Results 1 to 13 of 13
Thread: INPA/ista connection
    Dec 2012
    Placerville
    97 318I, 01 325ci
    I have both OBD EX and vlinker FS cables. I cannot get either to work on my laptop with windows 10. OBD EX worked previously.
    INPA doesn’t see the cable and I suspect the same is true for ISTA.
    Can anyone help me with connecting? I’m at my wits end here
    Dec 2012
    Placerville
    97 318I, 01 325ci
    Is there another forum that can help me with?
    Jul 2004
    Houston, TX
    36 Cylinders
    Short of being there in front of that computer, it's really challenging to get a sense of what's going on.
    Can you provide a lot more detail and elaboration on it?
    Are your drivers installed, COM ports you said are fine. The cable brands you mentioned are China names, so it's impossible to know what that actually means in terms of cables, etc.
    Then there's a bunch of car specific settings that require configuration and more info about.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Dec 2012
    Placerville
    97 318I, 01 325ci
    Drivers installed. Port settings are set as requested by hardware. INPA simply doesn’t find the cable. I really don’t have more info to offer…
    So frustrated because this is the only way I’m going to get the codes I need. My other scanner won’t pull them.
    Jul 2004
    Houston, TX
    36 Cylinders
    Sigh, you're not making it easy to help you.
    What car exactly are you trying to diagnose?
    What is your configuration like in ediabas, ista, etc?
    What does your cable look like?
    More info is better than none. Pictures, anything.
    -Abel
    Dec 2012
    Placerville
    97 318I, 01 325ci
    Ok, sorry. 2009 BMW 328. Dell laptop running windows 10
    I don’t know what other info I can offer
    Jul 2004
    Houston, TX
    36 Cylinders
    What does your obd.ini file say?
    -Abel
    Dec 2012
    Placerville
    97 318I, 01 325ci
    This?
    Jul 2004
    Houston, TX
    36 Cylinders
    Also it looks like OBD Link EX is an ELM327.. not ideal at all. You should get a K-DCAN cable with a switch. Switch is for going between dual K line and DCAN
    -Abel
    Dec 2012
    Placerville
    97 318I, 01 325ci
    So this won’t work? I swear I used it once before?
    Jul 2004
    Houston, TX
    36 Cylinders
    On the 2009 E90?
    -Abel
    Dec 2012
    Placerville
    97 318I, 01 325ci
    Correct. Both of these cables supposedly switch automatically…
    I’m 90% sure I’ve used it before with ISTA+ less sure about INPA (my German is no good)
    Dec 2012
    Placerville
    97 318I, 01 325ci
    Cable allegedly switches automatically
  1. INPA/NCS Connection issue
    By blatant in forum Diagnostic Software
    Last Post: 12-10-2013, 09:22 PM
  2. INPA not connecting (no black circles)!
    By V8Z4 in forum Diagnostic Software
    Last Post: 10-07-2012, 05:47 PM
  3. INPA not connecting to DDE5 (E46 330D M57N)
    By kristsm in forum Diagnostic Software
    Last Post: 08-20-2012, 02:55 AM
  4. INPA/EDIABAS connection problem
    By cclassen in forum Diagnostic Software
    Last Post: 01-09-2012, 07:40 AM
  5. Got INPA working connected but registry error
    By 99frc in forum Diagnostic Software
    Last Post: 07-16-2010, 09:07 AM
