You need a rear sump for the e36/46.
1995 M3 - Forged 9.8:1 2JZ, S366, MS3x, E85, LQ9s, 420g/PMC Motorsport kit, 4 clutch 3.15 LSD Large Case 757whp/710wtq
2011 X5 Xdrive35d- Blk on Cinnamon, Towing Pkg, Heat Pkg., etc..the tow rig/DD!
Btw there is a 1jz and 2jz powered BMW Facebook group with about 2500 people in it that can help you.
Good deal!
Hi, I'm a newbie . Had jus bought a 1jz manual e36 . It is in a running condition , jus the rpm and water temp on the speedometer aren't working . Can that be hookup and work?
Yes. One of the water temp connectors on a factory harness runs back to the x20 connector and that will supply the coolant gauge in the cluster. Usually people will weld in a bung to give them a spot to put the factory bmw sensor.
Thank you for the help... I'll inform my mechanic about this and see how it goes. What about the rpm ? Any idea how to get it work ? Tq
