BMW E46 Fuel Delivery Parts, Fuel Rail, Injectors, Throttle Body, Fuel Tank Breather Valve & Fuel Vapor Smog Emissions Canister OEM Parts USED
"Donor Vehicle"
-2004 BMW 325xi AWD E46
These parts were removed from the donor vehicle listed above. All parts are in USED working condition. The have Cosmetic Used type wear to them but still function properly. You will receive everything pictured. You will receive the following..
-6 Siemens Deka Fuel Injectors
-1 Throttle Body Unit
-1 Fuel Rail
-1 Fuel Tank Breather Valve
-1 Fuel Vapor Smog Emissions Canister
The fuel rail is missing one of the clips on the bottom as can be seen in the photos above.
"Part #'s"
-Fuel Rail = 143894902
-Fuel Injectors = 1427240
-Throttle Body = 408238425004
-Fuel Vapor Smog Emissions Canister = 6752223
-Fuel Breather Valve - 1433602
Make sure you look over everything including part numbers & photos before making your purchase. These are USED parts, so what you see is what you get. Being that these are USED parts, it is unknown to know if these parts will work better than your current parts on your vehicle. Unless the part your replacing is broken or wore out, than the parts will work great for you.
List Date: 6/13/2015
For more info, click here to view the original listing: BMW E46 Fuel Delivery Parts, Fuel Rail, Injectors, Throttle Body, Fuel Tank Breather Valve & Fuel Vapor Smog Emissions Canister OEM Parts USED
This item is no longer available.
