1995 M3 turbo frankenstein motor OBD2 RK 6765 turbo TS (needs TLC to finish build)
car is almost done so leaving the rest to the new buyer has alott of potential
selling because I am starting a business and need the tied up funds so selling cheap
Car had a Texas salvage title but I put a lien on it to register it in CA to become clean title but the lien paper work will be delivered and can be registered with it to get a new title and could be salvage depending on the State. (like buying a car from a tow yard auction)
everything in the motor was bought new and turbo has under 1k miles m52 s52 crank are unknown miles
car needs alot of TLC wires hanging around, interior is in good shape but needs a cleaning and a set of used door cards are included since the original is falling apart since the car was in the shop for a long period of time.. needs new coilpacks one is weak and misfires from what david told me car dynod 644whp and 620wtq with 23ish psi
Tranny should be swapped.. leaking a little
I have alot invested but just need to move on
ONLY 99K Miles on Chassis
Interior is falling apart and needs TLC.. I have a Autopower rollbar that is included seats are extra $600
Mods
*200 Miles on frankenstein motor built 8:5.1 Wiseco Pistons and eagle rods, S52 Crank S52 Cams, heads resurfaced, Supertech Valve Springs and retainers, ARP Headstuds, O ring'd, new oil pump, new high performance timing chain.. built by davidtm5
*RK Custom dyno tune e85
*precision 6765 dbb with 1.15 and .84 twin scroll housings
*otis custom top mount twinscroll manifold
*66mm precision wastegate (recirculated) springs included
*3.5" Stainless exhaust with vibrant resonator and muffler
*115lb injectors
*4" intercooler
*UUC evo 3 SSK with DSSR
*UUC Twin Disk Clutch and flywheel kit
*UUC Sway Barbarians (rear not installed yet but included)
*AKG Motor and Tranny Mount
*RallyRoad Tranny brace
*Driveshaft Shop Driveshaft included not installed
*3" Intercooler piping
* No Seats.
* 4PT Autopower Roll Bar
* walbro 450
*boost a pump
* e85 fuel filter
*adjustable fuel regulator
Wheels and suspension are stock and should be replaced
Asking $10k
CALL OR TEXT ME 510-861-4902
2002 911 Turbo k16 billet, JIC Coilovers, GT3BBK, Cobb Mafless, Oz Ultra
