Just got this message a couple of days ago and the car is running very rough... This is the P-Code P1634 - 'Throttle Valve Adaptation Spring Test Failed'. What is the fix for this problem? Any help is greatly appreciated. Thank you. Cap3056
El Cid 1999 ILDUDMD Tune/DINAN CAI/19 in Style 95 Rims/Bilstein's Shocks/Eibach Lowering Springs/OEM Folding Mirrors/Custom Cupholder/Custom Wood Sunshade/Sport Steering Wheel/Euro Center Console/Leather Shifter/Rearview Camera /Luke Custom 10 in Sub Box/Cross Drilled Rotors/Rear view Camera/BMW OEM Monitors/BMW E38 Picnic Tables/Vanity Headrests/OEM Roof Rack/Strut Bar/Dinan MAF and Dinan Throttle Body and Dinan tunning /BM53 Radio upgrade /Custom Innovadrive NXG39 modify and Alpine ILX-W650 touch screen radio.
Franco90 - What was the fix for your problem with the engine fail safe program; P1634 code?
Change your throttle body with a new one or good used one. Very easy swap, only 4 bolts. May need a new gasket as well.
If anyone is still dealing with the P1634 code on the 740i I had this code recently come up on a 740iL we got for a flip at the auction. If you cleared the codes it would come right back up. Run like shit in limp mode etc. I removed the connector for the throttle actuator on the TB and cleaned it with contact cleaner and the car now runs great. I'll post up if the fix works in the long run (for however long we have the car!)
1994 530iT 6 speed
