Page 5 of 27 FirstFirst 123456789101112131415 ... LastLast
Results 101 to 125 of 668
Thread: Laminar's M3 5.0 swap: Fünf-Null
  1. #101
    Dec 2014
    Des Moines, IA
    '97 M3/4/5.0
    Another Sunday, another Autocross. Like last week, this event was held in the parking lot of the Iowa Events Center which is on the smaller side, lending itself to tight courses. This month’s course included a long 7-cone slalom, which was great for working on getting my slalom speeds up and backsiding the cones.
    I forgot to bring my helmet (on the day when you’re NOT supposed to forget things), so the flubs you see where I’m wearing a borrowed open face were on the second run where the tires were still cold and the car was incredibly tail-happy. Luckily my wife stopped by with my helmet so I no longer had to feel like I was wearing someone else’s apartment on my face.
    Speaking of flubs, those poor RE-11a rear tires are pushing 7 years old and are certainly not as sticky as they once were. I was hoping to nurse them through a couple of events next season but it looks like I’ll be picking up some more RE-71Rs right away to match the fronts and to keep the rear end behind the front.
    Last month’s course had a couple of high speed hard braking zones which brought out my engine’s tendency to lose oil pressure when all of the oil went sloshing to the front. For this event I switched from Motorcraft’s 5W-20 blend to Mobil 1 10W-40 and overfilled by about a half quart. You can see the pressure dip when I brake hard, but it only goes down to ~22psi instead of the 10psi I saw last month, and it recovers right away. Last event, it would stay at 10-15psi for a few seconds of hard acceleration out of the corner, which is a little scary. When I build this engine I’ll look at baffling the oil pan, but for now I’m satisfied.
    Still waiting on final results, but as it sits I landed at 10th of 65 for raw times. That didn’t include the 7th and 8th runs, though. I know my 7th run was about two tenths faster than my 6th, but I know of at least one car that beat my 7th run in his 7th or 8th, so my position could drop. Either way I’m very happy with the event and my progression this season – I started out finishing mid pack but have managed to work my way up to the top 15% or so in the last couple of events.
  2. #102
    Apr 2012
    Stuttgart, Germany
    1997 M3 / 5.3
    Very nice...one of the few that actually run their swapped cars in a competitive event!
  3. #103
    BALTIMORE
    the canton roadrace pan i bought for my swap fits *almost* perfectly. the swaybar hits the front sump, though really their pan looks like a modified OE pan and the front sump looks exactly the same, so if you don't have issues with your current setup the canton roadrace pan will probably work just fine for you
    the kickouts in the back might pose some problems for guys with tight exhausts though - once i get my bmw back in the garage, i'll take some measurements of the kickouts and report back
    Popular engine swap weights & stock engine weights
    M42 + trans - 427lbs
    302 + t5 trans - 475lbs
    m20b27 + g260 - 497lbs
    m52b25 vanos + g250 - 544lbs
    351w + t5 trans - 572.5lbs
    LS,
    aluminum block + t56 - 609lbs
    LS, iron block + t56 - 719lbs, EST.
    http://www.bimmerforums.com/forum/sh...60-m42-1jz-2jz
  4. #104
    Dec 2014
    Des Moines, IA
    '97 M3/4/5.0
    My exhaust actually touches the rear sump, so a new pan would mean new exhaust. When this engine gets built I'll be building headers for it anyway so that shouldn't be a problem.
  5. #105
    Aug 2009
    Metro DC
    79 323i, 94 325is, 13 M3
    Crud, mark me down for a race pan and pickup when I can summon the strength and patience to install it. The Ford Racing pan costs more than I would like, but it looks like the easy button. I'll just keep telling myself, it's about the same as a new set of tires & mounting.
  6. #106
    Dec 2014
    Des Moines, IA
    '97 M3/4/5.0
    If I was doing it again, I'd just take the Summit pan I bought and add some baffles per the Ford Racing design. For the street driving and mild autocross duty it sees, the engine will be fine.
    For a full-on race car, I'd look at a real pan. If you think about losing a $250 engine, plus a tow home from a track, plus lost entry fees, plus buying the right pan after all, it's worth the real pan in the first place.
  7. #107
    BALTIMORE
    ya know, since you're mainly doing autox right now, i'd bet that an accusump/accumulator would do the trick just fine
    LS,
  8. #108
    Dec 2014
    Des Moines, IA
    '97 M3/4/5.0
    Looked into it - it would unload in the first corner then steal flow from the engine to refill itself, possibly not being ready for the next corner. Maybe for a track day with 20-30 seconds between braking zones, but not an AutoX with 4 braking zones within 40 seconds.
