Page 2 of 3 FirstFirst 123 LastLast
Results 26 to 50 of 71
Thread: Catalytic Converter replacement
  1. #26
    Dec 2011
    SoCal, City of Angels
    840+S550 AMG+CanAm RS-S
    Quote Originally Posted by olinjohnston View Post
    You could try that, but what is the condition of the air filter, fuel filters, spark plugs, O2 sensors, and commonly-air-leaking intake manifold gaskets? If any of those are bad, you could see an improvement by changing them.
    Sadly, it seems very common to have replacement/aftermarket cats offer only a small (or temporary) improvement on emissions test figures.
    I changed everything in 2012-2013...the only thing I didn't check is the intake manifold gaskets (after reading Timm's write up this may be the culprit )
    Cats can be killed pretty quickly by an over-rich mixture - and the V8's are notorious for it due to multiple vacuum leaks that skew the adaptations. Have a read of this:
    http://www.meeknet.co.uk/e31/BMW_M60...cuum_Leaks.htm
    Great stuff as usual...and it has to be one of these (I'm guessing the gaskets) that is the problem.
    Thanks for the link!
  2. #27
    Nov 2005
    Langley BC Canada
    91 850 Panzer
    For what its worth, my local exhaust specialist, who is also a Magnaflow Dealer will not install Magnaflow cats on any car as he says they don't last even for a year. Right after install, they are fine enough to pass aircare/smog testing but will fail within 3-6 months. This is based on his personal experience (he is considered the best custom exhaust shop in the lower mainland) and having to re-do the job over again under warranty. He will now only install Walker universal cats - and guarantee them. YMMV... but I wouldn't install Magnaflow cats on my car.
    91 850 (Panzer), 2012 Mini Cooper Countryman (WifeMobile) www.wuffer.ca
  3. #28
    Jun 2012
    Mundelein, IL
    840Ci/6 528iT Europa TCS
    Where I live in the Midwest, cars 1995 and older do not have to go through a smog test. I removed my Cats, since they were rattling, per my dealer mechanic's advice. I have since replaced them with an aftermarket single converter 2 in 2 out, due to the smell my wife complained about. I am not sure what converter was installed, but the smell is gone. Now after reading this I am wondering if I should do the manifold nuts. What are the symptoms of the intake vacuum leak? My car seems to run well, but maybe it could run even better. Is this a maintenance item on these engines, or do we wait until symptoms occur?
  4. #29
    Apr 2008
    Los Angeles, CA
    95 BMW 840Ci; 97 Toyota 4Runner Ltd
    Thank you for this information. After reading this, I feel so fortunate passing all 4 of my smog tests since 2008. Fortunately I have some time until the next one... August 2016. I'll have to give some local muffler shops a call and see what brand they recommend and what type of warranty the cats come with.
    Pardon my lack of knowledge, but does anyone have insight as to why the stock cats are so expensive and come with the entire exhaust system?
    Quote Originally Posted by Wuffer View Post
    My 1995 BMW 840Ci
    Authentic OEM 18" M Parallels, Staggered Michelin Super Sports,
    Airbag Sports Steering Wheel 2,
    ACS-style aluminum pedals and more to come...
    wanted an 8 since college back in 1991; came to fruition in May 2007
    click for more pics->
    http://forums.bimmerforums.com/forum...05&postcount=1
  5. #30
    san diego,ca, usa
    e36 m3,e30,e46,e32,e31
    Anything stock or dealer is more expensive but going back to what Wuffers mentioned and to explain further ....aftermarket cats have less precious metals and tend not to last as long as factory ones. This what I've been told by my smog shop.
  6. #31
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Both my catalytic converters failed on my 840ci, one had started to melt, then other disintegrated:
    In my history file was a bill from BMW for replacement of both cats four years ago - total cost of replacement £1700
    I had both replaced by a custom shop with 200 cell Longlife units - total cost of replacement £500. I've passed two MOT's (UK smog test) with them fitted. Performance was noticeably better than when I first had the car due to the better gas flow. My feelings are obvious - I could have them replaced another couple of times and still have £200 in my pocket!
