Page 23 of 47 FirstFirst ... 131415161718192021222324252627282930313233 ... LastLast
Results 551 to 575 of 1152
Thread: The Z3 Diagnostics Thread: Instructions, Experiences, Discussions, Experimentation
  1. #551
    Oct 2017
    england
    2002 BMW Z3
    Well guys think I’ve sorted it, decided to trawl through the wiring diagrams and checked all the wires on the steering sensor and there was a bad ground, shorted it to ground and all lights out yay just need to find ground point X492 now.
  2. #552
    Dec 2007
    Great Dismal Swamp
    E36/7 E36/8x2 E46 F25
    Left inner fender by the airbox.
    /.randy
  3. #553
    Oct 2017
    england
    2002 BMW Z3
    Many thanks wire had corroded in the lug, replaced lug and now all seems fine
  4. #554
    Jan 2015
    Timaru, New Zealand
    Two Z3 Roadsters
    Was working on a 2007 Z4 M54B30 engine yesterday. Couldn't find a E85/E86 section in INPA. Finally found a model that covered the M45 DME/M54B30 combination needed to completed the engine work.
    There is more work to be done on the ABS. Is there a separate E85/E86 section or are they equivalent to another model?
    Using the standard INPA install as per post 1 with your modified start menu function keys.
    1999 2.8L Z3 Roadster,
    2000 3.0L Z3 Roadster,
  5. #555
    The eBay cables seller has 8% off right now, my total was $12.84 for both cables
    PRICE CUT on ALL FABRICS
  6. #556
    Jan 2015
    Timaru, New Zealand
    Two Z3 Roadsters
    Quote Originally Posted by Muzz258 View Post
    Couldn't find a E85/E86 section in INPA...
    Edited the INPA.config file today to swap in the E85/86 section in place of one of the Mini's. The lead got pins 7-8 soldered and the programming changes to enable connection to later model BMW's. All set now for working on Z4's.
    Thank you for the excellent support documents in Post 1.
  7. #557
    Washington, D.C.
    S54 e36/8
    I'm going to spend some time getting set up with these tools this year. The M5 is getting old and needs some work, so these tools should help.
    I was googling around and reading other forums, and as of the time of me writing this, I haven't searched here yet, but is ISTA-D the newer preferred tool? Has anyone started a thread on how to set this up for our cars/eXX series cars?
    Happy New Year All!
  8. #558
    Jul 2004
    Houston, TX
    36 Cylinders
    Quote Originally Posted by fmcfad01 View Post
    Happy New Year All!
    ISTA - D is the dealer's program. It uses all the INPA/EDIABAS protocols in a pretty graphics user interface.
    It's a commercial paid program or through rental service, so it can't really be posted here.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
  9. #559
    Washington, D.C.
    S54 e36/8
    fair enough, but it's available on *other* BMW forums...
    I'll start here with INPA
  10. #560
    Dec 2011
    Riga, Latvia
    2x 1997 BMW Z3 2.8
    Abel, I can confirm that INPA and other software works fine on my MacBook with macOS and virtual Windows images (Win7, WinXP) through VirtualBox software. Maybe you want to update first post with that info. (Havn't tried your packages, but others work well.)
  11. #561
    Oct 2017
    england
    2002 BMW Z3
    Well cars been running fine till today, dsc lights came back on again ahhhhhhhhhh. connected computer and error code 5E30 lateral acceleration Sensor electrical failure checked dsc sensors and the offset lateral acceleration is in the red??? file attached What could cause this??. have had lots of rain wonder if its got wet again??
    Cheers
    Attached Files Attached Files
  12. #562
    Jul 2004
    Houston, TX
    36 Cylinders
    Quote Originally Posted by tazmantic View Post
    Cheers
    When you replaced it last time, did you do the calibration procedure (described somewhere in this thread)?
    If yes, you can do the calibration again, which will make it work for a while... But eventually it fails again. Mine did.
    I doubt it's water. My sensor was dry and it just lost calibration again and again.
    Something must be failing inside it.
    -Abel
  13. #563
    Oct 2017
    england
    2002 BMW Z3
    Thanks for the reply, I didn't replace it in the end I just left it inside in the warm and it then started reading ok, so maybe it has failed but last time it was the left hand side that was full scale but this time its on the right (dsc reading from before attached)
    Cheers
  14. #564
    Jan 2018
    Germany (NRW)
    1x 1998, 1x 1999 Z3 QP
    @328 Power 04: thx for the awesome step-by-step guidline (INPA/EIDIABAS ...); using this tool on an old IBM T61 laptop with Win10 and Xp-emulation mode - works fine for my Z3 Coupe FVL with ODB1-Adapter connected to USB :-)
    Q: I suspected that the mileage of the speedometer does not correspond to the actual mileage - a look into the central computer of BMW brought me to that! With INPA, I can only read the total distance in the instrument cluster. In the TIS I had found something according to which an "error 01" indicates manipulation - and this error is also indicated with me.... theoretically the EEPROM could probably be "defective" - right?
