- Dash Wood trim removal?
Anyone have an idea how to get at the wood trim above the glove box? I can feel 2 plastic nuts, one on the left upper and one in left center on the low end of the trim. There are also 2 screw studs right center lower and right side upper that have no plastic nut. everything on the right feels tight even though there are no nuts. Is that it or are there any metal tabs that may be bent over like the door trim? I am refinishing the wood and I'm having a hell of a time trying to get my hand and arm up behind the dash. Thanks for the help.
Eric
1985 735i
its hard but you have to remove the 2 plastic nuts toward the center of the car then slightly pull out on the wood from the center side then pull toward the driver side and the wood will come out hope that helps JIM
Remove the HVAC panel and you can access the two nuts. Then just pull and slide towards driver side. just don't force anything.
Thank you, Sirs! I'll give that a try.
going through the HVAC panel is the best way, I got mine out by going through the glovebox and it was a major major major pain in the ass. The one nut is literally right there if you take the HVAC panel out.
2000 BMW M5 Evolve Alpha-N Tune, Evolve Carbon Fiber CAI's, UUC Short Throw Shifter, Dinan Front STB, Dinan Rear Sway Bar
2001 BMW 330i Dynavin N7 Pro
1985 BMW 745i 18" Style 37's, Team745i Chip, Getrag 265/6, Clutchmasters FX-300, UUC Short Throw Shifter, Strut Tower Bar, Bilstein HD's ("Build" Thread")(SOLD)
1986 BMW 735i Getrag 265/6 Swap, Strut Tower Bar, Bilstein HD's, Euro F/R Conversion, 3.46 L/S Diff (Scrapped)
2016 Ford Mustang GT Performance Pack Stock
2004 Mercury Marauder Eaton M112, 3.4 Billetflow upper, Accufab SBTB + Plenum, 4.10's, Stainless Works LT's, 2.5" Exhaust, Borla Stingers, FX-R projectors, Addco F/R swaybars
2003 Mercury Marauder JLT CAI, SCT Xcal4, Stainless Works LT's, SW 2.5" Catback
1996 Ford Bronco 4" lift, 35" BFG A/T's, MH1 projectors
This helped allot- Thanks!!
- You may not post replies
- You may not edit your posts
Forum Rules
