After replying to Daniels635turbo's post about coilovers for his e38, it got me curious to know what & how many viable options are there for our cars. I posted an initial list and continued to research and the list continued to grow until now it sits with almost 20 options! well technically it's not that many choices based on whether you have EDC or not... or simply chose to have it removed anyway. So in order to stop hijacking his thread with updates I'm simply posting on here for easier location (searches, subscriptions,...)
UPDATE: List below is now complete with about 25 options! See updated list here (post #21)
(* please note that some of the links are to eBay sales which may not be active for very long)
BMW e38 Coilover Options
1. ST X Performance, fixed damping (by KW, w/o EDC): $978 shipped
2. KW V3, double adjustable dampening $2750 shipped
3. KW Street Comfort, fixed damping (6kg Fr/5.6kg Rr spring rates): $2400 shipped
4. Kido (mine were 10kg Fr/8kg Rr Spring rates); see Aquila for costs ~$925 shipped
5. FK Highsport System (w/o EDC): $600 shipped
6. FK Highsport System (w/ EDC): $604 shipped
7. FK Silverline, Stainless Steel, non-adjustable (w/o EDC): $696 shipped
8. FK Silverline, Stainless Steel, non-adjustable (w/ EDC): $696 shipped
9. FK Silverline +X, Stainless Steel, adjustable Koni shocks (w/ EDC): $1239 shipped
10. BR Series BC Racing, pillowball mounts FR/RR; (9k Fr/6k Rr spring rates): $996 Shipped
11. Nex SS: $??
12. Fortune Auto 500 Series, pillowball camber plate, (10kg Fr/8kg Rr spring rates): $1,349
13. K-sport Kontrol Pro, 36 damping settings, camber adjustable pillowball mounts: $1,500 shipped
14. DGR 30 damping settings, camber adjustable pillowball mounts: $950 shipped
15. Broadway static 500S, 24 damping settings, aluminum mounts & camber plates: $1450 shipped
16. Ceika Performance, Type 2M: $1,720 shipped
17. Ceika Performance, Type 1M: $1,260 shipped
18. Vogtland , Individual Ride Height Adjustment, uses factory mount plates: Regularly $1139 shipped, on sale $963 shipped
So one question I have is, is it better to use factory mounts? Or best that the coilover come with its own mounting plates?
"A good scientist is a person with original ideas. A good engineer is a person who makes a design that works with as few original ideas as possible. There are no prima donnas in engineering." - Freeman Dyson
What about gecko coilovers....do a search...
Rubber Bushings
In stock form, almost all cars use rubber bushings in the suspension. The reason for this is that rubber bushings absorb much of the force produced by the vehicle's suspension when it is driven over bumps and road imperfections. This in turn isolates the occupants and provides a more comfortable, compliant ride. One of the issues with rubber bushings though is that, because they deflect more, the suspension can lose precision. This is generally not a problem for normal driving, but if a car is modified for better handling, a more rigid setup may be desired. Among the solutions to make a suspension more precise are urethane bushings as well as a more extreme solution, which are pillow ball mounts.
Pillow Ball Mounts
Despite their misleading title, pillow ball mounts are solid metal mounts that are used in areas such as the upper strut mount. The rubber normally used is replaced with a metal spherical bearing. Rather than deflecting from the cornering forces like a conventional rubber bushing, pillow ball mounts do not move at all. This translates into a far more precise feel from the suspension and steering.
My Kidos bottoms out too on the rear with 10k springs.
Also Neo Motorsports makes a coilover for e38s.
http://www.neo-motorsport.com/makes/..._id=82&type=gt
Monotube vs Twintube
https://www.tein.co.jp/e/special/ni_toryu/
Spaceships & Woodgrain.
Correction:
4. KIDO; $925 Within 2 weeks delivery CONUS; No specific 1 Week delivery option offered.
I have the BC coilovers on my car and I love them!!
Broadway Static is $1450 shipped, extra $300 for swift springs.
Info about Swift Springs
http://swiftsprings.com/tech/advantage.html
I always wondered how the FK Highsport went from $1100 in 2009 when Mojo first got them to $600 now. Did the quality drop off?
