First does anyone have one for sale? I have fab skills for custom brackets, so besides buying Wildwood single pots what other rear calipers have you guys used? The cable settup has to go!!! This is for an e36m.
Derek
I know Rustyfriend just said he's in the process of making a bracket for a second stock caliper. I will either be doing the same or I may use a front from an e21 since I have a couple sets of those laying around.
Wasn't sure if there were any 1 piece alternatives people were pulling from other makes/brands of cars. Or maybe smaller than a rear M3 caliper?
Hi Derek. Suck kit does exist. ;-) Bolt-on.
Lee
1969 2002 racecar + 1989 e30 M3 racecar
There are a few threads on BFc about those kits. One for e36 M3, one for e36 and one for e30. No cutting. No drilling.
Lee
OP is looking for an option other than buying wilwood calipers.
Myself, audioscience rustfriend and many others are looking for a cheaper more commonly available caliper option such as an OEM caliper.
Lee, have always trusted your info and parts/ thanks for all the tech you have provided to performance BMW parts! With that being said, was seen if say is there an option on any other make or model of car/truck that is a 1pc that anyone else has used (240sx/fox body/supra) anything?....or just man up and rock a Wilwood kit (already run Wilwood bbk lol)
Thanks guys
if you want to be cheap just weld 2 ears to the hub. shouldn't take me then 20 minutes
honestly the willwood calipers arent that much, you can find them new for 300 for a pair on ebay with pads. great deal for what you are getting. I love mine, they lock the rear wheels up fantastically plus they look cool.
The problem with using an OEM sliding caliper is the play which comes with the sliding mechanism. The tiniest play will show up greater at the handle. How heavy is an OEM steel caliper? Most likely heavier than the 3lbs Dynapro. A used caliper needs refurnbishing while a new caliper is... new. Not to mention the great selection of compounds and brands for the Dynapro. That being said, I am not pushing the kit itself in its final execution, but the thinking behind it. ;-)
One thing is for sure, having a parallel hydraulic system is night and day. You can feather the main brakes to transfer weight to the front wheels, and then modulate the hydro handbrake totally independently to slide the back end. Can't do that with an hydraulic handbrake plumbed into the main system.
Lee
i just wish i could keep the stock ebrake on my 328is with the massive kit. i live in the texas hill country and everywhere i park is on an incline.
Lee,
I wish you had a bracket for the OEM non-M rotor (280mm x 10mm) for the extra caliper. I'd use that with a single piston sliding or dual piston 1.5lb Wilwood caliper as my primary caliper and ditch the OEM caliper for a nice lightweight autocross setup. Then I'd get Coleman to make me something nice and light for a rotor and sketch up a nice lightweight aluminum hat to mount it on.
Can you say "drop 15lbs of combined unsprung weight off the rear axle"?
I park on all manner of inclines, I just leave it in 2nd gear, no problems yet in the year and half I've had Lee's Kit
e36 M3 model - hub must be removed for installation
https://www.facebook.com/media/set/?...2267056&type=3
e36 model - hub can be left in place for installation
Calipers used are Wilwood Dynapro 120-9703 - I suggest Wilwood's H compound pads for the highest grip.
Jegs and others eShops offer the calipers for under $150.00 each
And it all started 3 years go after 6 months of design and test fitting.
http://www.bimmerforums.com/forum/sh...1#post23537311
About 120 sets have been installed and it "seems" they work well ;-)
yea, youve said that to me before. i just dont trust it.
is there ANYWAY at all to have an independent caliper and retain the stock ebrake?
or...... the k-sport hydro ebrake has a provision, if i recall that can lock it in place, would this work for a makeshift parking brake?
^ could work a bit but I would still leave it in gear as a fail safe. I don't know why you dont trust leaving it in gear.
Park on a hill stay in the car dont pull up the e brake and put it in 2nd and let off the brake and the clutch. you wont go anywhere.
Hi guys
The hydro handbrake kit was designed for dedicated drift cars. Guys wanting more performance and modulation from their handbrake, and especially legal for drift associations requiring independent hydraulic systems between main and handbrake channels. It is a competition-only part. You can't have a competition part on a street-driven vehicle unless you're willing to give away something. It's like fitting a coil-over suspension and expecting Cadillac-plush softness and quietness. Or fiting aluminum suspension bushings yet not wanting vibrations, and so on... ;-)
Lee: Whats the pricing on the non-M bracket kit? And ballpark what would a set of calipers run?
Well lucky me Florida doesnt have state inspections of any kind . We get away with a lot of crazy shit.
