Results 1 to 25 of 27
Thread: Deadlocked Driver's Door- STUCK CLOSED
    Jan 2015
    Connecticut
    1993 BMW 740iL
    I was experiencing problems with my driver's door. Typical situation of not going up all the way, so I had to open the rear door, reach in and pull the knob up manually to open the door. Irritating but not critical. Having resolved more pressing problems with this car and the wife's ride, I turned my attention to this inconvenience.
    I pulled the panel off the door and found the bracket was cracked. I fixed the bracket with a piece of sheet metal epoxied over the crack. (Same idea as Johan and Sean's rivet fix, but removal of the bracket was not necessary and I think the repair is probably stronger.) Thinking I fixed the problem, I put the door back together and left the car overnight for the epoxy to fully cure.
    When I went to check the car today, it locked fine. But now the driver's door will not unlock from the outside with the key or from the inside with the knob. All the other locks function normally, but the drivers door is now deadlocked. I cannot lift the locking knob or open the door at all. Obviously this is not workable in a daily driver. (It may have been doable when I was half my age, but climbing over the console is not going to work for me now.) So now I've moved from irritation to serious problem.
    On top of that, the door is locked closed. As a result, I see no way to remove the panel in the normal fashion. I found one post where the owner cut a hole in the door panel to access the locking mechanism. If at all possible, I'd prefer not to go that route, or cause any other damage.
    I tried the "Emergency Procedure in the Owner's Manual, but found I could not turn the key past 45 degrees. Should I "force it" to turn further, or is that process for a different problem?
    So what is our collective insight for solving this problem? Specifically, is there a way to open the door when it is in this state? Or is there a way to remove the panel or otherwise access the mechanism from the inside with the door locked shut? (Once I get the door open I'll need to know why it deadlocked, so suggestions on that front are also welcome.)
    Thanks in advance, Craig
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    I have saved this vintage copy from an E34 rear door lock opening:
    E34 locked rear door procedure
    Special repair note: If the rear door lock actuator fails when the door is locked, the door cannot be opened to replace the actuator. The following procedure can be used to open the door without cutting the door trim panel.
    -remove 3 screws retaining door trim panel at upper mount of grab handle, inside door release handle, and behind ashtray. Remove plastic door knob.
    -Open the window and, using a putty knife or trim removal tool, carefully pry the uppermost part of the door trim panel away from the chrome trim by the window opening to get the upper retaining clips to release. The insertion of the tool is eased somewhat by pressing down on the trim panel.
    -Carefully pry the trim panel back, and use a small block of wood or screwdriver handle to hold it away from the door.
    -Use a long, thin screwdriver to reach between the trim panel and door, and peel the insulating sheet away from the door so that you can see the end of the lock actuator.
    -Use a bar, or a long, heavy screwdriver to reach inside the door and contact the white plastic end of the actuator that the lock linkage hooks up to. Hit the end of the tool so that the white plastic end breaks off, disconnecting the linkage from the seized actuator. The door can now be unlocked and you may proceed with the repair in the usual manner.
    Maybe that also works on the E32 front door
    NYC & Long Island & So FL
    '93 740il '84 633Csi
    I want to see the Youtube version of that. Sounds like you might have some luck with a "slim jim"
    Jan 2005
    Japan
    I hope he makes pics and a detailed instruction how to....
    Jan 2015
    Connecticut
    1993 BMW 740iL
    Well, I guess I know how I'm spending this weekend.
    Hopefully I'll be able to report some success.
    Thanks, Gents
    Brantford ON Canada
    735iL - 1989
    Quote Originally Posted by Craigtd View Post
    There are 2 motors inside each of the four door lock actuators. One motor locks and unlocks the door, and the second motor sets and releases the deadlock.
    You want to operate the deadlock motors, to release them. Open the 3 doors (for safety!) and lift the rear seat. Remove the RM module from its sockets.
    Locate pins 1 and 14 on the BLK socket connector (X258), and insert a finishing nail into each of these 2 contacts. Pin locations in X258 are shown on pg 8500-05 of the ETM.
    Now use a 12V booster pack and briefly (1 second) connect NEG to pin 14 and POS to pin 1. You will hear the deadlock motor operate in the drivers door, releasing the deadlock. Now you can open the drivers door as normal.
    Wiring shown on pg 5126-02 and 03. Again, leave the 3 doors open while you are doing this, for safety!
    To prevent any future deadlocking, cut off pin 14 of the RM.
    Jan 2005
    Japan
    Good that we have the expertise of E32Fan.
