You can use whatever diameter pipe, as long as it can bolt up to the U.S. Spec front and rear sections
98 Estoril ///M3 4/6
S54 swap CSL
Do you have 328 bmws in Croatia? The US m3 system is identical to the euro 328 exhaust.
I also ask as would you he able to make a 328 decat section similar to the one above?
We have many of them. Are you sure that euro 328i section is bolt on to US spec m3 e36 3.2? Lambdas is in same place?
If this is true we can make xpipe model, with and without resonators.
Part numbers is not the same for cat, why I dont know, maybe pipe diameter. Gasket and rings # is the same.
euro 328
http://bmwfans.info/parts-catalog/E3..._lambda_probe/
us m3
http://bmwfans.info/parts-catalog/E3...obe/#1744162_1
http://www.youtube.com/watch?v=Ocrvaw3d4UM Dont drive over limited speed!!! Drive safely......
Pipe diameter is the same (twin 2") lambdas are located in the exhaust manifolds for UK cars, but I believe some us cars have lambdas post cat too?
UK 328 manifold
http://m.ebay.co.uk/itm/Bmw-e36-e46-...695?nav=SEARCH
Us manifold
http://m.ebay.co.uk/itm/OEM-BMW-E36-...516?nav=SEARCH
I know for a fact that people here in the UK, buy manifolds and manifold-back exhaust systems for 328s from America and they fit fine.
I have source to 328i euro midpipe (no 1 on picture). If anyone can confirm that I can use it as build sample for US m3 e36 obd2 i will make one xpipe resonator model.
http://bmwfans.info/parts-catalog/18301740997/
UK and most euro cars don't have the secondary lambdas post cat, we just have the 2 in the manifolds.
I'll quite happily take one for.my UK car if you could do one depending on price?
We can weld lambdas threads, this is no problem. I need to be sure that dimensions is the same between euro 328 and us m3 e36 3.2 so i can start to build it.
Based on picture from bmwfaninfo euro model have secondary lamdas.
Price is as in first post, maybe is ship little lower to uk from croatia.
I have a set of headers that will go perfect with this exhaust.
― George Orwell
always trying to make it lighter and faster
^^former build: http://www.bimmerforums.com/forum/sh...-neglected-M3/
current build: http://forums.pelicanparts.com/porsc...car-build.html
instant grams: doktor_b
I have a stock US 95 M3 exhaust midsection sitting in my garage. Almost want to find a way to send it to you...
Difference between obd1 and obd2?
I believe that will be the lambdas post cat. Although it would be far easier for you to just have the threads there regardless, and simply include 2 blanking plugs with them.
Guys someone just check to see if the US m3 exhaust is the same as a euro 328 one. Then he can make one! I'm fairly certain, they look identical, pipe size and gaskets are identical, hangers and headers are identical...
How much cost ship one obd2 m3 e36 us version midpipe sample to 00385 croatia, europe? I call my manufacturer and we can make some in next weeks. Vacations is end here.
I can source 328 but cant burn money and fiting is not plug&play.
Good news. I find US version 3.2 midpipe here in Croatia. I will have it next week and can go in production in 3 60mm or 48mm versions:
only straight pipes
xpipe
xpipe with resonators
If you can reproduce that US midsection you have me sold
I still have headers for sale that will work perfectly with these if anyone is interested pm me
― George Orwell
Wow those look nice. Would be in for a US spec set. I already have Authentic Supersprint headers and Supersprint exhaust so I won't switch both those out. Been looking for a midpipe. ODB1 and 2 are interchangable hence why alot of people just swap their 1 to a oem 2 pipe.
- BMW - BMW Motorsport - UUC - Eibach - Tokico - ZKW! - Predator Chromium - Prolumen - ViS - Depos - Simota - Rieger - M Technic - Lamin X - Goodyear - MYCARR
Ok
Will also be in for a set of the 48mm Xpipe. Would the price change if shipped to Canada?
