Good work
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
correct. The lifters have only about a mm extra to extend (unless you pull them apart and remove the locking ring) but I doubt they grind them more than a mm. Did these cars make any ticking noises indicating the lifters weren't taking up the gap as designed? Or maybe they do take up the gap but "squish" down more easily negating the extra duration?
No new noises that i was aware of. Im not going to get into RR cam specs as they hold that close to the chest and wouldnt be kosher. I again never conclusively determined the cause. Pulled them and put S52s back in. Power jumped back up and ideal vanos shutoff point dropped back down.
Hmm, interesting about those cams.
I do appreciate rereading this thread from time to time. it makes me feel pretty good about the power my m3 is putting down untuned, better than most s52's posted and based on what you have acheived, I'm counting on a few extra hp once we get the timing and fuel corrected for altitude. We were as low as high 10's in some places. However, you should know, maybe you misstated it or misunderstood how the cams are made, the riots add zero lift to the original lobe, only duration. If you put a micrometer to them you would know this and if you spoke with the owner/ designer he would have stated this emphatically.
This is an incredibly interesting thread. It took some research but I finally found the elusive back to back comparison of an M50 vs. M52 manifold swap with no other mods.