    RM pinout, scroll down here http://www.e32-schrauber.de/bmw/s-sicherungen.htm
    Tabelle 5: RM x258 black connector, Pin 1 is ZV motor front left and right
    I have here also the GM pinout:
    Central body electronics ZKE = GM pinout
    Central body electronics (ZKE) Scheme 6100.0
    Pin Assignment
    A=X253 26-pin, green
    B=X254 26-pin, white
    C=X255 26-pin, yellow
    D=X332 5-pin, white
    E=X258 20-pin, black
    F=X259 20-pin, white
    Pin Assignment X253
    Pin Type Description/Function Connection
    1 A Activation, FH relay in RM Relay module (RM) Pin E3
    2 A Activation, FH relay in RM Relay module (RM) Pin E1
    3 A Activation, wiper relay Relay module (RM) Pin F9
    4 A Activation, TSH relay in RM Relay module (RM) Pin F17
    5 A Activation, relay arrest Relay module (RM) Pin F4
    6 not used
    7 A Lock signal Rear lid lock switch
    8 A OZV signal of ZV DWA module
    9 A Crash information output Crash alarm generator
    10 A Electronic power fuse Fuse relay
    11 E Position signal Instrument cluster
    12 E/A TxD diagnostic link Diagnostic connector
    13 E Diagnostic link for ZV relay Relay module (RM) Pin E9
    14 A Activation, SHD relay in RM Relay module (RM) Pin E4
    15 A Activation, IA relay in RM Relay module (RM) Pin E2
    16 A Activation, IB relay in RM Relay module (RM) Pin E7
    17 A Activation, relay lock Relay module (RM) Pin F3
    18 A Activation, relay unlock Relay module (RM) Pin F2
    19 A Activation, SRA relay fog light SRA module
    20 not used
    21 not used
    22 A Activation, washer pump relay Washer pump relay
    23 E Crash sensor Inertia switch
    24 A RxD diagnosis line Diagnostic connector
    25 E Diagnosis line for wiper relay in RM Relay module (RM) Pin E10
    Z6 E Diagnosis line for door lock heating Relay module (RM) Pin E19
    Pin Assignment X254
    1 not used
    2 E Rear position sensor Position sensor
    3 E Diagnostic link for FH/SHD relay in RM Relay module (RM) Pin E8
    4 E FH switch, FH passenger's side rear open Power window switch (FH)
    5 E FH switch, FH driver's side rear open Power window switch (FH)
    6 E FH switch, FH passenger's side open Power window switch (FH)
    7 E Rear end position sensor, driver's side End position sensor
    8 E FH switch, FH passenger's side closed Power window switch (FH)
    9 E End position sensor, passenger's door End position sensor
    10 E FH switch, FH passenger's side rear closed Power window switch (FH)
    11 E End position sensor, driver's door End position sensor
    12 E FH switch, FH driver's side rear closed Power window switch (FH)
    13 A Activation, FH relay in RM Relay module (RM) Pin E5
    14 not used
    15 not used
    16 E Diagnostic link for FH/SHD relay in RM Relay module (RM) Pin E18
    17 E SHD switch lift open Sunroof switch (SHD)
    18 E SHD switch close Sunroof switch (SHD)
    19 E SHD switch slide open Sunroof switch (SHD)
    20 E FH switch, FH driver's side open Power window switch (FH)
    21 E FH switch, FH driver's side closed Power window switch (FH)
    22 E Rear end position sensor, passenger's side End position sensor
    23 E FH switch, FH passenger's side rear closed Power window switch (FH)
    24 E FH switch, driver's side rear closed Power window switch (FH)
    25 A Activation, FH relay in RM Relay module (RM) Pin E7
    26 A Activation, FH relay in RM Relay module (RM) Pin E6
    Pin Assignment X255
    1 E Passenger's door contact Door contact switch
    2 E Driver's door handle contact Power window switch (FH)
    3 E Rear door contact Door contact switch
    4 E Switch stage 1 , 2, single wipe Wiper switch
    5 E Switch position, intermittent wipe Wiper switch
    6 E Switch position, wash Wiper switch
    7 E Detection, lock Infrared module
    8 E Switch position, intensive wash Wiper switch
    9 E Terminal 15 for GM Fuse
    10 E Terminal R for GM Fuse
    11 E Detection, lock Central locking drive
    12 not used
    13 not used
    14 E M Sedan: Front position sensor Touring: Ground Position sensor Ground connection
    15 E Driver's door contact Door contact switch
    16 E Detection, arrest/unlock Infrared module
    17 E Detection, unlock Central locking drive
    18 E Parking light detection Light switch
    19 E Terminal 50 load cutout Starter
