Results 1 to 9 of 9
Thread: SRS Fault code 38 03
    Mar 2004
    Chesapeake, Va. USA
    2000 Z3 Roadster 2.8 Silver
    Table 38, code 03 Supply voltage. Every time I reset it come back immediately.
    Had my 2000, 2.8 Roadster in the garage for a couple of weeks to install a new top. Recently replace the battery a few weeks ago. Didn't have any problems until today when I went to test drive. Light seemed to come on as soon as I put it in gear and started moving.
    I did a search and couldn't come up with anything.
    Bill
    Dec 2007
    Great Dismal Swamp
    E36/7 E36/8x2 E46 F25
    There have been many threads lately where people have been led astray by incorrect SRS code readers. Yout best bet is to get the codes read with a real scanner. I have such if you want to stop by.
    /.randy
    Mar 2004
    Chesapeake, Va. USA
    Thank you so much Randy. The light is still off. I just ordered me a USB cable off ebay. Searching for a 20 pin adapter and some software to install on my laptop. It does look like table 38 is actually 40 in the Peake manual.
    Fort Worth, TX
    E36M3/E46M3/E39M5/E63M6
    Bringing this old thread from the dead as I got the same code - 38/03 w/Peake SRS tool - and it won't even re-set (tried many times).
    A bit of a background - my car would get airbag light from time to time when I'd move seats around, but I was always able to re-set the light with Peake and it would be gone for months...this time I didn't even move the seat - I think the car has been sitting for a couple of weeks, and when I started it, got the light.
    Do I need to take this to somebody with a more serious SRS tool, cause I can't find anything that describes 38/03 codes?
    E36/8 2000 M Coupe Cosmos Black/Black
    Shark, Conforti CAI, B&B Exhaust, H&R, Bilstein, AKG Subframe/Diff, UUC TME Red/Caps, Swapped Front Hats, Ice>Link.
    Feb 2012
    UK
    1998 Z3 1.9 5 speed
    Reseat all the connectors under the seats and have another go - they can be very touchy.
    Fort Worth, TX
    Quote Originally Posted by BladeRunner919 View Post
    Will definitely try over the weekend.
    Can anyone tell me what is 38/03 code pointing to? I can't find this fault in the booklet that I have.
    Feb 2012
    UK
    1998 Z3 1.9 5 speed
    Quote Originally Posted by TexaZ3 View Post
    Mar 2004
    Chesapeake, Va. USA
    In my case, it turned out to be a wire behind the passenger seat. After jiggling the wire a bit I was able to reset it.
    Fort Worth, TX
    Finally got a cheap Windows laptop and installed INPA to diagnose this. Ended up being faulty passenger side pre-tensioner:
    So I got the seat out:
    Got new tensioner:
    Took a chance to clean up the carpet under the seat. Nice and clean:
    Reinstalled and re-set the light. All good.
