Does anyone run CAtuned coils on their e30? (or any coils that are rumored to be very similar). I'm curious how the rear is sitting on everyone's car. I maxed mine out and I feel like it barely dropped my car. Thanks!
I should be getting my set in the coming weeks. Just waiting on them to assemble. When I get them installed I'll drop em down and send pics to see if they are similar
Okay cool thanks! I live about 20 minutes from their shop so I just picked it up. Called them and told me that taking off the rubber guards would help lower the rear more. My brother took off the entire adjustment and all he had was the spring. Taking the top rubber guard will leave lots off room for the spring to move, so what I did is cut out the flat part and left the middle part of the guard so I'd get both the support and about a quarter of an inch drop on the rear. Might take off the entire height adjustment in the future.
I know this is an old post but I just came across it and I seem to be having the same problem … I just installed my CA Tuned coil overs on my E30. I set them for as low as they would go. I like how the front is sitting, the wheel is tucked. But the back still has a bit of a wheel gap. I was thinking about taking off the rubber guards and adjustment but I wasn't sure if that was safe or if that would fuck anything up.
You said your brother took off both the rubber guards and adjustments ring? Is there still tension on the spring? It seems like it would sit in there pretty loosely if I took out the rubber guards.
Thanks for your time!