    20 E Detection, lock Central locking drive
    21 E Diagnosis line for SRA module Headlight washer system module
    22 E Reset contact Wiper motor
    23 E Detection, unlock Central locking drive
    24 E Detection, arrest/unlock Lock contact, driver's/passenger's door
    25 not used
    26 E Detection, fog light Fog light switch
    Pin Assignment X332
    1 E B+ for GM electronics Relay module (RM) PinFS
    2 E Ground for GM electronics Ground connection
    3 not used
    4 E Electronic fuse Fuse relay
    5 E Electronic fuse Relay module (RM) PinF11
    Pin Assignment X258
    1 E Activation, FH relay in RM General module (GM) Pin A2
    2 E Activation, FH relay in RM General module (GM) Pin A15
    3 E Activation, FH relay in RM General module (GM) Pin A1
    4 E Activation, SHD relay in RM General module (GM) Pin A14
    5 E Activation, FH relay in RM General module (GM) Pin B13
    6 E Activation, FH relay in RM General module (GM) Pin B26
    7 E Activation, FH relay in RM General module (GM) Pin 25
    8 A Diagnosis line for FH/SHD relay in RM General module (GM) Pin B3
    9 A Diagnosis line for ZV relay General module (GM) Pin A13
    10 A Diagnosis line for wiper and ZV relay General module (GM) Pin A25
    11 A Activation, FH motor drives passenger's side Power window motor (FH)
    12 A Activation, FH motor drives passenger's side Power window motor (FH)
    13 A Activation, FH motor drives passenger's side Power window motor (FH)
    14 A Activation, SHD motor Sunroof motor (SHD)
    15 A Activation, FH motor driver's side Power window motor (FH)
    16 A Activation, FH motor drives driver's side and SHD Power window/sunroof motor
    17 A Activation, FH motor drives driver's side Power window motor (FH)
    18 A Diagnosis line for FH/SHD relay in RM General module (GM) Pin B16
    19 A Diagnosis line forTSH General module (GM) Pin B26
    20 M Ground for power windows and SHD Ground connection
    Pin Assignment X259
    1 A Activation, actuator drives Central locking actuator drives
    2 E Activation, relay unlock General module (GM) Pin A18
    3 E Activation, relay lock General module (GM) Pin A17
    4 E Activation, relay arrest General module (GM) Pin A5
    5 A Terminal 30 for GM General module (GM) Pin D1
    6 A Activation, IB lights Interior lights (IB)
    7 E Activation, IB relay General module (GM) Pin A16
    8 E Activation, wiper relay (stage 2) Wiper switch
    9 E Activation, wiper relay (stage 1) General module (GM) Pin A3
    10 M Ground for wiper and interior light Ground connection
    11 E B+ for RM function circuits General module (GM) Pin D5
    12 M Ground for central locking system Ground connection
    13 A Activation, actuator drives Central locking actuator drives
    14 A Activation, actuator drives Central locking actuator drives
    15 E Terminal 30 for RM control circuits Fuse
    16 A Activation, TSH heating Door lock heating (BH)
    17 E Activation, TSH relay General module (GM) Pin A4
    18 A B+ for wiper motor stage 1 Wiper motor
    19 A B+ for wiper motor stage 2 Wiper motor
    20 E Activation, wiper relay in RM Wiper relay
    E = Input, A = Output, M = Ground
    This is from
    5 Series - E34 (518i, 520i, 525td, 525tds, incl. touring) Schematics Model year 1994 Central body electronics (ZKE) Scheme 6100.0
    should be same for E32, http://download.golgofa.ru/valera/ET...ow_ETM/6100.0/
    Quote Originally Posted by E32FAN View Post
    Just to clarify the lingo. By "deadlock" do you mean "deadbolt" or am I not correct?
    --Ken
    Brantford ON Canada
    735iL - 1989
    If the actuator is unlocked and you pulse the deadlock/deadbolt motor, then when you next lock the actuator, it will STAY LOCKED.
    It is not possible to unlock the actuator either electrically or manually, until the deadlock/deadbolt is released.
    I never want my actuators to deadlock/deadbolt, so I always cut off pin 14 of X258.
    So it is the same thing. Just checking as I thought a lock has tumblers while a bolt does not
    Brantford ON Canada
    735iL - 1989
    Yes, the actuator is just an electric actuator device that pushes or pulls a linkage rod, quite separate from the keyed door lock cylinders.
    The key turning in the lock cylinders is opposed by the actuator rod, which refuses to move at all, when deadlocked.
