I have this beautiful 2004 BMW 745LI in the shop and it is literally perfect except for one thing. The Dynamic Drive is inactive and i cant figure out what it is. I flushed and refilled both the Power Steering and Brake Fluid Systems. I am able to operate the ARS Pump via INPA. I know the Valve Block is working. The steering angle sensor is working because the SZL Module has no codes stored or present. The only other possibility is the actual ARS Control Module which is behind the glove box.
1995 BMW M3 5 Speed Coupe, 3.0 S50B30, Cosmos Black/Hellgrau Vader, Shrick Camshafts, New Vanos
Dinan Cold Air Intake, Ireland Engineering Front and Rear Strut Bar, Turner Motorsport Chip, EWS Delete
BBS RC 303 Genuine, 24 lb Injectors, Tuned for 93 Octane, StopTech Rotors, Bilstein Shocks, H&R Race Springs
Continental DWS 06, Eibach Front and Rear Sway Bars, Turner Motorsport Rear Camber Arms, TM RTABs.
I have this same problem.
All my lights are on: Traction Control, ABS, Parking Brake, PARK, BRAKE and a red brake symbol with an exclamation point inside.
I will have it diagnosed later to see what it is.
hi..
i have the same problem. how you fix this?
regards,
Roland