OEM (750) Spring Rates
Front
FH 14.75"
wd 15.0
5T
Comp 8" rate 151 lbs/inch
Rear
FH 15.18
wd 12.6
9T
Comp 7" rate 166 ibs/inch
FH - Free Height
wd - wire diameter
(x)T - number of coils
Good info MJDoom. i've made contact with one of the neo motorsport suppliers waiting to hear back from them about their products and will update the list as soon as i know.
Sorry Michael, Correction made in original post.
Sooo can you share more info about your setup. Where did you get yours from? the same as in the link in my post?
kool. do you have this info for the 740's too? both iL & i models?
Also just to confirm, these spring rates translate into 3kg/mm rear & 2.7 kg/mm in the front? Am i misunderstanding something? Those rates seems very low.
Im pretty sure the the 740il and 750il uses the same springs, so same spring rate. I don't see the 740i being different either.
Your conversion is correct, stock oem cars have low spring rates. Reason for plush ride. More e38 spring rate info below.
UUC/B&G
Front - 167 lbs/inch
Rear - 188 lbs/inch
H&R
Front - 256 lbs/inch
Rear - 193 lbs/inch
Eibach
Rear only - 199 lbs/inch
http://www.bimmerforums.com/forum/sh...k-spring-rates
I have the St coilovers and they are great. One of the shocks ended up making a weird rubbing noise when I would back out of my driveway in the morning and St sent me a new one right away withought me having to send my bad one back first. Now that's service. I am really happy with my setup and the drop is super low. Drives a bit rough but considering how low I am and how many potholes there are on the damn roads in my city they are great. Plus I noticed much less body roll on corners and they make the car feel a lot more sporty. I do know that St, for instance, requires a minimum ride height in order for them to warranty any parts so make sure if you put some coils on your height is within the limit, of course we can all lie if we have to but I think this is more for product satisfaction, ie they will last longer if you use them properly.
The shock went after a few weeks but I think it could have been defective from the start. Also I have put on 5mm spacers in the front and 8mm in the rear since I took these pics.
http://s1243.photobucket.com/user/Pepper56/media/imagejpg11_zps6a2a2076.jpg.html?sort=3&o=27
http://s1243.photobucket.com/user/Pe...ml?sort=3&o=26
Gonna try to insert my table from a spreadsheet here:
Brand Model Style/Type Damping (Fixed or Adjustable?) for EDC? Mount Plate Type Camber plates? Front Spring rate [kg/mm] Rear Spring rate [kg/mm] Other Feature Color Cost Shipping Total Cost Supplier link Contact info Comment ST X Performance Performance fixed w/o EDC $978 $0 $978 ECS tuning not compatible with my Kidos KW V3 14 damping settings w/EDC Chrome, yellow, black trim $2,750 $0 $2,750 ECS tuning Limited Lifetime Warranty KW Street Comfort Street fixed 6 5.6 $2,400 $0 $2,400 ECS tuning not compatible with my Kidos Kido 40 damping settings w/o EDC pillowball mounts yes adjustable 8,10, 12 8,10, 12 Black/Blue trim $925 $0 $925 Bimmerforum Michael FK Silverline +X adjustable Koni shocks w/EDC $1,239 $0 $1,239 ECS tuning BR Series BC Racing street use 30 damping settings pillowball mounts 9 6 black , gold trim $996 $0 $996 FCP Euro 1 year warranty; $95/coil replacement after 1 yr BR Series BC Racing street use 30 damping settings pillowball mounts 9 6 black , gold trim $995 $0 $995 Racing Extreme 1 year warranty; $95/coil replacement after 1 yr Nex SS ?? ?? ?? ?? ?? ?? ?? ?? ?? ?? $0 #VALUE! unknown Fortune Auto FA500 Series 24 damping settings pillowball yes 10 8 black, lime and green trim $1,349 $0 $1,349 FR Sport 714.515.4001 5 year warranty Fortune Auto 500 Series 24 damping settings pillowball yes 10 8 black, lime and green trim $1,199 $57 $1,256 No Limit Motorsport 866-381-4618 5 year warranty K-sport Kontrol Pro 36 damping settings pillowball mounts yes adjustable black, orange $1,300 $200 $1,500 eBay DGR DGR 30 damping settings pillowball mounts yes adjustable black, white, red trim $950 $0 $950 eBay Broadway Static 500S 24 damping settings aluminum mounts or SS