*update
correct sized rods, balanced
pistons on, only stabbed myself once trying to get the wrist pins in
new rear main seal
rebuilt pump, nos chains, new slide rail/tensioner
Toyota RTV everywhere in addition to new gaskets
new front seal, new hardware
Oil pan, crank pulley, water pump installed. I reused my E21 water pump; I thought about going to the E30 setup but I don't see the need to move my radiator forward to the M20 position yet
motor mounts and oil filter housing installed
^ real owner of my cars
Beautiful. Absolutely beautiful!
Loving the work you're doing here.
Thanks!
head 'on' for protection, will actually install it tomorrow
'74 casting, more Toyota sealant, new gasket, new hardware
water pump pulley painted, alternator bracket painted/installed, oil filter installed, timing mark painted on crank pulley
intake
exhaust
cleaned up the surface rust and primed the subframe
painted
needs a wash
Looking "REALLY GOOD JP!" Looking forward to see it run. San Diego Auto-x in MAY?????
Always FUN TO DRIVE - Build Thread & Tech info - 79 320/6 track car build thread -- Videos of track car -Adam in car Auto-x video - Start-up video - 4/2011 Adam's TOP BMW time San Diego BMWCCA - 4-5-15 Dyno break-in run new M20B25 - Exhaust Thread - Link
Thanks Daryl! It will be on the road but I'm not sure if it will be broken in by then. I may have to come in the E46
few more last things... head actually on/timing set. Need to pull a tii distributor out of the pile and check it out/install. Will physically install the engine tomorrow and deal with fine tuning later.
you might notice that my stock downpipe/cat has been removed, headers sitting out for test fitting
btw, I finally mounted my bumper correctly (nyloc ftw)
ready for the new engine
just hanging out with my shark nosed friend
I foresee an exciting drive in your near future!
Deleted the O2 light reset
Battery tray cut out so I can fit the E30 airbox
Clutch installed
nice...... but tell me, what are all these other fine machines in the background?
Tom D
77 e21 - m42
88 e30m3
04 330 dinan3
84 r1000rt
02 r1150rs
all of them gray
14 f800gsa - red headed stepchild!
Great thread, thanks for posting!
Couple questions
Is it easier to install the bare long block, then put on the injection, etc? Seems like it would be easier to install the intake, injection etc on the stand then install in car, but I don't know. I've done this with aircooled porsches, on those you have to install everything first because of such limited engine bay access.
Roughly how much does a shop charge to machine, etc the block, prep the crank and the rods? What did you have done to the block crank and rods?
Thanks!
The city car sitting next to mine is a CSL that a customer bought last year. Most of the cars in the showroom belong to my buddy Carl, there's an Isetta in there that belongs to a customer, a Moto Guzzi that belongs to one of his friends, and a 2.7 911 that belongs to a friend who is remodeling his garage and needed somewhere to keep it temporarily. The cars in the yard are an assortment of Carl's personal stuff, friends, and customer cars.
I think it's easier to install it this way, I can maneuver the block around easy while it is hanging in order to get everything lined up. It took a few minutes to get it to engage the trans, I think it would have been much harder to do that if all the ancillaries were installed. If you go from the bottom like a Porsche/VW then you might as well install everything first.
Machine shop was about $500. They hot tanked my parts, decked & bored block, balanced rods, balanced & polished crank, valve job & mild porting on head
I got the cooling system finished. I might swap the 90A alternator for a 80A because the 90 is hard mounted to the bracket. I think 80 is more than enough and will have the benefit of bushings.
Really coming along nicely JP - great clean job!
beautiful work (and great background scenery in your photos!)
you're going to have to dress up that brake booster to match the engine though
really digging your build man. good stuff.
Thanks gents!
Yes Tom, I did end up with that bar. A friend of mine in the bay texted it to me when it was first posted on craigslist but I didn't get it in time. I managed to pick it up after it was posted on here. I actually don't like it that much and will likely end up having my buddy who is amazing at aluminum welding make me something similar to my Mason tii brace.
It may not look like I did much, but I accomplished a decent amount today
M20 throttle body/adapter dealt with
went to the junkyard: got a spare MAF, a 6 wire MAF connector/pigtail, 2x 3 wire TPS connector/pigtail, 2x M30B35 idle control valve, SuperETA 3 wire O2 sensor connector/pigtail
When we were installing the engine I think I managed to mess up the threads on my driver's side motor mount, replaced with an early E21 mount (longer stud/I think it has more rubber) because it was in stock. Also 'installed' the water divider and truly installed the stock exhaust (for now until I modify the headers). A 2002tii 002 distributor has also been used.
new E30 M10 alternator tensioner bracket
new poly bushings, new 888x10 v-belt. I think I may order a 875x10 as the 865x10 was too short.
Getting there...
Well, she runs. Now to clean everything up and figure out an airbox
Congrats!
nice.....
here's the reason for my amusement. about a year ago I was helping a friend stuff a M20B25 into his E21 315 and I was holding that same bar. I knew he had sold it, but I wasn't sure were it went until I saw it in your picture. at the time I called jay over at GC and asked him about it, he conveniently couldn't remember. it must have been really early in his career and he either didn't know how to weld aluminum or couldn't afford to have someone do it for him.
Tom D
77 e21 - m42
88 e30m3
04 330 dinan3
84 r1000rt
02 r1150rs
all of them gray
Thanks!
Hahahaha... we've been joking about it since I got it. We wondered why it was bolted together. Our long standing joke has been why they didn't use 2-4 more bolts. Honestly I'm not sure if I can use it anymore because the M30 ICV is in the way. I no longer need the cold start injector so once I make a block off plate and turn the ICV I might have enough room to clear the bar, we shall see
More progress
Enlarged the hole so I could get the computer plug through the firewall
I need to do a few more wiring mods and then should be ready to go