  9. #109
    Dec 2014
    Des Moines, IA
    '97 M3/4/5.0
  10. #110
    Jul 2012
    Herndon, VA
    98 M3/4/5, RIP 528e
    Quote Originally Posted by Laminar View Post
    Very nice alternative to OEM! Does OEM not fit with your exhaust or are you just doing it to save some money?
  11. #111
    Sep 2015
    Stow, MA
    1997 328i
    I like it, what are you using for tubing?
  12. #112
    Dec 2014
    Des Moines, IA
    '97 M3/4/5.0
    Quote Originally Posted by 95maxrider View Post
    No idea if the stock one will fit, and no desire to spend $100+ to find out. I already had the 3/16" plate from building my engine mounts and Menard's gouged me at $10 each for a couple lengths of tubing. And this way I can be sure it clears my drain plug.
    Quote Originally Posted by squashman702 View Post
    Generic Menard's 1" 16GA tubing. I got the other side cut and notched last night but it was raining pretty good and my legs were getting wet sticking out from the under the car. Tonight I'll make the final pieces and gussets and get everything fully welded.
  13. #113
    Sep 2015
    Stow, MA
    1997 328i
    Nice, planning to do something like this for my LS swap as well. I wish we had Menards in the Northeast.
  14. #114
    Dec 2014
    Des Moines, IA
    '97 M3/4/5.0
    There used to be a steel distributor nearby that had free delivery and no minimum order - it was awesome. I got 20' sticks of 3/16" angle, 3/16" x 4" plate, and 1.5" round tube for like $25 each. I guess it wasn't a viable business model though since they're gone now.
  15. #115
    Aug 2009
    Metro DC
    Somebody gave me the stock one, so I can't fuss about the price. But it makes complete removal of either of the two drain plugs something between difficult and impossible. I was sort of bummed, until I remembered I bought one of these for coolant extraction (before it cost $55 and came in the Christmas color scheme) https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1. Cars with dipsticks. Gotta love em.
    Maybe after I suck it up and install the stupid $500 Ford Performance baffled oil pan, the drain plugs will be in better spots. Looks like they side mounted 'em.
    I'm almost done with my wiring. Intake and throttle are next up.
  16. #116
    Dec 2014
    Des Moines, IA
    '97 M3/4/5.0
    Got primed and undercoated last night, tonight I'll bolt it back up, hopefully the holes still match up. I welded as much as I could with it installed so it wouldn't pull too far out of shape.
  17. #117
    Dec 2014
    Des Moines, IA
    '97 M3/4/5.0
    It did need a little hole-widening to get the outermost bolts to fit, but it was no biggie.
    Started pulling weight out last night. The luxury package heated power seats weighed in at 66lbs each.
    Rear seat and sound deadening pulled. I'll probably yank the console, and maaaaybe the carpet. Everything will go back in after the two autocross events this weekend, so I'm trying not to get too radical.
    I'm stealing the seat from my video game driving seat, which is just a cheap racing seat from Amazon.
    I thought about making a rear strut bar last night but the general forum consensus is that it didn't really do anything. The shock towers don't actually flex that much and the panel behind the rear seat provides plenty of stiffness. After I get the seat bracket made tonight I may see if I can fit in a front strut bar.
  18. #118
    Sep 2015
    Stow, MA
    1997 328i
    Did you drive the car with the subframe brace yet?
    I knew the lux seats were heavy, but 66 pounds is a LOT. Making me reconsider getting racing buckets for my LS car. Granted, I could probably stand to lose 50 pounds myself, which would help.
  19. #119
    Dec 2014
    Des Moines, IA
    '97 M3/4/5.0
    Just enough to pull it into the garage. I felt a bit WT having a car up on jackstands in the driveway all week, but once I realized what was wrong it was too late to try and drive the car anywhere. Plus it's dropped below 45 degrees overnight this week and that's too cold to leave the RE-71Rs outside so the M3 gets a temporary garage spot. After this weekend the Blizzaks go on and the Potenzas get cozy in the basement.
  20. #120
    BALTIMORE
    wait what? is this thing getting the full racecar treatment now?
    LS,
  21. #121
    Dec 2014
    Des Moines, IA
    '97 M3/4/5.0
    Just for this weekend. I'll put everything back afterwards, if for no other reason than I can't spare the garage space to store the interior.
  22. #122
    Dec 2014
    Des Moines, IA
    '97 M3/4/5.0
    Got the seat in last night. Don't mind the hole in the bottom cover, it's where one of the bass shakers usually sits.
  23. #123
    BALTIMORE
    that sure is some fancy stitching for a cheap amazon seat
    LS,
  24. #124
    Dec 2014
    Des Moines, IA
    '97 M3/4/5.0
    Feelin' all Bentley up in here.
  25. #125
    BALTIMORE
    lolololol. i've sat in a $10k (probably) leather couch before - the plushness of the leather is incredible. i couldn't imagine that feeling while puttering around town in a 400hp+ car
    LS,
