des Moines, IA
    '97 M3/4/5.0
    I have a 180 deg thermostat and it sits on 180 on the highway. If it's in the 90s outside, it might sit on 184 or so. My fan is driven through a relay by the Megasquirt, it's programmed to come on at 200 and turn off at 190.
  25. #200
    Aug 2008
    Houston, Tx.
    Well I have a chance to change out my thermostat now......
    Last night I changed the pcv hoses and pcv valve since I was having some blowby. Under heavy acceleration, the oil dipstick would pop out. Plugs looked good so I decided to go over the pcv system and then do a compression test. After all that, I took the car out for a test drive. It was running gear with no issues at all. Got on the freeway and gunned it. A GT500 passed me so I figured I'd try and keep up. Needles to say, that didn't happen. Let off, got off the freeway and made a uturn. At that point I noticed my temperature was climbing significantly. At 230°, I pulled over and turned the car off. Waited a couple of minutes and checked the temp. Once it was close to 210, the car started right up and drove home about 3 miles. At a red light, a ton of white smoke was coming from the exhaust. It looked like the foggers at clubs. Temp was still at 220is and started climbing. When I accelerated, the temps went down again and I made it home. What's weird is that the engine never lost a beat. It was running well which leads me to believe that water didn't go into the cylinders. Then again that doesn't make sense with all the white smoke.
    Regardless, today I'll remove the lower intake manifold and see if that seal gave out.
