Results 1 to 10 of 10
Thread: Light bulb socket for cluster CHECK ENGINE light...PLEASE HELP.
    Jun 2008
    Hendersonville, NC
    87 325ic,04 IS300 SD
    I ALWAYS do a lot of research for this car. I just spent about an hour trying to locate this part, without success, and I really do not have many hours to hunt this down like I usually do.
    Please someone supply me with the part number for the little black socket that the light bulb for the check engine light then goes into. When you take out your entire cluster, you have all those clips that snap into place, in addition to that you have those two little bulbs that hang there. I need the part number for the black sockets that bulb then slides into and then you slide the two wires onto either side of the socket and you push the black socket into the cluster.
    On the left hand side you can see the black socket and bulb hanging, and on the right hand side you can see the black sock and bub hanging just below the blue connector.
    Here is an upclose:
    richardodn's Avatar
    richardodn is offline Old Guy BMW CCA Member
    Moderator
    Nov 2008
    Lakewood, CO
    20 440ix cab, 12 X3 35ix
    I doubt they're available as a separate item from BMW. The lamp itself is a T1-1/2 size. You might be able to find a suitable socket at places like mouser.com or digi-key.com. However the best bet is to simply get it off a parts car.
    "Howdy, Folks!"
    Oct 2013
    Chicago, Illinois
    '90 bmw 325is, '90 vert
    Richard could be correct about this one. However, try this part number 62-11-1-376-716 and see if it coincides with the bulb socket that you need.
    richardodn's Avatar
    Moderator
    Nov 2008
    Lakewood, CO
    Quote Originally Posted by Heatmakerz View Post
    Not likely to work. It appears to be one to mount a lamp into a circuit board.
    "Howdy, Folks!"
    Jun 2013
    DE, USA
    2002 525i
    My CEL is not coming on even when I start the car. This was since I bought a care 3 years ago. I saw a thread stating that a fuse might have been pulled out but didn't mentioned which fuse. Any suggestions will help.
    Jun 2015
    Santiago, Chile
    Audi A4 , Grand Cherokee
    Ressucitating this thread...
    Does anyone know where to find the Socket?
    richardodn's Avatar
    Moderator
    Nov 2008
    Lakewood, CO
    As already answered, best bet is to salvage from an old harness. You can probably get them from any BMW of that era.
    "Howdy, Folks!"
    Jun 2015
    Santiago, Chile
    Thank you. Ended up buying FROM Pelican
    richardodn's Avatar
    Moderator
    Nov 2008
    Lakewood, CO
    What did you buy?
    "Howdy, Folks!"
    Jun 2015
    Santiago, Chile
    I bought the socket from Pelican. Part Number: 61-13-1-369-447 It is currently available and I bought from there because I wanted to order their project book too.