    Jan 2005
    Japan
    Here are some pics of a disassembled door lock barrel for easier understanding http://www.evansweb.info/2003/01/18/...l-replacement/
    Door lock mechanism http://bmwe32.masscom.net/sean750/do...kMechanism.htm
    Door lock microswitch http://bmwe32.masscom.net/johan/door...croswitch.html
    Brantford ON Canada
    735iL - 1989
    As shogun notes, there are 12 wafers in the lock barrel. BUT. we don't truly need to maintain all 12 of these. We could use just 5 or 4 or 3 or even 2 wafers and our key would always unlock our door.
    Car thieves will not expect that we have dropped our guard from 12 wafers to 2, say.
    I have not spied any car thieves lusting to steal my 26-year old BMW 735iL sedan. (I wish they cared for her!)
    Jan 2015
    Connecticut
    1993 BMW 740iL
    Just to update those with interest, I followed E32FAN's instructions as far as I could and had success. All I needed to do was remove the General Module from its socket and the actuators pulsed. After that, I had no trouble locking and unlocking the door. (I also took advantage of the rear seat removal and did a "magic reset.")
    However, the disabling instructions were over my head. I'd like to disable the deadlocking feature as E32FAN suggested, but feared pulling the wrong pin. What does "Pin locations in X258 are shown on pg 8500-05 of the ETM" refer to? I couldn't find a black socket in the GM and couldn't tell which one of the four sockets was number X258. Are there more detailed instructions or guidance available on this topic?
    Thanks, Craig
    Jan 2005
    Japan
    The colours are there to identify the sockets
    in the GM
    x253 26 pins GREEN
    x254 26 pins WHITE
    x255 26 pins YELLOW
    x332 5 pins BLACK
    in the RM
    x258 20 pins BLACK
    x259 20 pins WHITE
    The pinout is shown on page 8500-05 http://shark.armchair.mb.ca/~dave/BMW/e32/e32_93.pdf that is close to the end of the ETM, there you see diagrams/drawings of all the plugs under connector views with all pins shown and where they are.
    Jan 2015
    Connecticut
    1993 BMW 740iL
    I didn't know what the "ETM" was. Now I do, and where to find it. Once again, thank you Shogun and E32FAN.
    Quote Originally Posted by shogun View Post
    Erich,
    I looked on realoem for the microswitch but all I found was the door lock assembly. If I replace e the whole thing I guess I should order your door latch gaskets?
    Jan 2005
    Japan
    Depends on your door handle (cover) gasket condition, anyway, I have the gaskets on stock, whenever you need.
    Quote Originally Posted by Sansouci View Post
    Erich,
    Do you have a p/n for the microswitch?
    Jan 2005
    Japan
    This one? http://bmwe32.masscom.net/johan/door...croswitch.html so there you can see the old no is 1390873.2
    now you go to www.realoem.com and look under electrics and you find the new part no.
    Must be one of these http://www.realoem.com/bmw/enUS/show...diagId=61_0770
    For vehicles with CENTRAL LOCKING SYSTEM =Yes 05 MICRO SWITCH LEFT 1 61311390885 $38.47 05 MICRO SWITCH RIGHT 1 61311390886 $38.47 ENDED
    then you copy that no. and use google search for images and you find....https://www.ecstuning.com/ES166768/
    61311390886: MICRO SWITCH RIGHT From:12/20/1989 To:12/18/2012 (ENDED) Weight:0.034 kg Price:$38.47 Superseded by: 61311374458
    http://www.bmwetk.info/parts-catalog...69/61311374458 (06/01/1986 — ), Bilaterally exchangeable
    Part 61311390886 was found on the following vehicles:•5' E34   (03/1987 — 12/1996) •7' E32 (10/1985 — 08/1994), (06/01/1986 — ),
    Bilaterally exchangeable Part 61311390886 was found on the following vehicles:•5' E34   (03/1987 — 12/1996) •7' E32   (10/1985 — 08/1994)
    check the pics with yours, if they look same, you got it.
    Many thanks. I had been looking under the door lock page and never figured there was a separate list for switches. I feel stupid not looking deeply enough.
    Regards,
    Ken
    Oct 2007
    Boca Raton, Florida
    89'750iL,98'740iL,00'M5
    I had no idea there was a separate section for "various switches"... I too was looking under the door lock section. My driver's door has stopped locking in the past few months. It would lock fine via the trunk or passenger lock, but after a battery disconnect, the door locks had to be resynchronized. Impossible to do when the drivers door will not register the key's position. Have not had locks due to this. I also have lately had the door locks unlock when locking from the inside. They just pop back up as soon as I push it down on the drivers door. This is typical when it needs to be re-synched. Hopefully it is not a bad servo.