    My BMW Repair YouTube Channel
  7. #32
    Feb 2014
    Seattle, Washington
    1994 840CI & 1995 Rx-7
    I've had great luck with using Random Technology brand catalytic converters on race cars (for street class compliant cars) and miraculously it passed a sniffer test on a rotary that was pre mixing 2 stroke oil into the gas.
    http://www.randomtechnology.com/products.html
  8. #33
    fitchburg
    M3
    if anyone else replaces your stock cats please save them don't let the exhaust shop take them i will buy them from you! pm me if you do!
  9. #34
    Apr 2014
    Upstate NY
    1991 850i 6MT CB42321
    Any chance you know or could get the Walker model number your local specialist uses? The Walker website states #15022 as a direct replacement however the dimensions (width) seem too big plus it has an air pump port. In the course of building a new exhaust I found that the OE cats in my (your old) '91 850 6MT are one their way out, literally. Looking for a reliable weld in replacement. Walkers seem reasonable if I can get the proper configuration.
    1956 Austin Healey 100-4 BN2 // 1967 Chevrolet Camaro vert - project car // 1971 Datsun 240Z LSx resto-mod // 1986 Plymouth Conquest // 1991 BMW 850i 6MT // 2006 Ram 2500 Cummins 6MT // 2013 Audi Allroad
  10. #35
    Sep 2008
    Santa Barbara
    91 Dinan860 & 91 850 6sp
    The Walker #80832 are 50 State compliant and do not have the stupid air bung on them...
  11. #36
    tvjake2's Avatar
    tvjake2 is offline SoCalEights - CA BMW CCA Member
    Oct 2012
    Glendale, CA
    '97 840Ci, 1980 308
    [QUOTE
    Were your old cats cut and new cats welded in to the existing pipes?[/QUOTE]
    No they were new, aftermarket cats.
  12. #37
    Jun 2010
    Hyperworld
    '97 840CI
    Quote Originally Posted by german wannabe View Post
    ...aftermarket cats have less precious metals and tend not to last as long as factory ones...
    Magnaflow had at one point divided up their catalog into economy/ceramic, heavy metal, feature engineered, and California. California versions may-or-may-not be different from the 49-state version, but it is tracked and can be more expensive by far.
    Faced with restoring a rare 30-year old, I spent money on the better materials rather than market/regime.
    A Magnaflow heavy-metal was walked in from out of state, side-stepping the ban on sale, and installed personally, side-stepping the ban on shop installs and assuring a quality level.
    It is not regime stamped, but neither were cats from 30 years ago.
  13. #38
    Ireland
    X5M E70 and E28 525i
    Quote Originally Posted by cartoonz View Post
    This one? Its 1 in 2 out and appears to have a O2 bung hole?
  14. #39
    Sep 2008
    Santa Barbara
    No, you need the O2 bung... the other Walker part# mentioned earlier has a pipe that extends from the side of it, then crooks at a 90 degree angle for use one some kind of air pump that none of our cars have. Sure, you could use them I suppose, but you'd have to cap that off. The part# I gave (and you displayed above) doesn't have that appendage
  15. #40
    fitchburg
    M3
    if anyone else replaces their cats PLEASE SAVE THEM! I can pay you up to $250 for your old stock cats!! even if they are bad!
  16. #41
    Dec 2009
    Gardendale, AL USA
    1995 840 Ci, 1959 Sprite
    Slickbeamer: sorry I didn't read this earlier. Just let shop throw away. Had my cats replaced by straight pipes as I was told my cats were blocking flow.after removal, inspection revealed NOTHING left in cat housing, absolutely nothing, inside. Just were empty cans. Guess all precious metals and other internals were blown out tail pipe. Intake rebuild and resealing and new O2 sensors took care of CE lights on cold mornings. Can't really tell much sound differences or smells either. Just runs better than ever. No smog tests on any cars, so that is not a problem for us here.
