Awesome work. Good choice on the truck motor, I love the cost savings of them, and how plentiful they are here in Houston.
Almost finished the exhaust this morning. I just need to make some brackets to weld into the muffler for the hangers.
Also finished up the intake pipe. The filter was a tight squeeze and the hood just slightly crushes the corner. I wasn't about to hammer the fender well or downsize the filter.
95 M3, 5.3 LS, PTE 7675CEA, TH400/Gear Vendors OD
10.4@136 Pump gas at 3530lbs.
Build thread
http://www.bimmerforums.com/forum/sh...LS-Turbo-build
Wow very nice project! Will you have it ready for bimmerfest next month? I'd love to see this in person!
It's gonna be close. The fab work is nearly done with the exception of a couple brackets. We'll see how the wiring goes. There really isn't that much, but the days tick by fast!
If I miss Bimmerfest, I'll definitely have it at Slipstream roll race event in October at Pocono Raceway.
Build thread
Awesome fabwork and pace!!
2003 M5 LSx l 6 Spd Manual l 4.10 LSD
Build Thread
The chassis must always be regarded as a means to an end and never as an end itself
If you miss bimmerfest I'll probably never get to see it in person since I live in FL . I'm making a trip up just for bimmerfest
This thing is going to be an absolute monster!
www.facebook.com/Undr8dEmpireLlc Instagram: @UNDR8D_EMPIRE
Scarlet V2 - #Project333Ti - http://www.bimmerforums.com/forum/sh...(-Project333Ti)
Primary fab work is done. Black muffler blends in nicely.
Topped off the oil sump with a filter.
Definitely going to need to remove the spring pads in the rear to level things out a bit. Front sits a bit lower with the extra weight.
Build thread
Finished up the fuel pump wiring this morning.
Solid state relay for PWM control of the pumps.
Drilled and tapped the EGR blockoff as the boost/vacuum source.
Starting on the X20 to ecu wiring next.
Build thread
Not a chance in hell Im going to make Bimmerfest with the tedious stuff I need to wrap up. However, East Coast Call Out is a go.
Build thread
Started the remaining engine wiring to the new x20 connector. Hopefully will have it wrapped up later in the week.
A 90 degree 3/8" tube stem to 1/4" push to connect is a perfect fit into the headlight washer grommet on the euro washer tank.
Build thread
Nearly finished with the wiring. Still waiting on some connectors and another fuse block for the relay outputs.
Build thread
When you look at that last picture of your engine bay, it's hard to believe you squeezed a turbo in there!
Getting to the final stages. Wiring is done and started powering things up. I need to finish up the heater hoses, plumb the scavenge pump and get the right adapter fitting for the oil pressure switch.
Not much room left for anything. Good thing it doesn't need anything else!
Build thread
The last pieces are rolling in.
Build thread
Nice piece I ran the same one when I was bottom mount you won't be disappointed!
Ready to add oil. The only thing left underneath the motor is to wrap the downpipe.
Build thread
Looks like fine art! Can't wait to see some vids of this in action!
The to-do list is getting real short now.
Finished up the meth install, wrapped the downpipe so I don't melt my tie rod boot and started adding fluids.
Build thread
Build thread
What is the oil filter pump thing?
Scavenge pump for the turbo. Turbo is below the oil level in the pan so it can't gravity drain.
Build thread
Using a pair of 9mm spring pads on each side to get my front ride height back. Due to the added weight, I'm thinking of running Bilstein sports in front and Konis out back. It's my understanding that the Bilsteins have a much stiffer dampening. So logically it should work well for this.
Build thread
Had it on the road for the first time. Just a couple times around the block. Everything seems to be working as it should. The RXT clutch is awesome. It drives better than stock. VE table needs some work but that'll come with data logging.
https://youtu.be/ijOxx34lA1g
https://youtu.be/hAo9SrcVhYA
Build thread
Love the progress! In for dyno results!
