Hey guys,this car has been owned by the same person since 1989 and has been taken very well care of.
Here is what has been done:
Complete motor overhaul top to bottom:
rebuilt head by clackamas auto ($280)
Rings, bearing, and gaskets done by rasmussen Bmw
Fine tuning by Stuttgart auto ($250)
Timing gear, timing chain and chain guides ($278)
14" e30 bottle cap wheels
New starter ($189)
Mechanical Advanced Distributor ($100)
New weber carb with about 50 miles on it! ($225)
Mike Ohara rebuilt 5 speed 320i tranni and custom driveline($850)
rebuilt 1976 rearend ($240)
Tii pressure plate and flywheel
CLEAN fuel tank from junkyard with zinc coated outside ($80) stock ones rust out!!
New front brake pads
Car was repainted a while back by german auto works, and has a couple chips and scratch here and there.
As you can probobly see from the pictures the paint needs to be cut and polished, i went ahead and buffed out the front end so you could see how good the paint look when its polished.
The interior has RX7 front buckets seats as the originals are know to rot out, as are the door panels, which have been recovered. The rear seat has cracks on the top from the sun coming down through the back window.
I am asking $3500 dollars for this car and if you know your 2002's you know this is well worth it. Its not the cleanest car on earth but it is def. somthing to work with as it has had major work done
Here Are all the pictures
http://community.webshots.com/album/148092075ZEUcIZ
503-481-7989 or rossfruin@comcast.net