  17. #42
    fitchburg
    M3
    damn that sucks exhaust shops LOVE taking advantage of people who don't know. the really dishonest ones will tell you you need new cats just to recycle the old ones that are worth more than the new ones! haha. PLEASE anyone reading this contact me before giving an exhaust shop your cats!
  18. #43
    Orlando, FL USA
    I had to replace both cats in 2013. The OEM cats were replaced with Magnaflow's. Just had another smog check a couple months back and passed fine. The only thing I don't like about the Magnaflow cats is that they have a raspy sound under hard acceleration. As for longevity of the Magnaflow cats, I'm not arguing with Wuffer as I haven't really driven the car much at all. Probably less then 1500 miles in the last 2 years so can't tell.
  19. #44
    Apr 2008
    Los Angeles, CA
    Reviving this thread... my apologies.
    Well, it's been a year and it's finally time to replace the cats in order to pass my smog test by August. Based on this thread, it looks as if Walker cats are the way to go. Was #80832 the correct or incorrect part number? I did a quick search on Walker's website and it mentioned #80811 would be the correct one, and on Autozone, it would be #15196.
    Any other recommendations that may have been discovered over the last year?
    Thanks all!
    My 1995 BMW 840Ci
  20. #45
    Bay Area, CA
    Not a Ferrari
    Not sure how much the Walkers are, but I've always used Magnaflow cats for CA smog. They're $198 each from pretty much any place that sells them:
    https://www.summitracing.com/parts/m...FUdlfgodUeMGGg
    Also I'm curious, how did you determine that you need new cats? They will last for 250k miles easily if they don't get soaked in oil, fuel, or coolant due to engine issues.
    1995 540i/6 // Dylan Leff - www.originalplate.com
  21. #46
    Apr 2008
    Los Angeles, CA
    My mechanic and I noticed heavy rattling about a year ago and I've been putting off the replacement until my next required test.
    From what I keep reading, the Magnaflows will add a bit of growl to my car, but I'm looking for more of a quiet ride much like the OEM. Also, i've read that the Magnaflows don't last quite as long. How many tests have your Magnaflows gone through?
    Quote Originally Posted by mojocoggo View Post
    My 1995 BMW 840Ci
  22. #47
    Bay Area, CA
    Not a Ferrari
    I've never noticed a change in sound going from OE to Magnaflow cats. I also only want a quiet OEM exhaust sound so I've always paid attention to any changes. I can't say I have any long-term experience with Magnaflow cats, and I wouldn't use them on my own car personally.
    My 850i had no cats when I bought it. I ended up just getting a used set of cats from a 60k mile car that was wrecked. I verified the smog history of the donor car (you can do so for free here: http://www.bar.ca.gov/pubwebquery/ve...pubtstqry.aspx) and it had passed every time it was tested, so I figured it would be a good bet.
    I would go with OEM on a car you plan to keep for at least 2-3 more smog tests.
    It all fit in my E24 pretty well.
  23. #48
    Indianapolis, IN
    93 850Ci, 09 Caddy SRX
    What he said.
    I did the same thing last year...bought a set of low-mile OEM cats from Walter (former owner of the super-charged 850 now residing in NorCal). Passed SMOG with flying colors. My old cats had about 155k on them and I passed the previous SMOG by a single point!
    1993 850Ci.....18 years & 165,000 miles and counting!
  24. #49
    Sep 2008
    Santa Barbara
    The Walker cats I posted above (#80832 is the one you want) are easier to mount than the magnaflows, imo.
    That said, I have a pair of brand new Magnaflow cats in the garage sitting on a shelf that I'd sell for $125/ea, bought for a project I never did.
    As for swapping in a used OEM set... its a crapshoot, at best. All of them are 20+yrs old at this point. Sure, they might work for a few years, but usually the cost vs aftermarket doesn't seem to pencil out.
  25. #50
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    Do NOT use Magnaflow, you will regret it at the next smog test!
    USE WALKER only!
