I'm in the process of swapping the instrument cluster on my '83 733i and I encountered one small problem. I have two of these little clips that appear to clip onto the slit in the circuit board, but my board only has one slit so which one do I need to connect? There's a clip with a single blue/white wire which ties into the large blue plug and there's a clip with a blue/green, blue/yellow, and solid yellow wire on its own. Pics below...
1993 325i 5mt
Where did you find this cluster?
The blue wired one should be for the cruise control input...and increases the volume on the ECE cars with equipped radios (such as the Becker units).
Do you have the ETM yet for this car?
I make E23 parts.
10/1984 745i
11/1984 745i
11/1984 735i (10:1-265/6)
2000 BMW M5 Evolve Alpha-N Tune, Evolve Carbon Fiber CAI's, UUC Short Throw Shifter, Dinan Front STB, Dinan Rear Sway Bar
2001 BMW 330i Dynavin N7 Pro
1985 BMW 745i 18" Style 37's, Team745i Chip, Getrag 265/6, Clutchmasters FX-300, UUC Short Throw Shifter, Strut Tower Bar, Bilstein HD's ("Build" Thread")(SOLD)
1986 BMW 735i Getrag 265/6 Swap, Strut Tower Bar, Bilstein HD's, Euro F/R Conversion, 3.46 L/S Diff (Scrapped)
2016 Ford Mustang GT Performance Pack Stock
2004 Mercury Marauder Eaton M112, 3.4 Billetflow upper, Accufab SBTB + Plenum, 4.10's, Stainless Works LT's, 2.5" Exhaust, Borla Stingers, FX-R projectors, Addco F/R swaybars
2003 Mercury Marauder JLT CAI, SCT Xcal4, Stainless Works LT's, SW 2.5" Catback
1996 Ford Bronco 4" lift, 35" BFG A/T's, MH1 projectors
Ha ha, I got it from offroadkarter's '86 part out. What's ETM?
1993 325i 5mt
Nope, only the half-ass useless chiton's manual
1993 325i 5mt
I make E23 parts.
10/1984 745i
11/1984 745i
Thanks for the link, I found out where they go, under the little black door on the back of the cluster.
1993 325i 5mt
Compare the '86 cluster http://wedophones.com/Manuals/BMW/19...g%20Manual.pdf
The SI board changed then, not sure what else.
I make E23 parts.
10/1984 745i
11/1984 745i
Guess I didn't edit quick enough ha ha, I'm pretty sure they're the same, I just had to open the little door on the back. I appreciate the help, Eric.
1993 325i 5mt
This old thing?
Sent from my iPhone using BF.com
1989 635CSi Alpinewieß
1989 325iC Alpineweiß II
1985 745i Cosmosblau / Pacificblau cloth
1995 525iT S50 / 5 speed Alpineweiß III
1985 635i Cosmosblau
1998.5 M3 Technoviolent
1990 325iC
1999 528i
HI...
I've got the same problem - I took the cluster out and there are two little clips and there is only one place to plug in...I didn't see any Black Door that you could open?? There are little door tabs that you can snap off to access the board edge, but on mine there is only one door snapped off under where it ways tempo...
One clip has a single wire that is brown with a red stripe, and the other has two wires blue with yellow stripe and a red with a yellow stripe..
Any ideas??
ThanksAttachment 617711
Attachment 617712
The blue yellow is the speed information that goes to the OBC and cruise and goes to the one open spot opposite of the way you would think. the wire comes out of the connector pushed up against the cluster, not away from the cluster. The other blue connector one is not used.
Thanks so much... I'll just leave the brown wire w/red stripe hanging in there...and connect the other.
I took the cluster out to see if I could figure out why the temp and fuel gauge are pinned to the right but nothing obvious...?? Any thoughts on that??
Thanks again...really appreciate the coaching...
