You always want the lowest pressure possible in the relevant branch of the manifold as the exhaust valve opens as this will allow as much of the contents of the cylinder to be ejected as possible before the valve closes, thus allowing more oxygen to be drawn into the cylinder on the next intake stroke.
As I understand it, well tuned NA or SC engine exhausts use the kinetic energy of the exhaust gas from the previous cylinder to create a partial vacuum in the manifold at exactly the right moment (this is called exhaust gas scavenging); this isn't really possible on a turbocharged engine because the turbo restricts the exhaust gas flow too much. Thus in a turbocharged car, you want the air to simply flow as freely as possible to the exhaust outlet; however, for other engines back-pressure is used as part of the tuning technique to align the pulses correctly, so fitting a freer flowing exhaust to a N/A car can actually reduce power.
Here is some good technical literature based for this topic.. they used an M3 as an example.
http://www.autozine.org/technical_sc...riable-exhaust
Stancing is for drivers trapped in an abusive relationship of their own lives.
You had it until that last sentence, the lack of back pressure not being accounted for creates a lean condition, so when not tuned for correctly yes it causes issues. However that is failure of lack of tuning not the 0 back pressure. The second you adjust the tuning to accommodate the additional air flow allowed into the cylinder then your fine.
Without tuning yes low to no backpressure can cause issues. But it is not the overall problem. Lack of fuel becomes the problem.
Ok so now we're arguing about tuning and not the change in back pressure.
Like for like, same tune on the same engine, if you change the exhaust system to be one with 0 back pressure, the tune you had will reduce performance.
You will need to have your tune setup for the adjustment in back pressure drop.
What's going on? What all this shouting? We'll have no trouble here!
2003 M3CicM6 TiAg
Former:
1985 MB Euro graymarket 300SL
I think the missing link in this discussion is that changing the exhaust backpressure can impact scavenging. They are intertwined to a certain degree. So if, during a mod to reduce backpressure, you inadvertently screw up the tuned scavenging that the original exhaust provided, you could actually increase the amount of exhaust that is left in the cylinder for the next power stroke.
This can result in a loss in power at those rpm bands where the scavenging was negatively impacted to a greater degree than the backpressure was reduced.
The powerband is moved up. The power isn't lost. More air in isn't needed because there is always more coming in than needed. Now, may the car's stock rev limiter fall below where most of the gains are achieved? Sure. Power isn't lost. It's changed. Good headers or a good xpipe will help fix the need to keep low end.
I don't race at 4500 so for me, it serves it's purpose. Need to get some baseline runs in.
Inneressing. Nice setup, very clean. Would look even better w/ the Touring straight-out exit.
I could see doing a quieter version of that setup with a resonator at the first spot where yours is, then the 2-in-2-out flow-through muffler at the rear spot.
2003 M3CicM6 TiAg
Former:
I like the Touring tip idea. The only issue I currently have is with the HFC's and how low it sits, thats the first thing to scrape, followed by the magnaflow.
540i 6spd DUDMD tuned-weekend brute, sounds like an M5 throaty V8 "Vtec-ish" cam noise.
Hummer- 35inch MT's, Adventure offroad package.
check out my video gear
https://kit.co/Lv5multimedia/mobile-videographer-set-up
Best Oil hands down for bmw
https://www.amazon.com/gp/product/B0...1441c0abde2552
I am going to run the exact same setup, except I'll have an x pipe where you have the dual in dual out muffler, and a dual in dual out at the back of the car. X Pipe is where its at. nice H pipe setup tho! Share a clip with us! Headers are too expensive, but the rest is easy DIY welding whatnot. MCMNGNS will like this. 2 3/4"
Im no artist.
This is somewhat related but what type of gains can one expect from headers, rear exhaust work and a tune on the m62tu?
Ok, so i finally got it all installed.
THIS THING IS LOUD. Not like loud like "hey look at me I deleted my cats and resonator" loud, but like WHAT THE ACTUAL **** loud.
There is video, I will be uploading it soon. The video didnt truly catch the full effect of the sound the exhaust put down.. mostly because the mic on my phone couldnt keep up with it.
WHOA!! What is that exhaust setup now?
Supersprint headers for M62/S62 V8 SS PN# - 022 786 801 (Ceramic Coated)
Supersprint front connecting straight pipes (cat delete) SS PN# - 022 786 812
Supersprint Y-Pipe SS PN# - 022 785 912
Supersprint Connecting Pipe (resonator delete) SS PN# - 022 785 953
Dinan M-Sport Free Flow exhaust
Yeah, its essentially the muffler with the oval tip.
This is it here: http://www.dinancars.com/product/d66...ries&mid=1048/
Holy Nascar loud loud. That's wicked. You keeping it like that?
