Page 3 of 15 FirstFirst 12345678910111213 ... LastLast
Results 51 to 75 of 352
Thread: Tire Options for Force Induction
  1. #51
    Feb 2002
    Orlando, FL
    Turbo 97 E36 M3, 99 M3
    Going with the CES reinforced subframe and diff conversion.....my diffsonline 2.93 diff will be for sale shortly if interested!
    1997 Arctic Silver/Black M3
    1999 Techno Violet/Dove M3
  2. #52
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Last month we welded the adapter plate onto my subframe and put a 3.15 210mm diff into it. I may rebuild the diff to a 2.93 next winter.
  3. #53
    Vancouver, B.C., Canada
    '97 M3
    Are you trying to stay in third gear in the 1/4 mile or get to 200 mph?
    Sent from my GTX3582R
  4. #54
    Jun 2005
    New England
    More for relaxed highway driving with the 5 speed and I don't think I would lose much on acceleration given the power level. I was at about 135 in the quarter at around 575 rwhp. Even with another 100 rwhp, I probably won't do much better than 140, so the 3.15 would just make it.
  5. #55
    Def's Avatar
    Def is offline Lead Disagreement Eng PE
    Aug 2002
    SW22, Volt
    Quote Originally Posted by Jaze View Post
    It is a 140 TW R compound, which is pretty aggressive. I put them AT LEAST right on par with a RS3/StarSpec, and so do most people who have tried them in my travels. They don't allow the RSR in enthusiast class of GTA because it is too sticky...the rs3 and star spec are allowed.
    Like I said, not on par, but in the same league. Many time attack teams I work with use them for shake downs/experimenting before game time with hoosier r6. That says a lot to me.
    Have you had a chance to run them? With a little heat, they are an incredible tire for the money.
    Instructed in a car with them. They're definitely a 140 TW street tire. A 100 TW NT01 is another noticeable step up in grip.
    Maybe they're a tiny tiny fraction faster than a Star Spec/RS3, but they're definitely comparable in that you're probably talking maybe a tenth or three per lap when the setup suits both tires, not 1 sec+ lap that you'll get with an R-comp.
  6. #56
    Mar 2014
    Durham, NC
    1992 3000GT VR-4
    Any interest in running a full slick on a 17" rim? Will definitely help save the drive line. http://www.mandhtires.com/M-H-Racema...0#.VSCQW5HD-Ba
  7. #57
    Mar 2011
    Kingston ,Jamaica
    1997 328i turbo
    Quote Originally Posted by mdcrose View Post
    Full slick woukd require front runners
  8. #58
    Manchester, N.H.
    96 332IS 6466 turbo
    Yeah, I wouldn't hit the streets with full slicks.
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  9. #59
    3rd rock under the sun
    spaceship
    wouldn't the race logic traction system help out?? if a person wasn't looking to run slicks
  10. #60
    Manchester, N.H.
    96 332IS 6466 turbo
    Quote Originally Posted by turbo b View Post
    Race logic helps yes, but in the end your cutting power. OP has 800something powers. IMO race logic should only be used to save your ass in a corner. Other than that you really want to put the power down.
    1996 332IS
    Built 3.2
  11. #61
    spaceship
    the internet can be a painful place.. ive read that a few guys have gone faster with the race logic (one guy with a 300zx said he cut a whole second off his 1/4 time with it on)
    in my situation I will street racing but staying on a street tire.. so theoretically with the race logic one would have a perfect lunch every time. you aint winning if you spinning but I just don't know..
  12. #62
    Manchester, N.H.
    96 332IS 6466 turbo
    Let's use 1/4 for instance. The key is to build a car with lots of power , and put the power down. This is done by suspension and proper tires. By using race logic in the 1/4 your cutting power to put it down when you should be increasing tire/suspension. Yes you might not spin, but your not putting down all your power.
    A properly heated drag tire on a track will stick like glue, you will get full traction in first gear. Again.....a .properly sized, quality, heated drag tire. You need to do a long 2nd gear burnout till you see smoke. Then hold on.
    1996 332IS
    Built 3.2
  13. #63
    Aug 2012
    CT
    Twin turbo LS E36 M3
    traction control is a slippery slope. Like Butters said, its best to put the power down. I use it in my Megasquirt, so i can only comment on that, but if you have it setup correctly, it really does help.
    For example, before i had the TC working, you would have to pedal the car. When you factor in human error, it sucks. You go no where. Doing nothing but playing with TC, i can now just leave the pedal to the floor (with in reason), and the system will progressively cut power to maintain or regain traction.
    You combine that with a good tire, and it works very very well. But its basically just a bandaid for an overzealous driver/poor traction/car not setup properly.
    328i Sedan Twin s366's, 6.0LS, TH400, MS3 Ultimate
    9.20 at 150 on 22psi
  14. #64
    Upstate
    E28
    You CAN accelerate quicker with a properly set up TC, though. There is a certain range of slip (5-10% depending) that you can achieve greater acceleration than full traction. However, the main advantage of traction control is that it is able to respond faster than your foot. The fact that it can keep it in that slip range is a bonus.
    But I agree with butters, go with the best tire you can manage, and then go for traction control if it's not enough.
  15. #65
    Manchester, N.H.
    96 332IS 6466 turbo
    I would like a race logic for the street, but would shut it off at the track.
    1996 332IS
    Built 3.2
  16. #66
    Upstate
    E28
    It will only help at the track, why would you turn it off?
  17. #67
    Manchester, N.H.
    96 332IS 6466 turbo
    Quote Originally Posted by cj.surr View Post
    It won't help at the track. It will limit the power. If your running drag radials and heat them properly, you WILL NOT spin.
    1996 332IS
    Built 3.2
  18. #68
    spaceship
    As for tire I'll be running an 255/40/17 nt05. My car never really had a traction problem but im downsizing in turbo (6266 t4 .81) adding meth a few other driveline goodies
    as for the tc would help for the anticipation of the new found torque.. On the track I wouldn't use it but when street racing yes.
  19. #69
    Aug 2012
    CT
    typically speaking, you wouldnt ever really need it at the track with the right tire.
  20. #70
    Upstate
    E28
    How will it limit power then? It doesn't do anything unless you spin.
  21. #71
    Manchester, N.H.
    96 332IS 6466 turbo
    To be honest, I would want to know if the tires are spinning. If they do , something isn't right. Either not hot enough, not big enough or suspension related.
    Then if you were to run a full slick, those push you as they spin and find grip.
    1996 332IS
    Built 3.2
  22. #72
    '97 M3
    You can tell when Racelogic is doing its thing and then you just lift slightly until you can't feel the Racelogic. It trains you to adjust the throttle accordingly.
  23. #73
    Sep 2010
    Boynton Beach, FL
    Turbo 350Z
    What sizes were you guys running with the Federals? I heard they run super wide. I wonder if the 255 would be an issue with stock wheels.
    '97 M3/4 3.0l "Frankenstein" 760whp
    E90 335i 6mt Sold
    '97 Jetta TDi 16v ABA swap w/ pt6266 Sold
    2004.5 350Z APS ST 475whp 505wtq Sold
    2000 323i Sold
  24. #74
    Sep 2008
    Toronto, ON
    6465 328ti
    Quote Originally Posted by BlackPearlZ View Post
    I run a 235/40/17 on my ti. My nitto's were the same size and didn't rub but with the federals they rub a bit.
    I think this year however I'm going to get my first set of drag radials for when I want to do science experiments with locals. Spinning was fun for awhile but it's getting old.
  25. #75
    Nov 2009
    Long Island, NY
    67mm 325i, RAM 1500
    Spinnin ain't winnin fam
