Results 1 to 12 of 12
Thread: m30b35 into an e23 - Need Help
    Dec 2002
    Bay Area, CA
    e23, e28, e36
    So I already bought the Left and Right Koala engine mount adapters, but when mounted the engine still looks crooked. The passenger side adapter worked perfectly, but once you try to mount the drivers side, things get weird. Since this is an e23, do I need to order the driver side engine support bracket?
    Here's the 2 Koala adapters I bought so far... (I borrowed the picture below for the Interwebz... I do not have the other engine support bracket in the picture)
    Here's how crooked it sits...
    Here's a pic of the driver side Koala adapter....
    Here's a picture of trying to use the existing e23 b34 engine support...
    e28 535i driver side engine support bracket #3. Is this what I need (11811175591)?
    Jun 2010
    TX
    1983/84/85 745i
    Some guy on Bimmerforum did a B35 swap, all I recall is he said one of the bolts holes was not there so he had to use one less. I will try to find the thread. No clue what side, been years since I looked into it.
    Goms187 or something seems to be his handle from what I recall.
    I sell Motronic 013 ECU boost cut delete chips and drop in Tial conversions.
    10/1984 745i
    11/1984 745i (will be for sale!)
    IH, Ford, MB, Volvo, and GM round out the pack.
    Dec 2002
    Bay Area, CA
    e23, e28, e36
    This thread? It says Goms used an early b35 but I am using a b35 from a 1992 e34 (I'm assuming that's a late b35).
    http://www.bimmerforums.com/forum/sh...e-there-issues
    Jun 2010
    TX
    1983/84/85 745i
    Thumbs up
    Well, I am out of useful information then bud. Sorry. Haha
    If you were after HVAC or 745i help, I am your man.
    10/1984 745i
    Oregon
    '83 735i, '98 V70 Volvo
    i'd post it up on mye28.com. Nebraska_e28, whose name is LJ, is a wealth of info on e23's. i think he currently owns 4.
    keep us posted! i've enjoyed watching your car's evolution.
    Dec 2005
    Omaha NE
    84' 533i Turbo
    I agree it looks more than a bit cock-eyed. Check realoem & ensure the e23 specs the same mounts as the e28. On the other hand, is it possible one of the mounts is bolted to the wrong mounting bosses? This would definitely shift it aft one way or the other significantly.
    Dec 2002
    Bay Area, CA
    e23, e28, e36
    I posted this on mye28.com... but here it is again...
    So here's the pics my mechanic just sent me a few minutes ago...
    New e28 mount (11811175591)
    Engine sits straight now... : : :
    Jun 2010
    TX
    1983/84/85 745i
    So...what was the solution?
    10/1984 745i
    Dec 2002
    Bay Area, CA
    e23, e28, e36
    To install an e34 b35, you will need to buy the left and right Koala adapters and the driver side e28 engine mount arm.
    Jun 2010
    TX
    1983/84/85 745i
    Okay cool. Going to upgrade to 1.3 Motronic or MS?
    10/1984 745i
    Dec 2002
    Bay Area, CA
    e23, e28, e36
    Motronic 1.3 for now... 😈
    Mar 2011
    RWC, CA
    1985 BMW 535i
    Glad this got sorted. Checked in woth a buddy who e32 b35 swapped his 85 e24 and he was having issues with the same excessive engine slant. Just got a response from him and its same fix as you got!
