Results 1 to 16 of 16
Thread: Alcantara-like Faux Suede Touring Headliner Install
    northeast ohio
    E39T / E46 / E36 M3
    My E39 Touring grey headliner had seen better days and needed some love. After spending too much time looking at pictures of others, I dove right by ordering 6 yards of foamed back suede headliner material from Ebay seller Trimjobber. The material is made for headliners, UV protected, there is very little stretch, foam backing can be peeled away for the pillars.
    I used 3M 90 Adhesive. This stuff is great, follow the directions and give it ample time to dry before attempting to bond anything together. Patience is key for this project. I did mine over the course of a few days. If something was not coming out right, I would walk away and come back to it fresh the next day. Once the glue touches another piece with glue on it, you are usually committed at that point... so take your time.
    There are plenty of posts on how to remove the headliner. It's easy, but time consuming. Headliner slides out the tailgate very easily, a helper is helpful to guide it over the headrests. Try not to fold or crease the headliner.
    Remove a the old material. After peeling away the fabric you will be left with old foam stuck to the headliner. I found a coarse stiff plastic bristle brush worked great, like what you might use to deck scrub a floor. This knocked almost all of the crud from the headliner, follow by a wipe down with lacquer thinner to remove any gummy residue. Once clean it should look like this:
    Once cleaned you can begin to apply the fabric. I started in the rear and worked forward. I found that by working from the center out to the sides worked best for managing bulges and pulling the fabric taut. Again take time to make sure it is right before glueing. I covered all the holes then went back later to trim them out from the back side.
    The most difficult part is the recessed "oh Shit!" handles. I found applying a heat gun really helps convince the material to conform to the recesses and contours. Be careful as the heat gun can and will quickly scorch the material if not using care. Heat helps and again, let the glue dry before trying to handle the fabric, otherwise it will bleed thru the fabric.
    I peeled off the foam to cover the side pillars and motion sensor mounted to the ceiling. this material is not suitable for high wear areas like shifters, steering wheels or seats.
    Carefully masked all of the interior bits and I used Krylon Fusion Flat Black paint. I tried several different cans, but liked this the best. Was kinda hard to find. My personal favorite is SEM Trim Black. I could not find locally, until I realized that Summit Racing stocks all of it and nearby!
    Here are a few shots of the completed product. Very pleased with the results! If I were to do it again I might consider using the charcoal color material. The black looks awesome, but I could see some people not linking the darkness inside.
    Thanks for looking!
    Aug 2013
    Pleasanton, CA
    '99 540iT; '00 M5
    WOW that looks great!! Especially with the black trim pieces.
    Definitely want to get this done on my car.
    Mar 2015
    Michigan
    2003 540iT M-Sport (sold
    Thanks for the write-up! Looks awesome!
    Miami
    1998 318i
    #tuff
    Jul 2012
    mitten
    525it,02 525it,73 2002
    Nice work.
    Jun 2014
    Astoria, NY
    2003 M5
    Wow great job! How is it holding up? Some questions regarding the pet pet anchor points. My 3/99 touring doesn't have these and I'm trying to figure out if I can just buy the trim pieces and cut holes in my existing headliner. Would you happen to have photos of your roof with the headliner out? Thanks =)
    Instagram: ​Ethirtynine
    2003 M5 Sterling Grey
    (Weekend Fun)
    2002 540iA Schwartz Black (SOLD at 230K)
    1999 528iTA Titanium Silver
    (SOLD at 200K)
    2003 530i/5 Titanium Silver (SOLD at 122K)
    2002 530iA Sterling Grey (SOLD at 156K)
    1997 528i Aspen Silver (SOLD at 269K)
    Jan 2017
    CT
    2011 750Lix M sport
    That looks great. I also considered doing this except I was a little nervous as it relates to the sunroof slide cover. Did you also do that with the material or left it gray?
    Aug 2016
    Virginia,USA
    528i, 525iT, M5
    Great Job!
    Current Garage Highlights
    2003 525iT TiSilver
    2002 M5 TiSilver
    Former Garage Highlights
    2005 X5 4.8is
    2004 325iTs (2x)
    1973 Pantera L
    1969 Road Runner 383
    Dec 2016
    Canton, Ohio
    97 528i
    That's incredible looking...!!! Nice craftsmanship. The headliner in my wagon is black, and personally I like the darker interior. I get in our 528 (with the std gray headliner) and it's like "who left the lights on...?"
    Props to you for pulling this off in what appears to be your garage too. The write-up makes it sound easy, but headliner work is a task requiring patience and forethought (and room to work...lol...). Looks to me like you nailed that job
    "two wrongs don't make a right...only three lefts do...."
    '79 Euro 635csi - gone and regretting it...
    '89 gsxr-750 - former traffic knife
    '97 528i sedan - holding on strong...(just sold after 16 years of ownership - sad day)
    '03 Euro 525it - something about a famous dolphin.....
    '06 Mercury Grand Marquis (don't ask....it gets the job done....)
    '84 Specialized Allez - full Campagnolo Super Record
    '99-ish Cannondale CAAD4
    "Stinky" - Kona Stinky Five
    '86 528e
    2008 E70 X5 3.0
    northeast ohio
    E39T / E46 / E36 M3
    Follow up...
    So about 3 yrs later and the headliner has held up great. No sags or adhesive failure. The A pillars do show some wrinkling, but only noticeable in certain light. Would recommend!
    (I bought an E46 that needs a headliner, found my own thread! lol!)
    San Diego, CA
    98 M3, 03 540it M-Sport
    Fancy that A pillars just started to have the fabric start peeling off this week, and then this thread re-surfaces!! I'll probably redo both A and B pillars since one B pillar is also not so great. Great initial post tho!
    '98 M3 5spd - '03 540it 6spd M-Sport
    Jul 2018
    Albemarle nc
    1999 528iT
    so I have to ask, as my touring is slated for headliner work soon.....
    how much of the interior needs to be removed to get the headliner out of one of these? is there a how to for that, or a specific section in TIS (couldn't find one)?
    also, the black trim instead of woodgrain: was that a factory option, or did you sand and paint?
    San Diego, CA
    Quote Originally Posted by Dusterbd View Post
    I believe you just have to remove all the pillars, lights, grab handles, speaker covers, and sunroof motor cover.
    Jun 2016
    North Carolina
    03 525it/5, 1967 GTO
    Quote Originally Posted by anthrazit View Post
    Follow up...
    How well did the Krylon Fusion hold-up on the plastic trim? I’m getting ready to order materials for this project. I’ve used both the Fusion and SEM before, but not in this type of application (interior handles, seatbelt guides, light switches, etc.).
    Mar 2005
    Charleston, SC
    99 528iT
    Great info - thanks!
    northeast ohio
    E39T / E46 / E36 M3
    Quote Originally Posted by Twistytee View Post
    There is slight wear on the seatbelt sliders, but, its generally covered by the belt it self.
    The trim is factory, not sure of the name.
