well then your best bet is to run an inline hydro setup or make a bracket you can weld on to the rear control arms to mount calipers. My factory ebrake didnt work at all so I didn't miss it when I went to the massive setup.
I built a fixture to setup wilwoods on a non-M e36 and retain stock parking brake. It is weld on however. I like it because I can use the better calipers but still run 15" wheels if need be. I can get pics if you want.
And I also ran dual stock calipers for a season and it sucked. Lee is 100% spot on with the floating caliper comment. Stock calipers really need a lot of throw, but dont make much force due to small piston area. The willwoods have a ton more area and similar throw if not less.
Okay. So there's specs on wilwoods site with formulas explaining where to mount the caliper depending on rotor diameter, thickness, etc. I used those to design and machine this spacer/fixture. You clamp it to the rotor, and it ensures that your brake bracket is at the proper radius, the caliper is tangent to the outer edge of the rotor, and it is squared up in all other directions. Then you cut a bracket that you like, bolt it to the fixture, and weld it up.
I chose to cut down my backing plate, leaving it just large enough to support the ebrake shoes. You can just cut an area for the new caliper if you please.
Bolt your bracket on and clamp it to the rotor.
Poop weld it on. You will have to leave a gap on the back side where the abs sensor is. I also added a gusset in the back to reduce weld warping.
Replace wheel bearing, upper and lower balljoints(good upgrade) and trailing arm bushings while you have all this crap apart
Done. Stock ebrake, stock foot brake, baller e-brake, and 15" wheels.
I can rent the spacer out if anyone needs it. Its just going to sit around my workbench unless I need to do another e36
Sorry to revive an old thread and not trying to thread jack but does anyone know or make a dual caliper bracket for an e46 M3? Maybe someone that could make it or point me in the right direction any help would be appreciated.
Find a welder friend. That's really all you have to do.
Lol ok I was just checking to see maybe someone had them pre-made or something thanks for the info
Ya but they only have a kit for the e30
Not True
https://www.facebook.com/media/set/?...2267056&type=3
He definitely makes a kit for e36. And could probably do one for an e46 if he hasn't already
Oh my bad I don't get on Facebook much thanks for the info
Great work Gmfwd ! I PM you, but i am not sure if you received my message. Do you still have the scheme for the spacer and the welded plate ? If you could share them it would be awesome !
i posted in this thread but never seen the outcome. def interested in a bracket for this.
