Page 3 of 9 FirstFirst 123456789 LastLast
Results 51 to 75 of 215
Thread: Kouks e34 complete rebuild
  1. #51
    Apr 2014
    PA
    Quote Originally Posted by Binjammin View Post
    That just makes them cheaper if you're going to be swapping the parts into an m50/m52.
    OP was thinking about putting " A whole M54 in" So I figured I would throw it out there.
    "Helicopters: 10,0000 pieces of metal fatigue rotating around an oil leak."
  2. #52
    Butte, Montana
    Suck
    Quote Originally Posted by S61Dan View Post
    You do make a valid point.
    Go ahead and bite. Plenty for everyone.
  3. #53
    Mar 2012
    Baltimore, Maryland
    2016 640i, 1990 535iM
    Quote Originally Posted by Frchdragon View Post
    I was lucky to get a M54 bottom end for $300. Basically, you are making a S50 clone
    You get a good M54B30 engine and install crankshaft, rods and pistons into your M50/M52 block and you will have 3.0L engine with 10.3:1 compression ratio. Then add s50/s52 camshafts and you will have S50us clone. Use your Red label ecu with early non EWS M3 chip, might need a different DME for Vanos engine.
    Since we are on topic. Does the b35 pistons fit the m50?. Does the block need to be bored for proper fitment?
    You guys make it seem like it slides in
    2016 640i Coupe'
    1990 Bmw 535i Turbo 600whp
    1999 740iL: Sold
    1997 740i: Crashed and Parted
    1988 535i: Crashed and Parted
    1988 528e: Crashed and parted
    IG- @Rogetta_Stone
  4. #54
    Butte, Montana
    Suck
    m30b35 pistons in an m50?
  5. #55
    Mar 2012
    Baltimore, Maryland
    Sorry autocorrect messed with my post
    B30 pistons in m50 (from M54)
    2016 640i Coupe'
    1999 740iL: Sold
    IG- @Rogetta_Stone
  6. #56
    Dec 2011
    Lancaster CA
    e34,e38,e39,e46,e70,e90
    Alright, you guys got me thinking. Just to organized thoughts and continue with opinions, here are my options...
    Option 1: straight M50 rebuild
    Anything beyond a straight M50 rebuild will depend on the possibility or availability of the proper electronic control for the setup. It would have to be a reliable and not too costly setup.
    Option 2: use the Pistons, crank and rods from an M54 only.
    Option 3: same as 2 plus s52 cams
    Option 4: entire M54 install.
    For simplicity I'm leaning to 2, but 3 seems intriguing. I'm thinking finding the cams will be difficult and the DME setup is questionable.
  7. #57
    Apr 2013
    United States
    '91 M5, '13 E92, '89 E32
    Something to consider about the engine swap is the California smog test nonsense.
    Look at the trouble this guy had, to the point where he's selling this 540iT at a loss: http://carbuying.jalopnik.com/this-1...1490889/+damon
  8. #58
    Apr 2014
    PA
    Quote Originally Posted by kouks View Post
    Honestly if it's for your daughter, just work with whats in the car already. No point in putting in an m54 or whatnot when you want the car "teen-proof" more then performance. You did say "Daughter #1" overheated it last time so if the apple doesn't fall far from the tree, you are better off with the ole' cheap m50
  9. #59
    Aug 2012
    Simi Valley, CA
    328, 525, 740, R1200RT
    +1
  10. #60
    Dec 2011
    Lancaster CA
    Ok, with the smog, DME and the daughter issues I think keeping it stock will do for now. Plus I can get it done quicker so I can have a drivable car for her soon. Maybe save the cash for an S62/6-speed swap on the e38 later on.
    Found a friend with an engine lift, so the block is coming out and going to the shop for inspection too.
  11. #61
    Mar 2012
    Baltimore, Maryland
    m50 is cast iron block right? if so i dont think there any need to have it sent to the shop for checking
    2016 640i Coupe'
    1999 740iL: Sold
    IG- @Rogetta_Stone
  12. #62
    ATX
    Sundry old Grrrrmans
    Quote Originally Posted by E38740iMD View Post
    The M50B25 and M54B30 are both 84mm bore.
    S52 is 86mm, FWIW.
    - Brent
    www.angry-ass.com
    Quote Originally Posted by danespann View Post
    Every E34 needs the same things in the end.
  13. #63
    Dec 2011
    Lancaster CA
    Cracks? Warping? It was overheated not once, but twice.
  14. #64
    Mar 2012
    Baltimore, Maryland
    I don't think cast iron warps and cracks like that unless with an equal force. If I remember my Chem classes right. Cast iron breaks never bends so that eliminates the warping. And it would take alot of heat and pressure to crack cast iron. And a measly overheat shouldnt do that. But I can also be stood correct if others want to chime in
    2016 640i Coupe'
    1999 740iL: Sold
    IG- @Rogetta_Stone
  15. #65
    Butte, Montana
    Suck
    I don't think cast iron warps and cracks like that unless with an equal force. I'm I remember my Chem classes right. Cast iron reads never bends so that eliminates the warping. And it would take alot of heat and pressure to crack cast iron. And a measly overheat should do that. But I can also be stand correct if others want to chime in
    Iron can warp, but it's far more resilient. OP, clean up the deck and check it with a calibrated straight edge and feeler gauges, but it should be fine.
