Page 2 of 4 FirstFirst 1234 LastLast
Results 26 to 50 of 80
Thread: M52 custom turbo setup
  1. #26
    Apr 2012
    Tampa, FL
    E36,E38, and E46
    ngk 4554. gapped from .021 to .026 depending on the health of you coils and boost.
  2. #27
    May 2015
    96 Hellrot 328is Turbo
    Quote Originally Posted by bry195 View Post
    Perfect that is what I needed to know. The time for swapping in the engine is getting close!! Just need to time it, mock up the intercooler/charge piping, get some bungs welded in my temporary DP, tap some vacuum fittings in the manifold and we are ready for low boost.
  3. #28
    May 2015
    Lil update
    getting ready for the swap, which shall begin a week from today
    My buddy is going to do a cut and some bead rolling on my piping, and we should be good to go there. I have mocked it up and made some brackets for the intercooler.
    Oil distribution
    Gapped and torqued
    What do you guys think of this return, too much of a low spot? Or am I just paranoid?
  4. #29
    Mar 2012
    Renton, Wa
    98 m3
    Too much low me thinks. The angle of the fitting probably wont work
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
  5. #30
    Sep 2015
    Texas
    '97 328iS, '06 Tacoma
    What are other common locations for the oil return?
  6. #31
    Mar 2012
    Renton, Wa
    98 m3
    Use a small extension off the pan at a better angle. You could also return to the timing cover
    1989 535i - sold
  7. #32
    Phoenix, AZ
    1999 328i -2000 323i
    It will be fine like that. Top mounts don't usually have any issues with draining as long as -10 fittings are used.
  8. #33
    May 2015
    Quote Originally Posted by Hobbit38 View Post
    We're gonna find out here very soon. Im just going to point the fitting up a bit more and we'll see how she flows. I have a feeling your'e right.
  9. #34
    Mar 2012
    Renton, Wa
    98 m3
    Quote Originally Posted by manneurex View Post
    luke gronski ran a return and had issues because fitting angle. Fyi.
    1989 535i - sold
  10. #35
    May 2015
    Quote Originally Posted by vollosso View Post
    Thanks for the heads up thats why i asked. Was he running -10?
    *edit*
    Nvm I just realized what build you are referring to. The one that inspired me to do what I'm doing. That build changed my life lol. What ever happened to the guts of that car?
  11. #36
    Mar 2012
    Renton, Wa
    98 m3
    Thanks for the heads up thats why i asked. Was he running -10? *edit* Nvm I just realized what build you are referring to. The one that inspired me to do what I'm doing. That build changed my life lol. What ever happened to the guts of that car?
    Garage fire and then parted out...
    Last i heard maxpsi had his turbo manifold and downpipe for sale i believe it was spoken for but thats all iv heard.
    1989 535i - sold
  12. #37
    May 2015
    Garage fire and then parted out... Last i heard maxpsi had his turbo manifold and downpipe for sale i believe it was spoken for but thats all iv heard.
    That car was the stuff of legend. The perfect street e36.
  13. #38
    May 2015
    Motors in, although I have a slight problem.. The hood is no where near being able to close. I knew there was a bit of a risk of this happening, although i have seen a gtx3582 with this manifold which i figured was larger than my turbo? But no hole in the hood.
    Setup:
    Akg mounts 75d
    Turbonetics t3 t4 6057 .7 ar
    RallyRoad feed line into a -4an to 1/8" npt adapter and finally to a 1/8"npt feed line flange (This sticks 1.3cm above the turbo housings). The hood is over an inch away from where its supposed to be.
    So what do you guys think, could i shorten the oil feed somehow and maybe trim the engine and trans mounts an be good? Any ideas?
  14. #39
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    You can run a banjo bolt oil feed into the turbo. Low profile -- like 1/2 inch total height.
    I am currently running Vorshlag red poly engine mounts cut down about 1/4 inch.
    Seems like even that 3/4 inch total would not get you where you need to be.
  15. #40
    Dec 2010
    Vancouver, BC
    1998 328is
    I'm running the same manifold as you, its my compressor housing that makes contact with my hood. I only had to file a couple mm's off the compressor housing to make it work. Its a Garrett t3/t4e 60 trim .63 ar
    What size downpipe were you able to fit? I relocated the wastegate to the other side of the manifold (think obx) and can fit a 3" dp w/o touching the vc gasket or strut tower.
  16. #41
    May 2015
    Quote Originally Posted by ocyrus411 View Post
    I'm running the same manifold as you, its my compressor housing that makes contact with my hood. I only had to file a couple mm's off the compressor housing to make it work. Its a Garrett t3/t4e 60 trim .63 ar What size downpipe were you able to fit? I relocated the wastegate to the other side of the manifold (think obx) and can fit a 3" dp w/o touching the vc gasket or strut tower.
    Dp is the cx one for now. I thought i saw a picture of yours with the 3" and the wastegate in normal spot no? So I think I'm cutting a hole in the hood. So much for the "sleeper look" lol. Im gonna see how afrs look a bit later today and possibly get a revision from trm and then hit the dyno. Current wastegate spring pressure is 16.5lbs.
    Pictures coming.
  17. #42
    Dec 2010
    Vancouver, BC
    1998 328is
    i ran that wastegate setup for the first year but have since changed it. i'm also on M3 motor mounts. i'd do whatever you can before you cut a hole in your hood.
    i'm gonna be hitting a dyno soon as well, trying to arrange a remote tuning session w jordan. maybe i'll turn the boost up to 16.5 on the dyno. it would be interesting to see how numbers compare our builds are pretty similar!
  18. #43
    Apr 2012
    Tampa, FL
    E36,E38, and E46
    i ran that wastegate setup for the first year but have since changed it. i'm also on M3 motor mounts. i'd do whatever you can before you cut a hole in your hood. i'm gonna be hitting a dyno soon as well, trying to arrange a remote tuning session w jordan. maybe i'll turn the boost up to 16.5 on the dyno. it would be interesting to see how numbers compare our builds are pretty similar!
    look he lives! post those numbers. Been waiting forever for this.
  19. #44
    Dec 2010
    Vancouver, BC
    1998 328is
    yeeup im still alive and married to my e36. hopefully i'll get the numbers within the next couple of weeks!!
  20. #45
    milKt's Avatar
    milKt is offline ßMW///MµrÐêr§þðr†
    Flaccid US Appendage
    95M3t 95M3 92525iT 95525
    +1
    I have a drain plug drain
    and ZERO issues.
    Vancouver, B.C., Canada
    '97 M3
    I think that the drain plug set up works fine when the ID of the fittings are big enough and oil isn't too thick at start up. The head pressure has to overcome the viscosity and flow restriction of the components used..
    Sent from my GTX3582R
  22. #47
    milKt's Avatar
    Theory or not...it works for many.
    Talk is talk.
    It is DONE.
  23. #48
    Manchester, N.H.
    96 332IS 6466 turbo
    Quote Originally Posted by milKt View Post
    Talk is talk.
    It is DONE.
    I had no problems for 2 years . worked great.
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  24. #49
    milKt's Avatar
    I just recall MANY posts from folks
    (some who never had top mounts)
    stating that it doesn't work.
  25. #50
    Mar 2012
    Renton, Wa
    98 m3
    I use a low bottom with a drain fitting and originally it had a tiny entry and it worked. I use 1" id line. It works better now that i drilled it out to 3/8"
    1989 535i - sold