    Is it possible to read out the total mileage at any other place?
    I have linked the current printout from INPA - aren't the far too high (?) values for SIA and the inspection intervals or the missing production date of the vehicle very strange?
  15. #565
    Jul 2004
    Houston, TX
    36 Cylinders
    This is on the 99 Coupe?
    The only places that km are stored are in the Kombi and in the Kombi coding plug.
    Unfortunately it's very easy to change the km in the Kombi, and not impossible to change in coding plug too.
    In Europe, it seems everyone is changing the km... so everyone is buying a car with more than advertised. There are businesses dedicated only to 'mileage correction'.
    There isn't an easy way to read the mileage from coding plug, but if the tamper dot light is on, then there is a mismatch between kombi and coding plug.
    At the bottom half of this page http://www.bimmerinfo.com/E36_OBC_tricks.htm
    are some KOMBI test menus.
    If you run test function 9 on KOMBI, it will sync KOMBI and coding plug eeproms to highest recorded.
    Also, the cold will sometimes throw eeprom errors on these models' kombi.
    -Abel
  16. #566
    Jan 2018
    Germany (NRW)
    Thx for answering ... and Yes - it´s on the 99 Coupe.
    What do you mean with (Kombi) "coding plug" - the ignition keys?
    Btw - guess INPA told me that in sum 5 keys would be "activated and used"...sounds like the two i own would not be saved the right mileage :-/
    Could you submit a picture/example of the "tamper dot light" please?
    Maybe i try to run function 9 on KOMBI to syn with coding plug EEPROMs - but can I be sure that the true mileage is stored here?
  17. #567
    Jul 2004
    Houston, TX
    36 Cylinders
    The coding plug is a physical plug in the back of the kombi, it contains an additional eeprom for security.
    It can be used to transfer instruments data.
    The keys do not store km.
    -Abel
  18. #568
    Oct 2013
    Augusta, GA
    1999 Z3 M-Roadster, 2007
    I went through your installation instruction on my Windows 10 Op system on a 64 bit machine. I plugged the USB OBD connector into my car (18 pin), turned the key to position 2, and clicking on the E36 button gives me no information about the status of the engine - nothing happens when I click on any other buttons either. The INFO button gives this output:
    The question marks after "INI Path," "Ecu path," and "Interface" imply to me that something went wrong with the installation. Do you have any hints on how to fix this?
  19. #569
    Jul 2004
    Houston, TX
    36 Cylinders
    There's nothing wrong so far. Click on E36 and choose MS41.1 for your M52/S52 engine (double click), and see if it logs into your DME. Then go to error menu.
    Follow the pdf on how to clear an error for ideas.
    -Abel
  20. #570
    Oct 2013
    Augusta, GA
    That seems to have worked. Why MS41.1? Why is there nothing that looks like it references my S52 engine?
  21. #571
    Jul 2004
    Houston, TX
    36 Cylinders
    S52 is a slightly hopped up M52 engine, that is ran by the MS41.1 DME.
    -Abel
  22. #572
    Jun 2017
    VA
    2008 135i coupe 6mt
    First, thanks for taking the time and effort to do the DIY and to keep it up to date for years! I'm installing INPA in a friends laptop and came across you're thread. I especially appreciate that you're DIY instructions and install process are definitely more streamlined and convenient than others I've read when installing on my own laptop.
    (Windows 10 32bit, 2008 E82 135i)
    Second. I followed the instructions and INPA works and can read from the DME, but when I try and check the airbag module I get the "sys-0012 IDENTIFICATION ERROR". Tried to search on forums and google but can't get a clear answer. Any thoughts?
  23. #573
    Jul 2004
    Houston, TX
    36 Cylinders
    Quote Originally Posted by danksies View Post
    Are you using a K+DCAN cable with pins 7&8 UN-bridged? (This is the correct specific setup for this car)
    -Abel
  24. #574
    Jun 2017
    VA
    2008 135i coupe 6mt
    The K+DCAN cable is not bridged at the 7 and 8 pins
  25. #575
    Jul 2004
    Houston, TX
    36 Cylinders
    Are other modules communicating?
    DSC and the like? CAS?
    -Abel
