Results 1 to 25 of 28
Thread: Dinan Breather Control Valve
    Sunnyvale, CA
    98 Z3 M Roadster
    Anyone ever figure out the generic replacement part for the Breather Control Valve on the Dinan E36 SC (Vortech) kits? Been searching the forums but so far drawn a blank (other than the Dinan part # which doesn't help)
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Yes. It is an old Ford part as I recall. You will have to do some searching, but I think the details were posted in this forum long ago.
    Jan 2006
    Oakhurst, CA
    96 M3 97 M3 98 M3 99 M3
    You're talking about the check valve used to block boost from the fuel tank?
    E3ZZ-9C793-B
    Sunnyvale, CA
    98 Z3 M Roadster
    Ah no that's the vacuum check valve. I was meaning the one in this picture that you put on the line going into the vanos.
    http://img.photobucket.com/albums/v8...1/breather.jpg
    The one near the ??'s
    Jan 2006
    Oakhurst, CA
    First off, delete all that crap and use a catch can or S62 oil separator. CA SMOG, even star stations, pass with an S62 separator in place. But if you must keep it; Part number is: E47E-9F491-BA
    Here's the S62 separator. This even drains back to the oil pan.
    Sunnyvale, CA
    98 Z3 M Roadster
    I actually have an S62 separator here. I thought that just goes in place of the stock one in the setup. Didn't realize it was meant to replace those parts altogether.
    Just noticed your location, were you the one selling the kit a while back? I based my entire project off that part listing / pics. It was awesome. Here's what I've assembled, powder coated all the mounting plates. Vortech rebuild on the SC.
    Actually, I got a follow up question based on you setup. Trying to determine the plumbing in that configuration.
    Top two lines are self-explanatory from the pic.
    The vacuum line I assume is just delete (replacing the 4 way X in the vacuum line setup with a tee) - Correct me if I am wrong.
    As for the feed from the bottom of the separator where does this go, into the stock separator? Or does this also replace the stock separator. How do you plumb all this part?
    G
    Jan 2006
    Oakhurst, CA
    Yes I'm the one who had several refurbed kits for sale over the years. Feel free to text me too; 949-500-8493 (Brett)
    Vacuum is deleted since the Ford valve isn't used.
    S62 separator bottom port is the oil drain. Just run it to the dipstick drain.
    Good parts collection there. I would advise to not use the smaller mechanical fan. Get a Stewart WP, 3-core Z3M radiator and just use the stock pusher fan. I've had mine like this for 4 years and 116 degree central valley summers. Go Zionsville if you can afford it.
    I've revised my parts list since you last saw. I can help you go over everything.
    Toronto, Ontario
    boosted M3's
    Quote Originally Posted by Braymond141 View Post
    I am actually contemplating getting rid of my Zionsville unit or just the electric fan if the mech fan will fit with the Zionsville Rad. The electric fan is absolute crap, it moves no air at all and the sound of it annoys me. It's a beautiful piece but I think ill be getting a new thinner rad and going back to the mech fan. Also, that way I can fit 8 rib pulleys for sure.
    Also, Im the process of getting rid of my original dinan breather control valve, any reason the s62 oil separator is favourable over a catch can setup?
    Your engine bay looks very, very clean. Good Job! What bypass valve do you use?
    Sunnyvale, CA
    98 Z3 M Roadster
    Actually, I am installing into a Z3M and already have the uprated Stewart pump installed. Didnt realize the stock fan would fit.
    What I'm confused about is the line coming from the original (Stock) oil separator.
    The S62 separator gets installed on the line going from the stock separator to the valve cover (1 - in the picture) and is connected to the SC intake. What happens to the connector on the stock seperator (2 - in the picture) that originally connected to hose #1?
    Or, are we saying that the stock oil separator is removed entirely?
    Jan 2006
    Oakhurst, CA
    Plug stock oil separator hole, delete the separator entirely.
    Use the S62 as shown.
