Hello recently my sunroof broke, I replaced the piece that broke, it was this:
After I replaced the piece I clicked the forward button to check if its all working, and I hear a crack, and next thing I know another piece broke. The piece that broke is the one shown below, does anyone know the part number or name for that specific piece not the whole group of pieces shown below, and also I have seen that I need to remove the headliner to replace the piece, is that true, and if not whats a easier way to replace it.
Link for sunroof guide rail(every part):http://www.ecstuning.com/BMW-E39-M5-S62_5.0L/ES157405/
Unfortunately, replacement of that part (the back piece, right?) requires dropping the headliner and sunroof cassette to slide those pieces out of the back. I did this about 2.5 years ago.
There are going to be a few broken plastic pieces most likely. If you really want to do this right, drop the headliner and remove the sunroof cassette, take pics before disassembling the rail pieces, then examine all broken parts including the weather channel piece that's probably laying in the back of the assembly.
Order your new parts needed, then replace. Do NOT under any circumstances operate the sunroof without the glass in place
Search around for a good DIY on this first. It's not that difficult if you know what you are doing. But going at it blindly will not be fun. I have done the headliner twice now and the second time was so much easier. I can offer some tips. Press the sunroof button to raise the rear section. The black rubber accordion strip you see is just held in a channel at the top. I suggest some sort of trim removal tool to pry the end toward you from behind. Then if you gently pull the top of it towards you, it will start to pull out of that channel. Once it's out, you will see the 3 metal fasteners on each side that hold the glass/brackets to the frame. Once those are out, you can remove the glass. Then from the top of the car looking down, you will see all the little fasteners that hold the headliner to the metal frame. Remove all of those and then work your way around the car removing the screws in the sunvisors and grab handles. IIRC, you have to remove the A pillars and C pillars as well. A pillars have a large screw in each behind the SRS cover. Then pull up and out as there is a tongue down behind the dash. The C pillars have screws behind the map lights.
That should get you going enough to where you can figure out the rest. But I still suggest searching for a more detailed list or video in case I missed any steps.
These threads may offer some assistance
http://www.bimmerfest.com/forums/sho...d.php?t=753221
http://www.bimmerforums.com/forum/sh...hlight=sunroof
Took about 3 hours with two people, I would suggest if anyone has to do this grab a friend to help, can be difficult alone.