    Have to pick one of these up.
    BMW 7er Website www.7er.com
    1989 BMW 735i Schwarz (sadly, sold) // 1989 BMW 750iL Cirrusblau Metallic // 1998 BMW 740iL Oxfordgrün Metallic // 2000 M5 Carbon Schwarz ///
    Jan 2005
    Japan
    There is wrong feedback to the GM, because one lock does not work, then it unlocks again to tell you. Here described :
    This Service Information Bulletin supersedes S.I. 61 01 92 (3460) dated January 1992. It incorporates additional information on the new General Module software for E32/E34 vehicles.
    Please remove and discard S.I. 61 01 92 (3460) dated January 1992 from your S.I. Binder.
    SUBJECT: New General Modules (GM) MODELS: 7 Series (E32), 5 Series (E34)- Vehicles produced 9/91 and later
    Situation: New general modules have been used in production since September 1991 in all E32 and E34 models. The software has been completely revised (details of these revisions are found in the attachment to this Service Information Bulletin). Part numbers have been changed to reflect these revisions, as listed below, as of September 1991. Model Part Number
    E32 61 35 8 356 095,
    E34-up to 61 35 8 356 095 9/91 production
    E34-9/91 and later production 61 35 8 355 812
    Note:
    E34 vehicles produced 9/91 and later have different central locking system components from earlier E34 vehicles; therefore, P/N 61 35 8 355 812 is used only in E34 vehicles produced 9/91 and later, P/N 61 35 8 356 095 can be used in E34 vehicles produced prior to 9/91, and in all E32 vehicles. When the general module is connected to the vehicles electrical system, it will recognize (and store in memory) the vehicle configuration, such as:
    - with/without power windows
    - With/without power sunroof
    - with/without wiper contact pressure control
    - with/without headlight washers
    Important Information
    All general modules must be plugged in only after disconnecting the vehicle's battery. If the vehicle's battery is connected when the GM is installed, undefined signal contacts can cause an incorrect vehicle configuration to be stored, resulting in the impairment of
    one or more of the above-mentioned systems. If one or more of the GM functions are impaired in this matter, the GM can be "cleared" by disconnecting the vehicle's battery for at least ten seconds.
    GM Function Changes E32/E34 (Beginning with 9/91 Production)
    - Repeat and Time interlock for headlight washers:
    · Time interlock: 3 minutes
    · Headlight washing at fifth windshield washing after time interlock.
    - Intensive washing pump operating time reduced from 3 to 2 seconds
    - Minimum interval for intermittent wiping is programmable down to 2 seconds (previously 3 seconds)
    - Increased wiper contact pressure during windshield washing cycle is now also provided during dry wiping portion of the cycle (previously only during washer pump operation).
    - Previously, the GM would react to opposing signals (eg., an unlock signal while trying to lock, as with a defective microswitch) by carrying out the first command, then the opposing command (e.g., locking, followed immediately by unlocking).
    Repeating the first command then results in carrying out that command (e.g., try to lock again, and locking is now carried out).
    This function ("Asynchronous Position") is omitted in the new GM for all E32 models and E34 models prior to 9/91 (P/N 61 35 8 356 095), and remains in the new GM for E34 models after 9/91 (P/N 61 35 8 355 812) only for central locking commands "lock" and "double-lock".
    - After unlocking is performed due to crash sensor activation, the locking command is now reactivated by double-locking with the key from either the driver's or passenger's door.
    - The "one-touch" operation of windows has been expanded to include all four windows in the opening direction. The driver's window still has "one-touch" operation in both opening and closing directions. Interruption of the "one-touch" feature of the driver's window in the closing direction is still accomplished by depressing any window switch (in any direction), or by depressing the sunroof switch in the "tilt" direction (provided the sunroof is not already in the "tilt" position). Interruption of the "one-touch" feature of the sunroof in the closing direction is still accomplished by depressing the sunroof switch (in any direction).
    - The switch-off delay of the interior lights which occurs after entering the vehicle and closing the driver's door has been reduced from 20 seconds to 15 seconds.
    Dec 2005
    Baltimore, MD
    81 Scirocco-92 750il
    I know i'm late to this but mine had the same problem and it was simply because the locks were out of sync. I simply went to the pass door and locked and unlocked the car and kapow, the drivers door unlocked.
    So after a 2 year hiatus with the car in storage, I am planning my spring repair program. Before I take apart the door lock to replace the microswitch, I wanted to be sure of my diagnosis. The passenger front door will lock and unlock all the doors. The driver's door will lock all doors but not unlock all doors. What is the best approach to test the system to identify the problem?