pillowball yes varies,12 std varies, 10 std optional swift springs black, blue, silver trim $1,450 $0 $1,450 broadway static 5 year warranty Ceika Performance Type 2M rally, racing, and street 2 way adj damper Pillowball mounts yes adjustable 2.5 to 19 2.5 to 19 blue, black, red, gold trim $1,720 $0 $1,720 Ceika Performance External reservoirs (remote or piggyback); has helper springs Ceika Performance Type 1M 33 damping settings Pillowball mounts yes 2.5 to 19 2.5 to 19 black, gold pink $1,260 $0 $1,260 Ceika Performance has helper springs Vogtland Individual Ride Height Adjustment uses factory mount plates $963 $0 $963 ModBargains Neo Motorsport Racing Green 12 damping settings pillowball mounts yes, adjustable 10 6 orange, black $1,350 $100 $1,450 Neo Motorsport Quickstyle motorsport 1.855.477.8953 Neo Motorsport Dynamic Purple improved handling on the street & at track 32 damping settings rubber mount bushings ? 10 6 orange, black, purple trim $1,145 $100 $1,245 Neo Motorsport Quickstyle motorsport 1.855.477.8953 1 year warranty Neo Motorsport Blue Basics sporty ride; retain everyday driving comfort spring preload adjustable rubber mount bushings ? 10 6 orange, black, blue trim $800 $100 $900 Neo Motorsport Quickstyle motorsport 1.855.477.8953 1 year warranty
PS: KIDO coilovers go down to 7KG Spring Rate - never had anyone order that for an E38 though. The Pillow Mounts / Adj. Camber plates are a free option - you can have it your way.
No worries man. And I am sure research will show we all tend to be biased about things we know and have good experiences with - I'm okay with that. It's actually good to know that there are these many choices out there and what each offers, it makes for informed consumers.
A part of me does wonder how many of the "brands" are actually re-badged from the same manufacturer.... .
The ST coilovers use the OEM mounting (so I assume aftermarket camber plates would work too) and they are zinc chromate steel which gives them a light gold tint.
They will rust if you drive with road salt.
SPAX RSX968
Spax RSX Coilover Suspension Kits contain uprated, 28 stage on-car adjustable dampers with stainless steel height adjustable platforms, matched to a set of chrome-silicon race type, uprated coil springs.
Lowers Front 35-80mm / Rear 35-80mm
http://www.spax.co.uk/modern_products-rsx.php
http://www.demon-tweeks.co.uk/perfor...s-rear-35-80mm
BMW e38 Coilover Options Brand Model Style/Type Damping (Fixed or Adjustable?) for EDC? Mount Plate Type Camber plates? Front Spring rate [kg/mm] Rear Spring rate [kg/mm] Other Feature Color Cost Shipping Total Cost Supplier link Contact info Comment ST X Performance Performance fixed w/o EDC uses factory mount plates no bronze, yellow, black trim $978 $0 $978 ECS tuning 800.924.5172 5 year limited warranty KW V3 14 damping settings w/EDC uses factory mount plates no double adjusting damping Chrome, yellow, black trim $2,750 $0 $2,750 ECS tuning 800.924.5172 Limited Lifetime Warranty KW Street Comfort Street fixed 6 5.6 $2,400 $0 $2,400 ECS tuning 800.924.5172 not compatible with my Kidos Kido 40 damping settings w/o EDC pillowball mounts yes adjustable 7,8,10, 12 7,8,10, 12 Black/Blue trim $925 $0 $925 Bimmerforum Michael FK Highsport System w/o EDC uses factory mount plates no $600 $0 $600 ECS tuning not compatible with my Kidos FK Highsport System w/EDC uses factory mount plates no $604 $0 $604 ECS tuning not compatible with my Kidos FK Silverline non-adjustable w/o EDC uses factory mount plates no $696 $0 $696 ECS tuning not compatible with my Kidos FK Silverline non-adjustable w/EDC uses factory mount plates no $696 $0 $696 ECS tuning not compatible with my Kidos FK Silverline +X adjustable Koni shocks w/EDC uses factory mount plates no Zinc-plated, SS housing Chrome, blue, red trim $1,239 $0 $1,239 ECS tuning 800.924.5172 FK Silverline +X adjustable Koni shocks w/EDC uses factory mount plates no Zinc-plated, SS housing Chrome, blue, red trim $1,149 $0 $1,149 ESE Tuning 888.633.5237 BR Series BC Racing street use 30 damping settings pillowball mounts no 9 6 black , gold trim $996 $0 $996 FCP Euro 877.634.0063 1 year warranty; $95/coil replacement after 1 yr BR Series BC Racing street use 30 damping settings pillowball mounts no 9 6 black , gold trim $995 $0 $995 Racing Extreme 1 year warranty; $95/coil replacement after 1 yr Nex SS ?? ?? ?? ?? ?? ?? ?? ?? ?? ?? $0 unknown Fortune Auto FA500 Series 24 damping settings Aluminum pillowball yes 10 8 Swift springs upgrade option black, lime and green trim $1,349 $0 $1,349 FR Sport 714.515.4001 5 year warranty Fortune Auto 500 Series 24 damping settings Aluminum pillowball yes 10 8 Swift springs upgrade option black, lime and green trim $1,199 $57 $1,256 No Limit Motorsport 866-381-4618 5 year warranty K-sport Kontrol Pro CBM280-KP street use & occasional track 36 damping settings Aluminum pillowball yes adjustable 12 10 zinc electroplated bodies black, orange $1,196 $35 $1,231 k Sport Chris M. 480.829.8100 1 year warranty; regular price is $1300, but they have 8% off promo DGR DGR 30 damping settings w/o EDC pillowball mounts yes adjustable 8, 10 7,8 lifetime warranty springs black, white, orange trim $950 $0 $950 eBay DGR lifetime warranty springs Broadway Static 500S 24 damping settings aluminum or SS pillowball yes 12 to 16 10 to 14 optional swift springs 4-28k black, blue, silver trim $1,399 $50 $1,449 broadway static 5 year warranty Ceika Performance Type 2M rally, racing, and street 2 way adj damper Pillowball mounts yes adjustable 2.5 to 19 2.5 to 19 blue, black, red, gold trim $1,720 $0 $1,720 Ceika Performance External reservoirs (remote or piggyback); has helper springs Ceika Performance Type 1M 33 damping settings Pillowball mounts yes 2.5 to 19 2.5 to 19 black, pink, gold trim $1,260 $0 $1,260 Ceika Performance has helper springs Vogtland Individual Ride Height Adjustment uses factory mount plates no gold, burgundy, black trim $963 $0 $963 ModBargains Jurrian Terpstra 714-582-3330 x 8002 product replaced, but no info Neo Motorsport Racing Green 12 damping settings pillowball mounts yes, adjustable 8 8 other springs are available orange, black, green trim $1,350 $100 $1,450 Neo Motorsport Quickstyle motorsport 1.855.477.8953 Neo Motorsport Dynamic Purple improved handling on the street & at track 32 damping settings rubber mount bushings no 8 8 orange, black, purple trim $1,145 $100 $1,245 Neo Motorsport Quickstyle motorsport 1.855.477.8953 1 year warranty Neo Motorsport Blue Basics sporty ride; retain everyday driving comfort spring preload adjustable rubber mount bushings no 8 8 orange, black, blue trim $800 $100 $900 Neo Motorsport Quickstyle motorsport 1.855.477.8953 1 year warranty Spax RSX SPXRSX968 28 damping settings rubber mount bushings no Stainless Steel Height Adjusters Yellow, red, silver trim $892 $111 $1,003 spax Demon tweeks (in UK) 1 year warranty Suggestion: Using dry lube containing PTFE on pillowballs (e.g. White Lightning) should help prevent wear and binding.
I've also attached a PDF version of the spreadsheet for anyone's convenience.
Disclaimer alert: This information is the best known data that I could gather. Please confirm this info before buying or making any decision on any product.
Glad you found the thread useful. Credit goes to all the contributors on here for their input & suggestions though. I just wanted a central location to see the options instead of doing a "term" search again.
By the way, I contacted the shop and they can't recall what they did either. It was 3 or 4 years ago when that was done. Wish I had the car conveniently nearby to check. maybe take a pic to show, but I now have a different e38 than that original one (long story). Regardless I am in the same boat as you & looking to replace my suspension.
That being said. there were several threads where people suggested using the e46 links:
http://www.bimmerforums.com/forum/sh...k-for-coilover
http://www.bimmerforums.com/forum/sh...Short-endlinks
and a few others. good luck
* On a side note. Wonder if I should revise the spreadsheet by replacing the EDC column with whether sway bar links are included since some are included with the purchase & some are not? hmmmm