  16. #66
    Mar 2012
    Baltimore, Maryland
    edited my previous post because the grammer was f'ed. should be more understandable
    2016 640i Coupe'
    1999 740iL: Sold
    IG- @Rogetta_Stone
  17. #67
    Dec 2011
    Lancaster CA
    Shop called. Head only needs about .003-.005 inches off to fix slight warping. All valves seal good. No cracks. Amazing after two overheats, one where my daughter drove it over a mile while it was cooking so she could get home. The M50/52 sure is a bulletproof machine.
    Asked about a complete valve job, $729. Don't really want to pay that much.
    After 240,000 miles I'm wondering about the valve guides and seals. Engine compression was still good when it ran but it did start to burn a bit of oil. Valves looked clean from above so I don't think the seals are gone.
    When is a complete valve job appropriate?
  18. #68
    Butte, Montana
    Suck
    When you care enough to spend $729 to save on $100 worth of oil a year.
  19. #69
    Dec 2011
    Lancaster CA
    Again, Ben with the wisdom. Nice.
  20. #70
    Dec 2011
    Lancaster CA
    Removed power steering pump, oil filter bracket, AC compressor, and tried to remove the Jesus lot without the pipe on the breaker bar...nope. Need to go to Home Depot and get one tomorrow. Going s bit slow cause my wife's Burb also needs front end suspension work and new tires. Always come down to money...
  21. #71
    Nov 2009
    Realville
    93 525iT,91 318i
    How much oil does it take to foul the cats, though? If you have to deal with emissions testing, wouldn't an oil burner may be problematic?
    Your head gasket set will come with new valve seals. Why not just get yourself a valve spring tool and some valve lapping compound and the $2 suction cup tool and do your own valve job? Shouldn't take more than a day.
  22. #72
    Aug 2012
    Simi Valley, CA
    I have a valve spring compressor I used once on my M20, if you need some help.
  23. #73
    Butte, Montana
    Suck
    Quote Originally Posted by locknload View Post
    If by foul you mean clog, that wont happen. If you mean burn in the exhaust and cause the cat to melt? It takes a lot, more than a puff on cold start and the slightly increased loss of oil while running.
    DIY is very inexpensive and pretty easy, and OP has the patience and skill to do it, but lapping valves and a valve job are two different things man.
    On top of that, lapping valves wont solve worn guides.
  24. #74
    Nov 2009
    Realville
    93 525iT,91 318i
    Yah, I agree. Lapping would just help seat the valves a little better and possibly restore some compression. Once the valves are free, though he can see if any wobble enough to be out of spec. Even then, I think you can still have the offending guides knurled (or replaced) to get them back in spec. without having to wholesale replace all the guides.
  25. #75
    Dec 2011
    Lancaster CA
    I'm not sure what lapping valve entails or what it means but just replacing the seals would be of interest. However, I'm afraid of not leaving well enough alone. The shop said all the valves seal properly and during a conversation about the seals and guides the owner told me to be careful if I do it since if a piece of carbon came loose and got between the valve and the head I would need a full valve job. Not exactly sure what he was talking about but I think he was trying to say the valve would not be centered any more and require reseating. I'd like to replace the seals, but not if its a risk of a $700+ job.
    Today I removed the Jesus bolt and spent about 3 hours cleaning the block surface and Pistons.
    Upon close inspection of cyl 1 and 6 I saw what appears to maybe be corrosion or some other sort of imperfection below the piston ring line. I could barely feel them with my nails but the texture was certainly not as smooth as the rest of the cylinder wall. Cyl 2-5 did not have this. I assume that 1 and 6 is where the gasket was failing and may have allowed coolant in, maybe causing this imperfection. Opinions on this?
  1. E34 Turbo project by ROVBMW - complete rebuild!
    By ROVBMW in forum Forced Induction
    Last Post: 05-25-2015, 11:41 PM
  2. E34 WTB E34 Complete Exhaust 525i (M50) in Southern California
    By uscharalph in forum E34 Classifieds (closing soon)
    Last Post: 05-22-2013, 02:30 AM
  3. E34 E34 Complete Oxford Green Wide-Grille Conversion
    By bubbajan21 in forum E34 Classifieds (closing soon)
    Last Post: 10-22-2011, 11:38 PM
  4. Replies: 35
    Last Post: 07-07-2011, 11:48 PM
  5. E34 E34 Complete OEM Roof Rack w/ Keys and Fittings
    By HunkaTunka in forum E34 Classifieds (closing soon)
    Last Post: 12-02-2009, 11:56 AM