    Toronto, Canada
    supercharged 97 m3
    Braymond, Would that set up work well with higher boost S/C cars? I really like the clean set up; but wonder how well it would work at 12 lbs boost?
    Insufficient funds...
    Jan 2006
    Oakhurst, CA
    I'm at 12psi with it. My motor has blowby so I get a trail of oil vapor. The motor I have in the works will have much better ring sealing. You can run the S62 + a catch can if you are really concerned, but that does defeat the simple fit.
    Toronto, Canada
    supercharged 97 m3
    I sold the car and had a catch can set-up. This is very clean, so I forwarded the link to him.
    We were both impressed on how nice it looks, but as long as it functions under the higher boost, with
    no adverse problems...I'd be switching over to this...
    thanks
    Sunnyvale, CA
    98 Z3 M Roadster
    Ok, dumb question time. How do you plug the hole when you remove the stock oil separator. (i.e. is there a particular part I should pick up?)
    Toronto, Ontario
    boosted M3's
    bump, what intake tube is that?
    did you just drill in a second hole for the s62 oil separator?
    Sunnyvale, CA
    98 Z3 M Roadster
    Hm good q, that looks like you have the Euro MAF on there with no reducer so I'm guessing that's a 3.5" pipe to keep the line open between the MAF and the SC inlet. Is it a custom fab?
    Looks like the intake from the RMS kit although as ColdshotM3 stated with an additional hole drilled and another bung added.
    Jan 2006
    Oakhurst, CA
    Toronto, Ontario
    boosted M3's
    you mentioned removing it after passing smog? why?
    and im assuming you just drilled another hole? trying to get this setup replicated or use a catch can setup as i am still using the original dinan stuff. (among fixing many others issues...fml so much hackery has been done...)
    Braymond what bypass valve do you use?
    Jan 2006
    Oakhurst, CA
    Quote Originally Posted by ColdshotM3 View Post
    I didn't remove anything after SMOG, only venting the separator to atmosphere because my motor has too much blowby.
    Aluminum BPV. No brand.
    Sunnyvale, CA
    98 Z3 M Roadster
    I don't see it for sale on the RMS site. Wonder if it would work with the Z3M.
    Jan 2006
    Oakhurst, CA
    Quote Originally Posted by GBPaterson View Post
    Call them.
    Jan 2017
    Puget Sound, WA
    MZ3 325xi
    I'm about to tackle refreshing the breather hose refresh on my 99 MZ3 with the Dinan supercharger. I has 182k (130k with the S/C).
    I think I'll switch to the S62 oil separator in the process. It looks like a much cleaner setup.
    I can't tell from the pictures if you're using the Bank 1-4 or Bank 5-8 oil separator. Which one is it?
    Aug 2001
    CA Bay Area
    99 M3 coupe
    Resurrecting this thread.
    (I've begun to tear into a very poorly running Dinan SC M3. Sheared impeller shaft, many failed vacuum hoses. Lots of oil in the manifold. I've pulled the manifold and only beginning to understand the Dinan plumbing. I'm intrigued by the simplification of the S62 separator, but am not sure of its implementation. The car has Dinan's CARB certification, and it passed smog a few years ago. I want to make sure it can pass smog again, both visually and at the tailpipe.)
    I've attached two drawings. The first is what I believe the "stock" Dinan setup looks like. The second is an interpretation the S62 separator setup, but i'm not sure it's correct.
    Any input would be appreciated.
    Dinan Supercharger Vac 2-3.pdf
    Last edited by MDR; 04-05-2024 at 04:11 PM. Reason: Updated S62 oil separator & corrected S/C input
    99 M3
    Jan 2006
    Oakhurst, CA
    You will pass with the S62 separator. I've done it for many years and so has everyone I have supplied that setup to (30+ owners).
    If you need help rebuilding the charger, I do that too.
    Aug 2001
    CA Bay Area
    99 M3 coupe
    Brett,
    Just got my S62 separator, trying to figure out where to install it. Considering the forward angled bracket that supports the intake, but am open to any suggestions that you have.
    Thanks,
    Murray
    99 M3
