First video on Youtube...not ready for prime time yet. I should have used a script and a monitor to see what I was recording.
Think I forgot to show the final torqueing of bank 1 exhaust sprocket and repeated one section twice.
I had recorded this in 1920x1080HD but really had to trim it down, edit the crap out of it, and convert it to MP2 so I could upload it, quality is still pretty good.
No more P0011 and P0021 posts please.
Make sure you have the bank 1 cams set correctly, this is shown at the 20 sec mark in the first video.
Here is that pic. The #1 cylinder lobes are tipped toward each other and are close to pointing to the nuts on the cam caps.
I can also supply rebuilt vanos using BesianSystem o-rings.
Part 1
Part 2
Edit:
Should have also said to have all the plugs loose or out, much easier to turn the engine over by hand.
Added pic and more text.
Now our famous Jim stars in his own movies. Great stuff. Looks like you had YT stabilize the video?
2003 Ferrari Red M3 3.5L wagon // 2011 Montego Blue tri-turbo 335d wagon
2012 Deep Sea Blue X5d // 2003 Orient Blue 330i wagon
In progress/For Sale: 2003 Alpine White M3/ZHP wagon // 2003 Japan Red M3/ZHP wagon
Pass the popcorn, both parts take ~12 min.
I did see some message pop up about stabilizing it. How did you know they did that?
I can tell based on how some of it is pixellated (nothing to worry about though). Great vids, just finished both. Makes it look easy but I still think I'ma invite you over for a nice few meals and beers and get your personal help someday!
Sure, no problem. Was planning on looking you NC guys up next time I'm in Cary.
Just watched them both. Looks a lot less scary after watching it.
Nice job editing. You may have a future as the next U-tube E39 sensation. Maybe some good tunes in the background.
No gloves, nice shirt, your car is clean!! I'm addicted using the nitrile gloves anymore on my dirty engine.
One question: Do the trigger wheels tend to rotate a slight amount when you tighten the outer nut? I did not see them move at all while you were doing it, but I could see that potential and maybe that is why some get the codes afterwards? I see the tool holds them, but its kinda a wonky set up and cant see how they can really hold the wheels perfectly still. I guess that why you do the re-check at the end. Makes sense.
Nice job removing the mystery a lot of guys must have. Maybe this will keep some more on the road.
Thanks Jim, fabulous videos! This needs to be a Sticky for sure!
In for updates and commentary and for the chance to watch when my kids are in bed. I don't have to do this yet but when I do, I don't doubt this will help tremendously. Thank you Jim.
Subscribed for more bluuuuuuuuess in your videos .....
Next time, Jim will do the timing in a g string put on backwards.
It takes balls to do timing.
Excellent video, Jim. Clarity is great, in both the vid & content.
No need to pin the ring gear to hold the crank?
Ed CT
1998 528i
5-Speed
Aspen Silver
Aubergine Leather
So smooth and relaxing. Makes timing our cars looks so easy and fun.
Philly, when the trigger wheel nuts are torqued the fixture was bolted tight to the head with its alignment pin in the hole on the trigger wheel. It's solid, can't rotate at all.
Double checking the position and getting the top surface of the upper covers even with the top of the head is what counts.
Its really not that difficult, watching how it's done is sometimes better than reading about how it's done.
Manny, don't think that will ever happen.
Ed, yes the flywheel is always pinned except when the crank is rotated.
auag, blueeeeeeeeee it is.
Thanks to the rest of you guys too.
Jim,
You should make more videos. Ultra clear voice, great organization, and great overall video clarity.
Well done. Brings back memories lol. Nice trick with the zip tie around tensioner when you remove the block. Nice way to make sure no jumping.
2000 Silverstone/Silverstone M5 1/34
Awesome Jim - also cant watch at moment w sound - but kudos for the accomplishment! Gettin psyched up for when we hit my job...
2003 M3CicM6 TiAg
Former:
1985 MB Euro graymarket 300SL
Great videos!
Very nicely Done Jim
2003 540MSPORT #861/1265 -GF71249 .Black Sapphire Metallic/Sandbeige.Dinan intake~M60 manifold
Spec racing stage 2+ clutch and custom light flywheel .M5 rear LSD 3:15~M5 driveshaft ~Rogue Octane SSK
36K ENGINE SWAP!!!.~Rogue thrust arm bushings~Rogue studds~Dinan strut bar
EIBACH front/rear sway bars with BEASTPOWER brackets~CDV delete~Redline fluids/Racing blue Ate~ APEX EC7 RIMS SQUARE 18 x 10's~M Pararallel rims 9.5 all around~285 30 18 rears~265 35 18 fronts~ENKIE 18x10's square with Continental Slicks 275's square~RE 11's, 595 RSR's~BC racing coil overs 8k/6K~Steel braided brake lines~Powder Coated valve covers-A1 headers 100 cell cats, performance resonator and 4”cross tips, CUSTOM BBK - MASSIVE HATS AND BRACKETS - AERO-6 WILDWOOD-, ANODIZED CALIPERS STAINLESS STEEL PISTONS THERMAL TREATED, CUSTOM WILDWOOD ROTORS 14.50”
Boo-Yaaa !!!!!! Awesome Video Jim. I need to save that on my phone and carry it around with me.
Great videos Jim. Doesn't get better than that.
Anyone else thinking about getting a 540i with broken guides and going to town? Would have to spring for the timing tools, but this seems easy peezy.
2003 DINAN 5 | M54B30 | Titanium Gray Metallic | Stage 3 Engine Software | High Flow Throttle Body | Cold Air Intake | Free Flow Exhaust | Performance Automatic Transmission Software | Front Strut Brace | OE 18x9 BBS RS745 Style 42 on 265/35-18 MY BUILD THREAD: [Click]
Sweet! I'd start looking for nice 540's local to me with broken timing guides, but I'm pretty sure someone I know would beat me to em!
Ah, that's the key! Wait until the toy store is full.
Excellent video Jim.
How different is the procedure for non TU?
